#21 |
Dark Cherry Pearl Join Date: May 2007
Re: Tire Pressure
On my previous vehicle (Ford Explorer) I kept 35 psi front and 32 psi rear. With those settings I got 75K miles from the original Goodyears and 75K from the replacement Michelin ATX tires as well. I found the slightly higher pressure provided a bit firmer ride (which it needed); also seemed to give the sidewalls a bit of increased strength and kept the edge of the tire from rolling over and wearing as much.
Regarding, my RTL- the pressure on my tires when I first checked (after 2K miles) was almost 40 psi fronts and 36 psi rear. Very high when compared to the recommended number in the door sill and the tire Mfg's specs. However, I never noticed the higher pressure in the feel of the ride; but I did notice the hurt in MPG when I lowered the front pressure to 32. I also checked the pressure before / after driving the truck and found out that in the current weather (approx. 82 deg. F) that the pressure increases about 3 psi once driven upon and heat put into the tire. Thus, I'm running 36 psi front and 34 in the rear. A little high I know; but I like the ride and the mileage did seem to improve a bit. My wife and I just completed a 2.3K mile vacation trip to the Outer Banks of NC (Avon, NC) with the above psi values. With the two of us, vacation 'supplies' and two mountain bikes in the bed, we got approx. 21.3 mpg when on flatter roads of Virginia. Lastly, I check the tires occasionally for heat (driving approx. 75mph) and the tires were hardly even 'warm' to the touch of my hand. So, from my prior experiences and the observations during the vacation trip, I think the 36 front / 34 rear psi readings are going to be 'okay.' I'll also watch and observe though....
#22 |
Amazon Green / Olive Join Date: May 2006
Re: Tire Pressure
I'm surprised that most people are calling the truck more responsive. I've always felt that cars get more twitchy or darty on the highway with higher tire pressures. I'd agree with the increased mileage statement though.
#23 | |
ROC Rank: 3k Comma Club
Billet Silver / Gray Join Date: Sep 2005
Re: Tire Pressure
Honda Towing Package, Rear Splash Guards, Prodigy brake controller, Garmin 2610 GPS, Front Window Tint, Torza Soft Top. Echomaster reverse sensor step bumper What I tow: 2005 Fleetwood Highlander Sequoia - 3,500 lb 2008 Ranger 1860 Angler w/150 Yamaha - 3,950 lb "Things will get better as they improve." |
#24 |
Formal Black Join Date: Apr 2010
Re: Tire Pressure
I just measured my tires b/c the light was on that I was underinflated and one was at 20psi and another 26. So i put 38 for the front and 37 rear. Is that too much?
#25 |
2009
White / Beige Join Date: Jun 2005
Re: Tire Pressure
The 09 and 10 RTL with 18" wheels the tire states 44LBS max and I run 41 to get better MPG. It does make a big difference. At 32 I was getting 17MPG at 41 I am getting about 20MPG. (all air pressure is cold at about 70 degrees F. )
For those naysayers that say 44 is too high - get a wheelbarrow and read the tire ( It will be 55 to 60 lbs) fill it to the rated lbs and fill the wheelbarrow with rocks and push it around. Now lower it to 40 lbs ( this is what Honda is telling you to do with your 18" wheels rated 44lbs when you put 32 lbs in it ). and push the wheelbarrow around - you almost cannot do it. This is exactly what you are doing to your truck when you keep the pressure too low. Tires almost never blow out for being too high at cold temperature ( they are cold at 70 F at 32lbs, they will be at 50-60 lbs after 100 miles at 70mph because the sides are flexing causing heat. if at 70F and cold at 22lbs after 100 miles at 70 mph they might reach 200lbs from temperature from the sides flexing that will cause a blow out - that is why Big Brother requires TPMS on all cars/trucks now. ) Some folks whose TMPS is on when they start their drive and it is off after 2 minutes are at the 27/28 pressure cold and warm up enough to get enough pressure to end the TPMS warning. Maybe the TPMS waring symbol should be $$$$ flying off. People seem to care if they are losing money.
2009 White RTL with Gray interior My second Ridgeline. My first was a 2006 RTL Steel Blue with Gray interior. Mud Flaps, AVS bug guard, AVS ventvisors, Sportwing Door Protectors, Donnelly Autodim Compass Mirror, Isimple Ipod attachment. And a full sized 18" spare tire.
#26 |
Billet Silver / Gray Join Date: Jun 2005
Re: Tire Pressure
Yesterday after much research I had 4 new General Tire Grabber HTS
245/65R17 LLR Serv.Desc: 111T Load Range: XL UTQG: 640 AB They have a Max Load of 2403lbs each or 7090 Total Max Inflation pressure: 51psi If we run these according to Honda's door plate @ 32psi, they look like flat tires. I noticed that the installer put 41lbs psi and the ride is very comfortable. I would like to know what would be the optimum pressure both for safety,comfort and max gas miliage. ANY SUGGESTIONS WOULD BE APPRECIATED
SILVER RIDGELINE RTL/S/R Moonroof, XM, Foglights, Roof Rack, Bed Extender, Running Boards, Trailer Hitch Package,Rear Splash Guards, Hood Air Deflector, Dark Floor Carpets, PinStriping, Full Size Spare,G E Nighthawk headlights 9003/HB2 Honda Door Visors. RAMPAGE 49" L.E.D. Brake Light w/indicators. Boss 318 Chrome 17x8 wheel on General Tire Grabber HTS 245/65R17 LRR,111T,XL's. |
#27 | |
2009
Sterling Gray Metallic Join Date: Aug 2009
Re: Tire Pressure
On my Ridgeline tires, max is 44psi and the dealer had delivered my truck with 41psi which is where I continue to run at 93.2% of max pressure or 3psi short of max. Your tires are 51psi max, so IMHO you would probably be ok at 91-93% of max around 46 - 47psi. which is still 4-5psi less than max pressure.
mahna-mahna |
#28 |
2010
*Not a Ridgeline Owner
Other Join Date: Aug 2009
Re: Tire Pressure
Cold tire PSI:
40 front 36 rear |
#29 |
*Former Ridgeline Owner
Nimbus Gray Metallic Join Date: Sep 2010
I've been running 32 psi.
Anyone else?????
Leather, Navigation & Moonroof > 245/70 17 Toyo "Open Country" A/T Boots! OEM Steelies 245/70 17 Winter Boots!![]() My other ride is my Bicycle! |
#30 |
2009
Sterling Gray Metallic Join Date: Jan 2007
Re: Tire Pressure
Same here. 32 psi...20,000 miles and a few rotations and my stock Michelin's are wearing perfectly.
All tire manufacturers recommend using the tire pressure thats stated on on your car's doorsill. Bottom line...Honda knows best. But, you always have guys who think they know better than the engineers...like running different weight oils, tire pressures, fuel or oil additives ....etc. |
| What is your tire normal pressure? | Ultra-HOG | Tires, Wheels and Suspensions | 57 | 04-26-2008 11:28 AM |
| Low Tire Pressure Indicator | FL_Ridge | Dear Honda: (Feedback Forum) | 6 | 09-15-2006 05:14 PM |
| For Sale - OEM Valve Stems for Tire Pressure Sensors | chiricon | Trading Post | 0 | 09-09-2006 12:35 PM |
| Check Your Tire Pressure | hwycycle | Tires, Wheels and Suspensions | 7 | 08-16-2006 10:27 PM |
| Suggestions, methods and tools for maintaining correct tire pressure. | Ultra-HOG | Tires, Wheels and Suspensions | 14 | 12-14-2005 05:59 AM |
