Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Miscellaneous/General Honda Ridgeline Discussions
Old 11-07-2009, 08:09 AM   #11
RinconRidgeline
ROC Rank: Stuffing
2007 RTS
Formal Black
Re: Transmission Fluid: To change or not to change?
Automatic tranny fluid needs to be changed. I will NOT buy a vehicle that does not have a tranny dipstick.
Our Ridgeline had a very small leak at the temp sensor. Honda dealer drained fluid to inspect the O-ring. The fluid at 10k(?) was dark colored. They did not have an O-ring in stock so back in with the old one along with new fluid. I returned 2 weeks later to have O-ring installed and the tranny sensor was not leaking, so I agreed to leave well enough alone. 2 years later I found the leak had returned. This time the new O-ring was installed and once again fluid was dark colored.
I got 2 partial fluid changes at Hondas expence.
As a rule I change my filter one time @25k and just drain the pan and install new fluid every year.
My mechanic friend told me that if the tranny filter were to become clogged that enough wear has taken place to rebuild your tranny.
I have a 96 Regal 165k and a 96 Dodge Cummins 182k and the automatics have never failed me with this type of service.
Transmission fluid will not hold up to heat like engine oil.
While checking, take a white paper towel and if it is dark colored or smells burnt then change it. Simple.
I do not know the cost to rebuild the Ridgeline tranny, but I would guess close to $4000. I do know that the largest section in my shop manual is about the,,,tranny.
RinconRidgeline is offline   Reply With Quote
Old 11-07-2009, 03:01 PM   #12
breye
ROC Rank: Stuffing
2009 RT
Billet Silver / Gray
breye's Avatar
Do the RL have a transmission filter?
breye is offline   Reply With Quote
Old 11-07-2009, 09:22 PM   #13
Jet Pack
ROC Rank: Cranberry
2008 RTL
Jet Pack's Avatar
According to the service manual, yes.
Dan
'08 Ridgeline EX-L S/R
Better to be a rider for a moment that a spectator all your life.
Jet Pack is offline   Reply With Quote
Old 11-07-2009, 10:02 PM   #14
shovelhd
ROC Rank: Green Bean Casserole
Steel Blue / Gray
shovelhd's Avatar
There is no transmission filter to change during normal maintenance.
Shovelhd media installation thread
Kenwood DDX8019*Garmin KNA-G510 Nav 2009 Maps*KCA-BT200 Bluetooth*KTC-HR100 HD Radio Tuner*KTC-V500N TV Tuner (RIP)*KCA-iP200 iPod Adapter*SIR-KEN1 Sirius Satellite Radio Tuner with Lifetime Subscription*Webb OEM XM Antenna Conversion*PPI DCX-730 DSP*Eclipse XA4000 Mains Amp*Rockford-Fosgate T1500bd Sub Amp*Rainbow SLC 265 Front Components*Rainbow 165 SL Rear Coaxials*(2) Diamond Audio D610D4 Subs in Custom Subthump Box*KP Technologies Rollup Modules
shovelhd is offline   Reply With Quote
Old 11-08-2009, 06:53 AM   #15
flying butcher
ROC Rank: Stuffing
my mechanic told me that it doesn';t need to be changed as often as most people believe. Changed mine at 79,000 and again at 130,000 no problems and I tow a boat 60% of the time my 2 cents
flying butcher is offline   Reply With Quote
Old 11-08-2009, 10:25 AM   #16
breye
ROC Rank: Stuffing
2009 RT
breye's Avatar
Now that’s good news.
I don't like that idea very much
Old 11-08-2009, 11:00 AM   #17
Jet Pack
ROC Rank: Cranberry
2008 RTL
Jet Pack's Avatar
You would have to open the tranny if you want to service the filter.
I've never owned an automatic before the R/L, I thought most auto trannys had inner filters.
Dan
Old 11-08-2009, 11:44 AM   #18
breye
ROC Rank: Stuffing
2009 RT
breye's Avatar
All the transmissions that I have changed fluid on don’t have a drain plug. The only way to change the fluid was to drop the pan and the filter was right there. So you changed the filter at the same time as well as a magnet.
Jeep Wrangler automatic transmission fluid and filter change
http://images.google.ca/imgres?imgur...a%3DN%26um%3D1
Old 11-08-2009, 05:23 PM   #19
shovelhd
Steel Blue / Gray
shovelhd's Avatar
That's not the way it works on a Ridgeline transmission. You guys gotta forget what you know about American transmissions. This drivetrain is different.
Old 11-09-2009, 07:25 AM   #20
g8rrr
ROC Rank: Stuffing
2007 RTS
Formal Black
g8rrr's Avatar
i just changed mine at 30,000 miles and it it looked pretty grungy
2007 Black RTS, Curt hidden hitch w/ OEM wiring harness, ventshade window visor, husky rear mud flaps, Backup sensor, Sportwing door guard, SS Raptor nerf bars, Window tint
g8rrr is offline   Reply With Quote
My A136 maintenance experience xd9x19 Under The Hood / Performance 105 Yesterday 04:31 PM
Transmission fluid change?? k co 3/7 Mods, Installs and How-To's 2 05-13-2009 04:03 PM
How to change transmission fluid and transfer gear box? ZowieK Under The Hood / Performance 6 04-24-2009 02:36 PM
Discolored transmission fluid N68330 Problems & Issues 6 03-07-2008 08:41 AM
Transmission Fluid Change mugen1 Miscellaneous/General Honda Ridgeline Discussions 7 11-06-2007 12:29 PM
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
