| Register | FAQ/How To's | ROC Chat Room | ROC Calendar | Honda Dealers | Honda Club Store | Search | Today's Posts | Mark Forums Read |
#1 |
ROC Rank: Stuffing
Ordered new struts.
Well I finally ordered some new struts my l/r strut is blown and makes a rattle noise over every bump on that side. I am kinda dissapointed seeing as I only have 34,000 miles on this truck. But anyways I ordered kyb's for just the rear hopefully this takes care of the noise.
Advertisement |
#2 |
The Modest Moderator
Billet Silver / Gray Join Date: Apr 2006
Re: Ordered new struts.
The Ridgeline rear suspension doesn't have a struts. The rear suspension is made up of a springs with a shock running vertically up the center of the each coil spring.
2006 Ridgeline RTL, Silver with roofrack. 2000 Accord V6 EX, White no roofrack.
#3 |
ROC Rank: Stuffing
Well whatever you want to call it this is what I ordered.
http://www.rockauto.com/catalog/rafr...&a=FR63-341402 |
#4 |
Yeppers, I made the same mistake and was corrected by the lead designer himself, Gary Flint.
#5 |
ROC Rank: Green Bean Casserole
Steel Blue / Gray Join Date: Mar 2005
FYI, the OEM shocks and struts are made by KYB.
Shovelhd media installation thread Kenwood DDX8019*Garmin KNA-G510 Nav 2009 Maps*KCA-BT200 Bluetooth*KTC-HR100 HD Radio Tuner*KTC-V500N TV Tuner (RIP)*KCA-iP200 iPod Adapter*SIR-KEN1 Sirius Satellite Radio Tuner with Lifetime Subscription*Webb OEM XM Antenna Conversion*PPI DCX-730 DSP*Eclipse XA4000 Mains Amp*Rockford-Fosgate T1500bd Sub Amp*Rainbow SLC 265 Front Components*Rainbow 165 SL Rear Coaxials*(2) Diamond Audio D610D4 Subs in Custom Subthump Box*KP Technologies Rollup Modules |
#6 | |
ROC Rank: Cranberry
Billet Silver Metallic Join Date: Mar 2007
Dan '08 Ridgeline EX-L S/R Better to be a rider for a moment that a spectator all your life. |
#7 |
ROC Rank: Stuffing
The sway bar links don't appear to be broken but I have seen that on some other cars. I know the shocks are bad because the LR is leaking fluid out of it.
I do know that the factory struts and shocks are made my KYB like a lot of cars. Aftermarket KYB's will have a lifetime warranty though and I think they are better. I also get cost on them $39 each. Brian |
#8 |
ROC Rank: Stuffing
I replace my rear shocks today. So what is the difference between a shock and a strut? I removed the whole shock assembly which seems to be the same as a strut. Took it to the spring compressor and compressed the spring so I could remove the nut off of the mounting plate to put the new shock in. I have never had to do that to a shock before. Every shock I have replaced you never needed a spring compressor to remove an attached mounting plate.
Brian |
#9 |
ROC Rank: Turkey
Steel Blue Metallic Join Date: Dec 2007
Anyone have any problems with the fronts? Those ARE struts, no??
I've got a front right that ONLY makes creaking noise in the mornings, when it's cold.... |
| Heavier Shocks and Struts for 2006 Ridgeline | pneary | Exterior | 2 | 08-07-2009 05:11 PM |
| Blown Struts | jian2000 | Problems & Issues | 4 | 07-30-2009 02:31 PM |
| Ordered the Borla and Injen today!!!!! | BBQRidge | Under The Hood / Performance | 13 | 12-08-2007 11:03 PM |
| Struts on back order??? | kthi7 | Problems & Issues | 9 | 09-07-2006 06:16 PM |
| blown struts | caliridge | Off-Roading | 30 | 06-02-2006 06:09 PM |
