#1 |
Formal Black Join Date: Apr 2012
Items needed for hitch install?
Sorry, search isn't yielding the answer...
I understand a harness is on the frame rail But I keep seeing people posting about adding a relay under the dash Is that relay just for trailer brakes? All I want is the harness and lights.... I won't pull anything big enough to justify trailer brakes. Any help to clarify exactly what I will need would be awesome |
#2 |
Aberdeen Green Metallic Join Date: Dec 2010
Re: Items needed for hitch install?
Not quite...
Here's the instructions for the hitch (it says '07 but the same for '08) http://www.handa-accessories.com/ridgeline/hitch07.pdf And this is the harness. Make sure you get the year specific harness. What is installed from the factory is a partial harness. There are gaps in the wiring that you need to fill in. Don't try to figure out why other than more money for Honda. http://www.handa-accessories.com/ridgeline/hitch07.pdf
![]() Full Size Spare, USA-Spec iPod adaptor, Westin powder coated sidesteps, OEM tow hitch and harness, 2009 camera handle, Back-up camera, Dual input 3.6-inch Boyo Monitor (Second camera on rear of my teardrop trailer), Trunk carpet, Trunk dividers, Billet Grill, Infinity Reference 1031t Tweeters, Full-time power to front and rear 12V outlets, Fumoto oil drain valve, FIGS G2 hood prop kit. Rhino 360B Hitch step, OEM Rear Splashguards, 255/65/17 MS2's. |
#3 |
I think those are the same links?
Thanks a ton for the reply though... It's snowmobile season and I've waited long enough to put on the hitch ( = |
#4 |
Lol...yup same link.harness in the front sections and the hitch itself at the end.
#5 |
Oh my bad, I read the top and failed to go thru the rest once seeing it was the same
Thanks! |
#6 |
#7 |
Yes. But i went OEM. It was easy to install. Keeps the trailer on a separate circuit. Will not have any issues with the wiring. Only way I would go.
These splice in kits are cheaper kits that tap into the tail lights. Some people have no issues, Others run into corrosion problems and have tail light problems. Stick with OEM wiring. The hitch itself you have more flexibility with OEM or not.
![]() Full Size Spare, USA-Spec iPod adaptor, Westin powder coated sidesteps, OEM tow hitch and harness, 2009 camera handle, Back-up camera, Dual input 3.6-inch Boyo Monitor (Second camera on rear of my teardrop trailer), Trunk carpet, Trunk dividers, Billet Grill, Infinity Reference 1031t Tweeters, Full-time power to front and rear 12V outlets, Fumoto oil drain valve, FIGS G2 hood prop kit. Rhino 360B Hitch step, OEM Rear Splashguards, 255/65/17 MS2's. Last edited by Elkhunter; 11-11-2012 at 10:20 AM. |
#8 |
*Former Ridgeline Owner
Nimbus Gray Metallic Join Date: Sep 2010
Credit card!
Leather, Navigation & Moonroof > 245/70 17 Toyo "Open Country" A/T Boots! OEM Steelies 245/70 17 Winter Boots!![]() My other ride is my Bicycle! |
#9 | |
I suggest that you stick with the OEM harness which isolates the trailer electrics from the truck electrics. |
| Tools needed to install a Truxxx lift? | FireMalt | Exterior | 1 | 01-04-2011 08:48 AM |
| hitch, harness and controller now needed. | bonescrub | Racks, Hitches & Towing | 0 | 07-13-2009 11:28 PM |
| How hard to install these items? | SquireSCA | Accessories | 18 | 12-07-2007 07:55 AM |
| Bull Bar Install help needed | Jenskp | Accessories | 7 | 08-22-2007 03:23 PM |
| Trailer Hitch Needed, wiring not available?? | lineridgejohn | Racks, Hitches & Towing | 15 | 06-02-2005 05:10 PM |
