Steering sounds & rear differential locking up - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Tires, Wheels and Suspensions
Old 11-12-2012, 06:57 PM   #1
Audiosolutions
Dark Cherry Pearl
So I have a 2007 ridgeline 91k miles and when I stear left I hear a weird sound is not clonking is more like mazdas zoom zoom Jajajajaja but for real it's alarming a tad bit especially when my car doesn't make any noises I would like to know if its something I can do a mechanic mentioned the power steering fluid to flush and put new fluids idk though
Audiosolutions is offline   Reply With Quote
Old 11-12-2012, 07:43 PM   #2
IanRTL
Re: Steering sounds & rear differential locking up
When was the last time you changed the rear diff (VTM-4) fluid? It needs to be changed every 20-30k miles. Old, worn out fluid and cause weird sounds when you turn left or right. If it's more of a whine, it could be the power steering fluid. A little more detail will probably be needed to make a more fair assessment.
Westin chrome tube steps, AVS vent visors, AVS bug shield, bed extender, carpeted trunk mat, blue LED interior switches, LED interior/exterior lights, Weathertech floor mats, Extang Trifecta soft tonneau cover, 5000k headlight bulbs, Pioneer AVH-P4400BH bypassed head unit, Metra Axxess ASWC, Jensen Carbon 65C components, Jensen Power 400 2ch bridged amp, 10" Boss Onyx shallow sub in custom behind-seat enclosure, FatMat sound deadening, Koolertron backup camera
IanRTL is offline   Reply With Quote
Old 11-12-2012, 07:56 PM   #3
Gouranga
2007 RT
Formal Black
i didnt know you had to change the rear dif fluid every 30k miles
what about tranny fluid ?
Gouranga is offline   Reply With Quote
Old 11-12-2012, 08:39 PM   #4
IanRTL
Yep. Honda recommends changing the rear diff fluid first at 15k miles, then every 30k miles past that. The tranny fluid is to be changed first at 45k miles and then every 30k miles although some have done the first change sooner. Some with trucks older than 2011 who have the older Z-1 fluid from the factory have elected to do three full drains and fills with the newer, full synthetic DW-1 fluid. Otherwise, regular fluid changes following the MM system is all that is required.
Old 11-12-2012, 09:44 PM   #5
speedlever
speedlever's Avatar
Ditto what Ian said about changing the rear diff fluid... VTM-4 fluid only. My understanding is that you can get a growling noise if the fluid is dirty or contaminated.
Gouranga, it would probably be a good idea for you to do a complete fluid and filter service to your RL to establish your maintenance baseline. Do you plan to use the MM for your maintenance events?
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is offline   Reply With Quote
Tags
chassis , differential , steering wheel , transfer case
Rear differential oil Tripmaker Under The Hood / Performance 79 06-26-2012 10:23 AM
rear differential change prospector Under The Hood / Performance 9 07-28-2011 09:27 PM
Rear Differential Failure BengalRidge Problems & Issues 37 09-22-2008 06:33 AM
Replacing the Rear Differential jz85 Problems & Issues 10 11-17-2007 11:53 AM
Steering wheel sounds like a toad is stuck in truck UglyDuck Miscellaneous/General Honda Ridgeline Discussions 2 05-09-2006 11:08 AM
