Whine from engine - Page 2 - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Under The Hood / Performance
Old 11-13-2012, 12:07 PM   #11
IanRTL
Re: Whine from engine
Originally Posted by bbriscoe View Post
So just replace the PS fluid/resevior and I'm good? Or will I maybe need a new pump as well?
If you just replace the fluid and the reservoir, you will see a dramatic improvement. From there, if you suck out the reservoir with a turkey baster every 10-15k miles and fill with fresh fluid, you should never have another issue. There was a thread on here about a TSB concerning a rubber o-ring on the end of the PS fluid feed tube. If there was whining going on, replacing this o-ring would solve it. Don't know if that would be an issue as well for you, but you should certainly start with the fluid and reservoir replacement.
Westin chrome tube steps, AVS vent visors, AVS bug shield, bed extender, carpeted trunk mat, blue LED interior switches, LED interior/exterior lights, Weathertech floor mats, Extang Trifecta soft tonneau cover, 5000k headlight bulbs, Pioneer AVH-P4400BH bypassed head unit, Metra Axxess ASWC, Jensen Carbon 65C components, Jensen Power 400 2ch bridged amp, 10" Boss Onyx shallow sub in custom behind-seat enclosure, FatMat sound deadening, Koolertron backup camera
IanRTL is offline   Reply With Quote
Old 11-13-2012, 06:56 PM   #12
bbriscoe
Steel Blue / Gray
Thanks, any good links to how to change the PS fluid? I found an old thread, but the pics had been removed from flickr.
bbriscoe is offline   Reply With Quote
Old 11-13-2012, 08:39 PM   #13
IanRTL
I wasn't able to locate the thread with the instructions from the service manual. If you PM speedlever, I'm sure he wouldn't mind getting them for you.
Old 11-13-2012, 09:15 PM   #14
speedlever
speedlever's Avatar
The most difficult part of changing the PS fluid is figuring out how to get the reservoir out of where it's mounted... Assuming you intend to change out the reservoir (~$20).
I posted a thread on it here with the FSM procedure and some pics of my process using a Mityvac. It has to be one of the easiest fluid changes on the RL.
I think it's best to elevate the front of the truck so you can crank the wheel without stressing the steering components.
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is offline   Reply With Quote
Old 11-14-2012, 02:52 PM   #15
Rickman
2007 *Former Ridgeline Owner
Rickman's Avatar
Talking Re: Whine from engine
Way ahead of you boys. See below!
Originally Posted by rollinhonda View Post
I suggest the next time you drive the truck, make sure all the doors are locked.
Make sure to only unlock your door. Quickly enter vehicle, locking doors immediately after seated. Fasten your seat belt and be on your way!
Whining stopped, right?
Originally Posted by Elkhunter View Post
Ejector seat accessory works well too
Leather, Navigation & Moonroof > 245/70 17 Toyo "Open Country" A/T Boots! OEM Steelies 245/70 17 Winter Boots!
My other ride is my Bicycle!
Rickman is offline   Reply With Quote
Whine in Transmission QCRidge Problems & Issues 57 09-04-2012 09:02 AM
High-pitch whine coming from engine Tcape Problems & Issues 9 03-31-2011 08:04 PM
Altenator whine?? DLIT Mobile Electronics 18 11-24-2009 10:33 AM
A little Odyssey whine... NJ RTL Other Cars, Trucks and Bikes 2 01-26-2009 06:31 PM
Whine, Whine & More Whine From Fans Gbenz Dear Honda: (Feedback Forum) 9 10-22-2007 07:45 AM
