Installing Brake Override Bypass on Pioneer 8400bh? - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Mobile Electronics
Old 11-26-2012, 05:14 PM   #1
lepack
2012 SPORT
Formal Black
lepack's Avatar
Quick question for you guys. I'm in the process of installing a Parking Brake Override Bypass (Amazon) on my Pioneer 8400bh and my question is do I still need to tap into the actual parking brake cable (green-orange), or does the bypass negate having to do that. Thanks.
lepack is offline   Reply With Quote
Old 11-26-2012, 07:37 PM   #2
ninjakris
2010 RTL
Re: Installing Brake Override Bypass on Pioneer 8400bh?
short answer, yes.
I have done around 6 pioneer double din stereo installs and while I usually use a simple relay from radio shack, i think the product amazon sells is pretty much the same thing. It somehow tricks the parking brake to get a signal a split second after the radio itself gets power. It should be pretty straight foward. Here is the video that explains it a little better than I can
ninjakris is offline   Reply With Quote
Old 11-26-2012, 08:48 PM   #3
kevin_stevens
Could I get the 25 word or less version of WTH a "Brake Override Bypass" is and why I'd want my stereo capable of it?!?
KeS
kevin_stevens is online now   Reply With Quote
Old 11-27-2012, 08:51 AM   #4
hessank
So you can watch a DVD while driving (the car is in motion). It is a safety feature to prevent the driver from the temptation of watching the screen when he/she should be looking ahead. However, on long trips it helps to keep the wifey engaged in watching a movie.
hessank is offline   Reply With Quote
Old 11-27-2012, 01:26 PM   #5
Deathdealer
2006 RT
Deathdealer's Avatar
why would you have to fool the parking brake? It doesnt care whether the radio is on or off.
You have to trick the radio...so the short answer is NO, you dont have to tap the parking brake cable...just need the relay to a hot source and it will trick the radio into thinking you have released the brake.
Deathdealer is offline   Reply With Quote
Old 11-27-2012, 01:49 PM   #6
Elkhunter
2007 RTS
Aberdeen Green Metallic
Elkhunter's Avatar
Thanks for clarifying. I wasn't sure what it was either.
Full Size Spare, USA-Spec iPod adaptor, Westin powder coated sidesteps, OEM tow hitch and harness, 2009 camera handle, Back-up camera, Dual input 3.6-inch Boyo Monitor (Second camera on rear of my teardrop trailer), Trunk carpet, Trunk dividers, Billet Grill, Infinity Reference 1031t Tweeters, Full-time power to front and rear 12V outlets, Fumoto oil drain valve, FIGS G2 hood prop kit. Rhino 360B Hitch step, OEM Rear Splashguards, 255/65/17 MS2's.
Elkhunter is online now   Reply With Quote
Old 11-29-2012, 10:55 AM   #7
lepack
2012 SPORT
Formal Black
lepack's Avatar
Originally Posted by ninjakris View Post
short answer, yes.
Thanks ninjakris. Different answer from Deathdealer. Makes logical sense to me to tap the brake wire on the HU but not on the truck itself. I'll try that first.
I temporarily connected the HU to a battery yesterday to play around with it and much of the visual stuff is tied to the parking brake being on to view the content. Seems to me like the bypass is a must for aftermarket HU's like this one.
Old 11-29-2012, 02:37 PM   #8
groupset
2006 RT
Billet Silver / Gray
I've done several installs of the Pioneer AVIC-series units; on those you simply pull an unused pin (usually the mute wire) from the original position on the Pioneer harness, then move it to a certain other position (depends on the AVIC model) and ground that wire along with the green parking brake wire off the Pioneer harness. This fools the unit into thinking it's in test mode, which frees up all capabilities of navigation; watching DVDs and video; etc. while the car is in motion.
groupset is offline   Reply With Quote
Old 11-30-2012, 04:50 AM   #9
hessank
No, it is not the radio you are trying to trick. It is the GPS function via the speed sensor. The speed sensor still tells the unit that you are moving even if it sees the parking brake as being off. In the Pioneer AVIC if it is not done correctly you will get a message actually telling you that your wiring was installed to fool the unit and it will not allow the DVD over-ride (ask me how I know). I have an AVIC3 installed in another car. You do what Groupset suggested and if you check on line it shows you how to swap the pins.
Old 12-04-2012, 02:02 PM   #10
lepack
2012 SPORT
Formal Black
lepack's Avatar
Bypass came in today. It's nice and small. Came with some detailed instructions too. Black to ground. Blue to remote wire, can still wire to amp if you've got one. Green to HU parking brake wire only, NO need to wire the actual brake wire with this bypass from microbypass.com (also sold on amazon). Detailed instruction attached.
Tags
2012 , brake override bypass , pioneer 8400bh , ridgeline
Parking Brake Bypass for Sony 660BT S2KILLA Mobile Electronics 19 03-20-2012 11:07 AM
Pioneer Parking Brake Bypass $10 + Shipping JadedSoulX Trading Post 2 03-13-2012 11:37 AM
Remote turn-on, amp, and parking brake bypass. hopper33 Mobile Electronics 3 03-23-2011 06:18 AM
AVHP3200DVD E-brake bypass Melvin8078 Mobile Electronics 1 04-15-2010 05:26 PM
Best location for installing prodigy Brake Controller Jeff Conrad Racks, Hitches & Towing 5 09-02-2007 10:57 AM
