#51 |
Aberdeen Green Metallic Join Date: Dec 2010
Re: How Long Will The OEM Battery Last
5 years and counting.....
![]() Full Size Spare, USA-Spec iPod adaptor, Westin powder coated sidesteps, OEM tow hitch and harness, 2009 camera handle, Back-up camera, Dual input 3.6-inch Boyo Monitor (Second camera on rear of my teardrop trailer), Trunk carpet, Trunk dividers, Billet Grill, Infinity Reference 1031t Tweeters, Full-time power to front and rear 12V outlets, Fumoto oil drain valve, FIGS G2 hood prop kit. Rhino 360B Hitch step, OEM Rear Splashguards, 255/65/17 MS2's. |
#52 |
Other Join Date: Jul 2009
Mine will be 7 years in January
#53 |
Billet Silver / Gray Join Date: Apr 2006
I just replaced my OEM battery the other day. It lasted 6yrs 9 months.
#54 |
Redrock Pearl / Beige Join Date: Oct 2012
Just a few questions:
Bought mine used and have no clue as to the age of the battery nor the conditions it was used in. Thinking about a replacement. A. What are the factory specs for the RL battery? CCA? etc.. B. For those that have replaced any recommendations? C. Advantages/disadvantages of 'overbuying' a battery with additional CCAs or warranty, etc...???
![]() Factory Equipment - Nav, AUX, Two-Tone Leather, Foglights, Tonneau Cover, Running Boards, Roof Rack, Mud Guards, Sunroof, Hitch, iVES, autodim compass mirror Mods - K & N Intake,15% Tint, LED Interior & Rear Plate, Stainless Cubby Cover, Pop N Lock, LED Strips, Weather Tech Side and Hood Air Deflectors, Chrome Mirror Covers, Chrome bull bar/skid plate, Chrome wheel skins, Hella Series 500 FF driving lights. FIGS hood struts Wishlist - Magnaflow Exhaust, Projector headlamps, LED Exterior |
#55 |
Here are the specs from the OM:
![]() Not much info as regards CCA and that sort of thing. I recently replaced my battery and just bought a WalMart Everstart Maxx 24FN for $85. http://www.ridgelineownersclub.com/f...8&postcount=38 I suggest that you find a way to keep power on the system while you change the battery so you don't lose your radio security code, tripmeter info, and other custom settings like your idle learn and ckp learn settings. I tried one of those $10 9v devices that plug in the acc socket, and even with the ignition in the ACC position (1), I lost my tripmeter info. I have no idea what else I lost. And it may not be a big deal at all. But rather than chance it, just keep power to it via a jumpstart pack and cable to plug into the OBD2 port or some have put a 9v battery across the battery cables successfully. |
#56 |
Nighthawk Black / Beige Join Date: Nov 2005
Original lasted almost 60 months and I am in Minnesota. My truck usually park inside most of the time. Just replaced it with a Costco brand. Make sure have the radio code handy after the battery replacement.
![]() Thanks from (AK786) -------------------------------------- 2006 Black Honda Ridgeline (RTS) |
#57 |
ROC Rank: 7k Comma Club
2010
Dark Cherry Pearl Join Date: Mar 2010
Don't worry about the rating too much. You can have one higher rated, which is probably better. I thought the stock was 550CA, but I could be wrong. Anything above that would be fine.
speedlever's battery is a good reference, and in fact likely a good choice. Most with the same ratings are the same battery with just a different label on it. Most are made by the same manufacturer. Last edited by rollinhonda; 12-10-2012 at 11:25 AM. |
#58 |
RTX
Formal Black Join Date: Jul 2007
5 1/2 Years on ours before replacement but lots of time outside and in cold weather.
#59 |
Billet Silver / Gray |
Long time owner and member here, but I haven't checked into the forums in months.
Just had to replace the OEM battery. 24 degrees F this morning and the first time ever the Ridgeline wouldn't start. So from March `05 to December `12 is 93 months and 98,000 miles. That's a pretty good battery.
The object to life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, with a big smile shouting, "Holy S#*t ...what a ride"! Last edited by steveberger; 12-26-2012 at 08:17 AM. |
#60 |
2012
RT
Polished Metal Metallic Join Date: Oct 2012
I went through three batteries in my old vehicle during the same mileage period. Florida heat is tough on batteries.
| how long till your original RL battery died? | daskraut | Under The Hood / Performance | 400 | 03-18-2013 10:24 AM |
| OK to use marine battery to replace OEM? | 2007ATLRTL | Under The Hood / Performance | 8 | 11-11-2011 11:45 PM |
| 2007 RTS, how long OEM batt warranty? | KKeppleRidge | Under The Hood / Performance | 3 | 01-27-2011 03:32 PM |
| Installed oem hitch and harness and battery died days later. | HRCNICK11 | Racks, Hitches & Towing | 19 | 05-08-2010 02:43 PM |
| how long do oem tires last? | jeelani | Tires, Wheels and Suspensions | 8 | 08-22-2009 11:38 PM |
