low brake pedal - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Under The Hood / Performance
Old 12-26-2012, 07:38 AM   #1
mrelmo
2007 RT
Billet Silver / Gray
low brake pedal
anyone have a real low brake pedal the dealer says it is low but can not find anything wrong, i was thinking about replacing all of the fluid as maybe there might be some air in the system, what kind of brake fluid do you need to use, does honda fluid make a difference thanks
mrelmo is offline   Reply With Quote Quick reply to this message
Old 12-26-2012, 08:34 AM   #2
larryr
ROC Rank: 3k Comma Club
2009 *Former Ridgeline Owner
White / Beige
larryr's Avatar
Re: low brake pedal
Any DOT 3 Fresh brake fluid is ok - I used Prestone from Walmart.
The honda brakes are not a closed system and absorbs water from the air - that is why you have to replace all the fluid every 3 years.
The harbor freight brake bleeder is wonderful http://www.harborfreight.com/automot...der-92924.html
I just put the opened can upside down in the brake reservoir and let the vacuum remove the old fluid. Do not let the reservoir get too low. You are done with each wheel when the fluid color changes. (it will).
figure 1 small can for each wheel or 1 big an 1 small to do all 4.
2013 Honda CR-V Polished Metalic EX-L with Navi.
The 199 fill ups on my 2009 Ridgeline with 20.6 MPG and over 60,000 miles driven- I just had 8 wonderful years in the Ridgeline but the Electronics are too many generations behind.
larryr is offline   Reply With Quote Quick reply to this message
Old 12-26-2012, 11:33 AM   #3
mrelmo
2007 RT
Re: low brake pedal
will the moisture cause a low pedal
Old 12-26-2012, 12:55 PM   #4
Ourfarm09
2011 RTS
Bali Blue Pearl
Ourfarm09's Avatar
Re: low brake pedal
Not unless you have a lot of moisture and your are getting the brake fluid so hot that the water is boiling.
Most likely you have air in the system.
aka Ron
U.S. Army (retired) , ASE Certified
AVS ventvisors, ROC decal,
Ourfarm09 is offline   Reply With Quote Quick reply to this message
Old 12-26-2012, 04:37 PM   #5
speedlever
speedlever's Avatar
Re: low brake pedal
When you say low, does the pedal height increase if you pump the pedal?
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is offline   Reply With Quote Quick reply to this message
Old 12-26-2012, 06:23 PM   #6
mrelmo
2007 RT
Re: low brake pedal
i haven't tried pumping the brakes, its not mine so i will have to wait until tomorrow, if the pedal does come up does that indicate air, and if it does not come up then what, i always thought with air in the system the pedal would slowly sink lower or feel spongy but it is firm not spongy
Old 12-26-2012, 06:54 PM   #7
speedlever
speedlever's Avatar
Re: low brake pedal
Your understanding is the same as mine. If the brake fluid has never been changed, that would be a good place to start. Also check the brake pad wear. If both of those check good, I have to question the master cylinder.
Here are a couple of links that may help:
http://www.agcoauto.com/content/news/p2_articleid/265
http://www.agcoauto.com/content/news/p2_articleid/266
Old 12-26-2012, 06:59 PM   #8
mrelmo
2007 RT
Re: low brake pedal
pads are 1 year old, i was afraid that it might be pointing to a master cylinder issue, those 2 articles are pretty extensive, after reading them i question doing brake jobs any more LOL
Old 12-26-2012, 10:40 PM   #9
mrelmo
2007 RT
Re: low brake pedal
pumping the pedal does raise the pedal then lowers, so i will assume that there is air in the system some where correct
Old 12-27-2012, 04:41 AM   #10
speedlever
speedlever's Avatar
Re: low brake pedal
That seems a logical conclusion to draw. My suggestion would be to replace the brake fluid and see if that corrects the issue. Then go from there.
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Honda Ridgeline Owners Club Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Model Year
What year is your Ridgeline?
Model
What model Ridgeline do you drive?
Color
What color is your Ridgeline?
Can you spell?
What letter in the alphabet is the fifth character of the word "Honda Ridgeline"
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
Spongy Brake Pedal Wiretap Problems & Issues 17 05-18-2015 05:17 PM
squishy brake pedal thefinks13 Problems & Issues 27 03-24-2010 06:23 PM
brake pedal travel nochangeofseasons Under The Hood / Performance 3 03-05-2009 10:44 PM
Altering Parking Brake Pedal BillB Interior 11 08-07-2005 02:29 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
