#21 |
Nimbus Gray Metallic Join Date: Dec 2009
Re: Do 08 or above RL have #4 cylinder issue?
Don't really know. I just use the one that fits.
Westin chrome tube steps, AVS vent visors, AVS bug shield, bed extender, carpeted trunk mat, blue LED interior switches, LED interior/exterior lights, Weathertech floor mats, Extang Trifecta soft tonneau cover, 5000k headlight bulbs, Pioneer AVH-P4400BH bypassed head unit, Metra Axxess ASWC, Jensen Carbon 65C components, Jensen Power 400 2ch bridged amp, 10" Boss Onyx shallow sub in custom behind-seat enclosure, FatMat sound deadening, Koolertron backup camera |
#22 |
See? Now I gotta go pull out my allens and try them to get the right size. Told you it wuz gonna take me at least 15 minutes to find the right tools. Sheesh.
#23 | |
Dark Cherry Pearl Join Date: Sep 2012
#24 |
My understanding is that the heat of combustion leaking past the loose plug destroys the plug (and parts fall inside the cylinder) and the heat will likely damage the coil pack. Although that last will be minor in the scheme of things.
#25 | |
#26 | |
I pulled a few plugs from the front bank awhile back. Probably around 150K or so. I just did it to check them out to see if the plugs appeared worn. I was very surprised to find the middle plug on the front VERY loose. I had the ratchet on it, but I bet I could of backed it out by hand. I didnt give it a thought...the plugs looked good, so I put them back in (did not torque with wrench) and planned to check them again at 200K. Now Im thinking I should at least put the torque wrench on it. I just always thought "goot-n-tight" was the proper spec for spark plugs.
#27 |
Aluminum heads and too tight could = stripped spark plug threads. I do NOT wanna go there.
Just remember no anti-seize on the NGK plugs. Very interesting that you found cylinder 5 with a relatively loose spark plug. |
#28 | |
I did NOT put anti-seize on when I put them back in. |
#29 |
No, I don't believe reinstalling old plugs with AS was ever resolved. I don't know if the NGKs are a use once and toss or just what.
#30 |
I wouldn't use the AS on the plugs at all - new or old. And I would totally recommend using the torque wrench. As I said, I always thought "good and tight" was the rule with plugs, too. I tightened mine by hand the first time and when I checked them 10k later, they were ALL loose. I used the torque wrench and 13 lb./ft. is certainly tighter than what I did the first time. Too tight is probably just as bad as too loose, though. Use a wrench!
| Cylinder 4/head gasket issue thread | speedlever | Problems & Issues | 66 | 04-25-2013 07:26 PM |
| Oil in cylinder #4 | garyelesys | Problems & Issues | 81 | 07-16-2012 09:57 PM |
| oil in cylinder | dukie2430 | Problems & Issues | 21 | 09-27-2011 04:13 PM |
| Misfire #3 Cylinder | soultrain | Northwest Ridgeline Owners | 8 | 07-21-2009 05:35 PM |
| light on RTL passenger climate control knob - minor issue (possible non-issue) | kuapao | Problems & Issues | 8 | 09-09-2007 07:20 PM |
