#11 | |
Dark Cherry Pearl Join Date: Sep 2012
Re: Consumer Reports vs Blown Cooler Line Reports
#12 | |
RT
Formal Black Join Date: Dec 2012
#13 | |
*Former Ridgeline Owner
Nimbus Gray Metallic Join Date: Sep 2010
Leather, Navigation & Moonroof > 245/70 17 Toyo "Open Country" A/T Boots! OEM Steelies 245/70 17 Winter Boots!![]() My other ride is my Bicycle! |
#14 |
Yea...things are tight down there, but it looks like an easy job to just pull the radiator. I would be willing to pull it and change the washers if possible. That would save some cash.
#15 | |
ROC Rank: Senior
2010
Dark Cherry Pearl Join Date: Feb 2009
From memory I think the fittings hold a cooling tank for trans fluid inside the radiator.
I have(HAD) an '07 Tundra Why am I checking up on Ridgelines? 'Cuz I bought a DCP RTL 6/29/10 |
#16 |
Thanks Rich! Someone had noted in a differnet thread that you must remove one fitting at a time so the coooler does not disconnect from the radiator. Im going to give the washer replacement a try. Im going to try and put it off until 200K. Im at 157 now, so I will probably hit 200 late this year.
#17 |
RT
Billet Silver / Gray Join Date: Sep 2011
Hey yall.... What i did to my RL....is just bypassed the radiator. Ive seen one other RL just recently with a mix of atf and coolant. (Internal leak in radiator) so what i did was unhooked my feed line that runs into my radiator and run it straight to my cooler. Capped off the ends on the radiator. Simple as that. Vehicle runs great. Does not make a difference with colder trans fluid. It warms as u drive. That way if my RL gets an internal leak...no mix fluids...just new radiator. Thus eliminating completely the chance of both fluids mixing. I kno pilots are having alot more of this issue.
#18 | |
2012
Crystal Black Pearl Join Date: Aug 2012
CR base their ratings on the number of survey received, whether it is 10 or 10,000... so it is really biased, and does not really give the real picture! I stopped taking CR ratings seriously, long ago! There is no better place to really find out what is real, not guess work than in a Forum like this one; and not assumptions based on a few surveys/polls! . Last edited by mtb; 01-18-2013 at 10:40 AM. |
#19 | |
RT
Billet Silver / Gray Join Date: Dec 2012
According to Consumer Reports they require a minimum of around 100 cars to publish reliability information for a model in a given year. Quote "Our statisticians have determined that a minimum sample of 100 is sufficient to allow us to report statistically-meaningful differences among models..." If they don't have the minimum sample size for a given model in a given year they will say no reliability information is available. So, assuming one believes what CR has put in writing they may have received and analyzed, at the very minimum, 600 or so surveys on the Ridgeline (based on model years 2006-11). More information on CR's rating methods can be found here.. http://www.consumerreports.org/cro/2...ginMethod=auto |
#20 |
RT
For what it's worth, here's the CR Report. Doesn't get much better.
(I don't know what's up with the fuel system on the 2012's, but I guess that's another subject and story...) |
| Transmission Line Pulled/Blown From Cooler!?! | hotrunner | Under The Hood / Performance | 12 | 02-26-2012 03:30 PM |
| '09 Ridge Consumer Reports Bottom Line Price | KrisRidge | Shoppin' and Test Drivin' | 4 | 05-29-2009 10:59 PM |
| Another review from consumer Reports | FredMez | Reviews | 12 | 02-22-2006 10:14 AM |
| Consumer Reports | 12VoltRidgeline | Miscellaneous/General Honda Ridgeline Discussions | 1 | 06-04-2005 11:30 AM |
| Consumer Reports | maybearidge | Shoppin' and Test Drivin' | 7 | 05-18-2005 08:54 AM |
