I'm sorry if this has been discussed previously as I did try searching...
Does anyone have a wiring diagram that shows where the front door speakers and the dash tweeters tie in to each other? I am installing some component speakers into my brand new 2012 Sport, and I would like to use the factory wiring and install the external crossover where the factory wiring splits between the tweeters and the mids.
Here is a quick breakout of my audio upgrade which will be completed in a few days:
Also if anyone has any recommendations as where to mount the XM tuner close to the HU that would be helpful. I removed the center dash console and noticed some type of silver metal box with a large wiring harness connected to it that was mounted on the floor under and behind the center dash console (basically directly under the HU on the floor). I can try to post a pic of this if needed. I am wondering if it would be okay to mount my XM tuner on top of it as I can easily remove the left panel to access it without having to remove the instrument panel or any other large panels.
- Pioneer FH-P8000BT Double-Din In-Dash CD/MP3/WMA/AAC Receiver
- Pioneer GEX-P920XM XM Digital Satellite Tuner
- Metra Axxess ASWC Universal Steering Wheel Control Interface -- called and they said this will work
- Polk Audio DB6501 6.5-Inch 2-Way Component System --- front
- Polk Audio DB651s Slim-Mount 6.5-Inch Coaxial Speakers --- rear
