Spare tire and tools - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Exterior
Notices
Thread Tools Display Modes
Old 05-15-2005, 12:16 PM   #1
1sthonda
ROC Rank: Freshman
2006 RTL
Billet Silver / Gray
Question Spare tire and tools
I just pulled out the spare tire today to be a little nibby and noticed the case that holds the jack has 3 unused cut outs or I'm missing some parts, Has anyone checked there spare and tools that might be able to answer?
1sthonda is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-15-2005, 12:33 PM   #2
the kid
ROC Rank: Sophomore
Re: Spare tire and tools
There is nothing that comes there from the factory...think these may be things you can buy from the dealer...maybe touch up paint etc
the kid is offline   Reply With Quote
Old 05-15-2005, 06:25 PM   #3
shovelhd
ROC Rank: Comma Club HOF 10,000+
2006 RTL
Steel Blue / Gray
shovelhd's Avatar
I put my wheel lock key in one of these.
shovelhd is offline   Reply With Quote
Old 05-15-2005, 08:45 PM   #4
danimal
ROC Rank: Freshman
it's probably not a good idea to keep your wheel lock in such an easy to find location. it'd be too much of a pain in the butt to bring it in and out of the house every time i go for a drive, so i just find a good place to hide it within the car
danimal is offline   Reply With Quote
Old 05-16-2005, 12:55 AM   #5
WhiteRTLnav
ROC Rank: Junior
2006 RTL
White / Olive
Actually, as well-intended as wheel locks are, I have heard a NUMBER of stories where people with Honda, and other brand, wheel locks have been unable to get the key in the lock, or they have not been able to remove the lock due to corrosion. Just something to keep in mind... Imagine having a flat and being unable to remove the wheel due to corrosion, etc??? I'm a big fan of wheel locks and Honda accessories, but it may be worthwhile considering a different style of wheel lock in which corrosion will not be an issue.
WhiteRTLnav is offline   Reply With Quote
Old 05-16-2005, 05:54 AM   #6
shovelhd
2006 RTL
Steel Blue / Gray
shovelhd's Avatar
It's a locked location so it's secure. And I put teflon anti-seize on the studs/bolts as part of my normal tire rotation. No problems yet.
Old 05-16-2005, 09:05 AM   #7
nwdiver
ROC Rank: Sophomore
2006 RTS
I bought the wheel locks from H&A and the directions in the package mentions that the tool assembly has a space just for it in the styrofoam. It also comes with a zip tie and recommends that it could alternately be zip tied to the lug nut wrench. I also noticed something that I think says alot about the stability of the RL--I put some tie down straps on the little shelf in the trunk and even with all the jostling and short stops etc., they stayed right where I put them. Kinda cool.
I drive a Honda and push one too.
nwdiver is offline   Reply With Quote
Old 05-16-2005, 10:46 AM   #8
shingles
ROC Rank: Senior
This can happy with any wheel locks. If you damage it the key might not fit. The corrosion is likely on the lug stud itself so any lock could have this problem as well.
shingles is offline   Reply With Quote
Old 05-16-2005, 03:08 PM   #9
TacomaDCLB
ROC Rank: Freshman
If they want your wheel bad enough theyll take it.
I took off a set of locks using an electric impact wrench and a socket that was just a hair too small to fit entirely over the lock itself. Just took a hammer and pounded the socket on the lock, attached the impact wrench to the socket, and out it came...
TacomaDCLB is offline   Reply With Quote
Old 05-16-2005, 04:40 PM   #10
nwdiver
ROC Rank: Sophomore
2006 RTS
It's just a deterrent to the casual thief/vandal. If they want your truck they'll take that too or they might even part it out on the spot!
Sponsored Links
Advertisement
BB code is On
Forum Jump
