Transmission Seal - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 10-04-2006, 10:30 PM   #1
chunjin
ROC Rank: Freshman
2007 RTS
Nimbus Gray Metallic
Transmission Seal
Has anyone had a problem with internal transmission seals that cause a noticable fluid leak? I have a 2007 RTS with 600 miles that has now been at the dealership for 3 days. They first thought that it was a pinched o-ring on the drain plug but after fixing that they realized that the fluid was coming from somewhere else.
It still had plenty of fluid in it when I took it in but does anyone think that the transmission could have been damaged from the leaking internal seal?
chunjin is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-04-2006, 10:44 PM   #2
MikeT
Mall Ninja Moderator
2006 RTL
Billet Silver / Gray
MikeT's Avatar
Re: Transmission Seal
You might have a leak between the Torque Converter and the transmission at the Tourqe Converter Input Seal. If you look at the bottom of the engine / transaxle, you will see a smallish black plate that is held on by two 10mm bolts. If your leak is coming from there, you might need to have the TCI seal replaced. This happened to me at 5k. Try reading my earlier thread at http://www.ridgelineownersclub.com/f...t=transmission
2006 Ridgeline RTL, Silver with roofrack.
2000 Accord V6 EX, White no roofrack.
MikeT is offline   Reply With Quote
Old 10-04-2006, 11:09 PM   #3
chunjin
ROC Rank: Freshman
2007 RTS
Thanks Mike, I will give the Dealer a call tomorrow and ask some additional questions.
2007 Nimbus Gray RTS
Sponsored Links
Advertisement
BB code is On
Forum Jump
