First Oil Change - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Under The Hood / Performance
Notices
Thread Tools Display Modes
Old 12-17-2006, 08:25 AM   #1
AZZX
ROC Rank: Freshman
2007 RTL
Nimbus Gray Metallic
AZZX's Avatar
First Oil Change
I know Honda requires the first oil change to be done @ 5000 miles,
currently i have 2900 miles and planning a long trip for the holidays which will add another 3000 miles.
can i change the oil now? from your experience will this cause any problems?
thanks
2007 RTL with Navi, Tow Pckg, G-Tech grill/brush guard, Westin Nerf Bars, OEM Hood and Moonroof Deflectors, Roof Rack, OEM Door Moldings, Backup Camera, Tonneau Cover, ScanGauage II. Westin rear bumper gaurd.
AZZX is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-17-2006, 09:18 AM   #2
dk miller
ROC Rank: Senior
2007 RTX
Dark Cherry Pearl
dk miller's Avatar
Re: First Oil Change
Actually I think Honda recommends that you go by the OLM for oil changes. Depending on your driving routine this seems to be about 6 - 7K. Long highway trips are mild service that produce very little if any oil contamination.
I think you are good to go but if it gives you peace of mind go ahead and change your oil, it won't hurt anything.
dk miller is offline   Reply With Quote
Old 12-17-2006, 11:38 AM   #3
shortspark
ROC Rank: 1k Comma Club
2006 RTL
Billet Silver / Gray
That will give you 6000 miles on the truck after your trip. That is about when most people see the OLM click in at 15% oil life expectancy and the service due notice. With your highway driving, I bet when you return the OLM will still not be at 15%. Even if it is or below that, just change it when you return. You really don't get into trouble until the "0" shows up and warns you service is past due. I don't know anyone at this forum that has shown a "0" on the OLM in less than 6000 miles.
shortspark is offline   Reply With Quote
Old 12-17-2006, 12:02 PM   #4
Lingered_I
ROC Rank: 2k Comma Club
2006 RTL
Nighthawk Black / Beige
Lingered_I's Avatar
For the first oil change I would wait for the OLM. The oil in your engine right now has a very high moly content which Honda deem to be necessary while the engine is breaking in. Leave it in there as long as possible is my advice.
Lingered_I is offline   Reply With Quote
Old 12-17-2006, 12:52 PM   #5
basils
ROC Rank: Senior
2006 RT
I am of the opinion that 5k miles would be a good compromise for those (like me) feeling a tad anxious about leaving the factory oil in for the full OLM. It's true that it has a high moly content and this may be critical for proper break-in (according to Honda), but at 5k no appreciable break-in will still be occuring (my opinion). I used a high moly synthetic as my second fill at 5k miles. I've had my Ridge a year and a half and it runs as smooth as glass, with zero oil burning between changes. I now do a 6 month oci regardless of miles driven.
"The name of American which belongs to you, in your natural capacity, must always exult the just pride of nationalism." -George Washington
basils is offline   Reply With Quote
Old 12-17-2006, 05:09 PM   #6
geneb13
ROC Rank: Freshman
2007 RTX
Formal Black
I just changed mine last week. The meter said 15% and it was 6200 miles. The local dealership gave me the riot act about the engine is not better and the oil is not better, so why wait until 6-k or more. I have had my RTX for 2 months and already have 7-k on it. So I am changing my oil according the the meter. I drive for business at least 2500 per month. I did spring for the 7500 mile maintenance while I was there.
geneb13 is offline   Reply With Quote
Old 12-17-2006, 06:46 PM   #7
CBRidgeJockey
ROC Rank: Senior
2006 RTL
CBRidgeJockey's Avatar
I took mine from Edmonton to Vancouver with only 1500km on the OD. I checked it after I arrived and it needed a litre. Make sure you check your oil before and after your trip.... my Ridge ate only 1 litre during the breakin....I have 20,000 KM now and she hasn't touched a drop....
Silver EX-L w/MR]Full nose bra, Moonroof deflector, Rear mud guards, Body side moulding, Block heater, locking lug nuts. Cargo net...
CBRidgeJockey is offline   Reply With Quote
Old 12-18-2006, 07:27 AM   #8
BillB
2008 RTS
Steel Blue / Gray
BillB's Avatar
Considering there is no such thing as a 7500 mile service for the Ridgeline, your dealer found a way to rip you off even though you didn't fall for the 3000 mile oil change BS most of tem like to try and dell.
BillB is offline   Reply With Quote
Old 12-20-2006, 02:36 PM   #9
RidgeLI
ROC Rank: Senior
2011 RTL
Polished Metal Metallic
RidgeLI's Avatar
First oil change.......is the OLM the only way to go?
I changed my oil the first time at 2,300 miles as I had the truck 6 months, drove 5 miles each way per day, only local during this time, and no highway driving.
I believe that the OLM was on 40% at that time, but felt that after 5 months it was time to change the oil. I never let my cars go beyond 6 months when I do not hit max. mileage, especially with all of the local driving I do. I used syn oil and went on a rode trip during this period.
I know the computer should be followed but time is also important to consider. I think that the OLM does incrementally consider time, but possibly relies on mileage as the deciding factor; possibly 70% of the deciding factor?
The second oil change at 6,400 miles was performed as I had oil in the truck for seven months and only 4,000 miles on it, again local driving. I used syn oil again.
Some say that was wrong to do, only follow the OLM, especially with the break-in oil in it. Others say as long at you get pass the crucial 600 miles, and preferably to 3,000 miles it is ok. I changed the oil to remove the micro metal shavings present in new engines and the combustion by-products, acids etc. that are created. While the oil probably had more "life" in it, time to me was important factor to consider as well.
How important is time in relation to mileage, clarity please.
RidgeLI
RidgeLI is offline   Reply With Quote
Sponsored Links
Advertisement
BB code is On
Forum Jump
Oil Change Interval - time or mileage? shortspark Under The Hood / Performance 21 08-19-2009 11:40 PM
First Oil Change / Better Gas Mileage? WhiteRL Fuel Economy and Gas Related Discussion 21 02-27-2008 09:00 PM
Confusion about Oil Change Intervals wv ridgeline Under The Hood / Performance 18 02-26-2007 03:50 PM
Before You Change Your Oil.................. FoxyRL Under The Hood / Performance 10 12-25-2006 11:08 AM
What does your dealer charge for an oil change? chisoxjim Miscellaneous/General Honda Ridgeline Discussions 27 11-29-2006 10:32 PM
