Fiberglass snow plows - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Accessories
Notices
Thread Tools Display Modes
Old 02-16-2007, 06:36 PM   #1
VRidgeline
ROC Rank: Freshman
2007 RTS
Steel Blue Metallic
Has anyone heard or have such a thing, if so please give me give feedback.
VRidgeline is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-16-2007, 07:24 PM   #2
qlake
ROC Rank: Junior
2007 RTL
Steel Blue / Gray
qlake's Avatar
Re: Fiberglass snow plows
I have not heard of fiberglass but I have used a lexan plow and liked it.
qlake is offline   Reply With Quote Quick reply to this message
Old 02-17-2007, 07:15 AM   #3
VRidgeline
ROC Rank: Freshman
2007 RTS
Steel Blue Metallic
Whats Lexan? and any pics
Old 02-17-2007, 07:52 AM   #4
oldcoastie
ROC Rank: Senior
2007 RTS
Dark Cherry Pearl
oldcoastie's Avatar
A neighbor uses a lexan, and it's just as heavy as the steel plow.
oldcoastie is offline   Reply With Quote Quick reply to this message
Old 02-17-2007, 08:16 AM   #5
Pug
ROC Rank: 3k Comma Club
2006 RTL
Billet Silver / Gray
Pug's Avatar
"Lexan" is General Electric's brand name for polycarbonate (PC) - a clear (in it's "natural state") thermoplastic resin that can be heated/molded into a wide variety of products. Polycarbonate sheets are available for glazing (windows) and sunglass/safety lenses are made of PC because of the high impact properties inherent in the resin.
I've used injection and blowmolding grade PC's to make parts for electronics industries, for medical devices, containers, and just about anything you can think of that requires a part designed to be structurally and chemically tough.
Heck! I've even made snow-shovel blades from the stuff! (in a "sampling" scenario).
I've been using one of the discolored "rejects" from that sample run for over twenty years! Had to replace the wooden handle once, but the Lexan "scoop" is as tough as the day I first used it.
The plastic snow-shovels you usually see have polypropylene blades that are much lighter and more flexible than PC. More "cost-effective" to produce, as well.
There are various "fillers" that can be added to the resin to increase certain properties, too. Glassfiber-filled PC's, in my opinion, are some of the toughest materials known, that can be easily molded into any shape.
A fiberglas plow? Seems plausible, but it would probably need reinforcement of some kind to give it added rigidity. And it would require some type of filler to allow it to remain a bit flexible at the low temps encountered while using it.
Personally, I'd stick with the metal plow. Other than the reduction in weight, what advantages would you expect from a plastic plow?
Pug is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Ridgeline + Blizzak DM-Z3 = Snow King TeamRidgeline Tires, Wheels and Suspensions 16 10-14-2008 08:52 AM
All New -SnowSport 180 Personal Utility Snow Plows realridgeline Exterior 9 10-17-2006 02:21 PM
Impressions after driving in our first snow. nevadagarth Miscellaneous/General Honda Ridgeline Discussions 4 12-19-2005 01:41 PM
Snow tires for RL hankim Tires, Wheels and Suspensions 21 12-12-2005 01:28 PM
Snow Bear plows gmtorque Miscellaneous/General Honda Ridgeline Discussions 1 03-19-2005 10:49 AM
