VTM-4 Fluid Change - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Mods, Installs and How-To's
Notices
Thread Tools Display Modes
Old 12-28-2007, 10:12 PM   #1
Cmotley
ROC Rank: Freshman
VTM-4 Fluid Change
VTM-4 Fluid Change
I hope these pictures help if you decide to change your VTM-4 fluid. I purchased the VTM-4 Fluid and two crush washers from the dealer; they are not available from Auto Zone. You will also need the following items; a 3/8" socket and extender, 6' of 5/8" x 1/2" plastic tubing and a funnel.
Step 1 Loosen the top plug first and then remove the bottom drain plug.
Step 2 Drain the fluid.
Step 3 Open the trunk hatch and remove the drain plug. Push the tubing through the drain plug. Now feed the plastic tube into the top plug. Close and tighten the bottom drain plug and crush ring.
The view from underneath shows the path of the tube and if run correctly the tube will not pull out.
Step 4 Pour the fluid into the funnel and fill until the fluid seeps out of the top plug. (See below)
Step 5 Re-install the top plug and crush ring.
Cmotley is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-28-2007, 10:32 PM   #2
franc944
ROC Rank: Senior
2006 RTL
Billet Silver Metallic
franc944's Avatar
Send a message via AIM to franc944
Re: VTM-4 Fluid Change
So that's what the trunk drain plug is for!
Genius!
2006 Silver RTL Navi, rear camera, oem step tubes, oem bug deflector, oem bed extender, and eBay 4 piece grill insert.
franc944 is offline   Reply With Quote Quick reply to this message
Old 12-28-2007, 10:42 PM   #3
MikeT
Mall Ninja Moderator
2006 RTL
Billet Silver / Gray
MikeT's Avatar
Originally Posted by Cmotley View Post
VTM-4 Fluid Change
Attachment 27126
Is it just me or does it look like a right side halfshaft seal is leaking?
I had mine replaced back in the first year of ownership.
2006 Ridgeline RTL, Silver with roofrack.
2000 Accord V6 EX, White no roofrack.
MikeT is offline   Reply With Quote Quick reply to this message
Old 12-28-2007, 10:43 PM   #4
weatherman
ROC Rank: Junior
2006 RTS
Nighthawk Black / Beige
weatherman's Avatar
cmotley,
does the rear differential hold the entire gallon of fluid? are the crush washers the same ones used for a motor oil change? where do you get the plastic tubing? thanks for the info and great pictures.
'06 Nighthawk Black Pearl RTS, with 16 mods and plenty of chrome.
'15 White Diamond Pearl Odyssey EX-L. Wife's ride
'92 Corvette LT1 coupe - fun, fun, fun!!
'00 Toyota Camry - boring (kids car)
weatherman is offline   Reply With Quote Quick reply to this message
Old 12-29-2007, 03:57 AM   #5
Six Rails
ROC Rank: Junior
2007 RTL
Formal Black
Six Rails's Avatar
What is the recommendation from Honda on the VTM - 4 change is it a mileage point ? or is it like oil so many miles or so many months.
ROC on Kevin
2003 Honda Pilot (Wifes Loaded)
2001 Honda Accord (Son's)
2000 Honda Civic (Daughter's)
Six Rails is offline   Reply With Quote Quick reply to this message
Old 12-29-2007, 06:26 AM   #6
Cmotley
ROC Rank: Freshman
The idea to use the "trunk drain" was posted in a earlier post by eurban, I simply supplied the photos. But like him, I had an awful time pumping the VTM fluid from the ground and pushing it in the rear differential. (It's really hard when it's cold and the cheap hose kinks)
Each time I changed the VTM fluid I used about 75 - 80% of the product they sold me. I followed the maintenance minder and change the VTM Fluid accordingly. The first change came at about 13,500 miles and my second was done at nearly 38,000. The hose was $3 from Lowes.
Old 12-30-2007, 04:09 PM   #7
shovelhd
ROC Rank: Comma Club HOF 10,000+
2006 RTL
Steel Blue / Gray
shovelhd's Avatar
I never tried this method but it sure looks interesting. I just jack it up and slide the bottle between the trunk and the A-arm.
Shovelhd media installation thread
Kenwood DDX8019*Garmin KNA-G510 Nav 2009 Maps*KCA-BT200 Bluetooth*KTC-HR100 HD Radio Tuner*KTC-V500N TV Tuner (RIP)*KCA-iP200 iPod Adapter*SIR-KEN1 Sirius Satellite Radio Tuner with Lifetime Subscription*Webb OEM XM Antenna Conversion*PPI DCX-730 DSP*Eclipse XA4000 Mains Amp*Rockford-Fosgate T1500bd Sub Amp*Rainbow SLC 265 Front Components*Rainbow 165 SL Rear Coaxials*(2) Diamond Audio D610D4 Subs in Custom Subthump Box*KP Technologies Rollup Modules
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
shovelhd is offline   Reply With Quote Quick reply to this message
Old 12-30-2007, 05:47 PM   #8
ssg
ROC Rank: Senior
2014 SE
Alabaster Silver Metallic
ssg's Avatar
I took the old bottle of vtm4 fluid and put a brass 5/8" hose connector through it and attached a fluid pump, but had I thought of that darned trunk plug life would have been much easier, thanks for the photos
Also when it's nearly done draining I give a few 'tips' of fresh fluid in there to hopefully wash out any of the old that's hanging around...never a bad idea I guess.
ssg is offline   Reply With Quote Quick reply to this message
Old 01-02-2008, 08:28 AM   #9
zinger084
ROC Rank: Freshman
2007 RTL
Formal Black
... found the answer in another thread...
zinger084 is offline   Reply With Quote Quick reply to this message
Old 01-06-2008, 06:45 PM   #10
MyRTS
ROC Rank: Freshman
2007 RTS
Formal Black
Send a message via AIM to MyRTS
Thank you so much for the pictures along with the description. Last week the dealer was trying to sell me that service, now I can do it on my own ( saving some serious $$)
MyRTS is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your Ridgeline?
Model
What model Ridgeline do you drive?
Color
What color is your Ridgeline?
Can you spell?
What letter in the alphabet is the fifth character of the word "Honda Ridgeline"
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Differential Fluid Change jwizard Under The Hood / Performance 18 03-05-2014 06:01 AM
Observations on changing VTM4 fluid eurban Under The Hood / Performance 32 09-02-2011 02:04 PM
VTM4 differential fluid change Boreal Miscellaneous/General Honda Ridgeline Discussions 12 02-27-2010 02:29 PM
What Tools are needed for VTM-4 Fluid Change Joeyo Under The Hood / Performance 20 09-23-2008 10:45 AM
rear diff fluid change....waste of money? MikeFL Under The Hood / Performance 6 10-19-2006 02:30 PM
