Truxxx lift kit installer in SoCal? - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Activities > Off-Roading
Notices
Thread Tools Display Modes
Old 06-02-2008, 04:03 PM   #1
desertpenguin21
ROC Rank: Freshman
I called ahead to see if a local off-road shop that does a lot of lifts could do the install and for how much but was told most likely no, because they don't supply the kit and don't work on Honda's sooo.. I was wondering if anyone knows of a reputable place in SoCal who will install the lift kit? Also.. Which tires go best? General, Yokohama, there are so many and I probably will never *really* off-road, but don't want to keep the small tires on either. Thanks in advance for any help.
desertpenguin21 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-11-2008, 12:45 PM   #2
wagonator
ROC Rank: Freshman
Re: Truxxx lift kit installer in SoCal?
I got my kit installed on a grease monkey shop (I live in Mexico). You can try any Discount Tire Co. or Speedee or so; as the work involved is the same work required for a strut change, so any suspension / tire dealer should be able. Make sure they align properly. I have not changed yet my tires; It looks ridiculous with the stock ones I´m going to buy 255/75/17 BFGoodrich All Terrains; the best tire. I have AT's on my FJ Criuser and an old Wagoneer and work great on and off road. Good luck. Enjoy.
wagonator is offline   Reply With Quote
Old 07-09-2008, 08:30 PM   #3
alexander
ROC Rank: 1k Comma Club
alexander's Avatar
you should do this yourself, it's very simple with the right tools that will cost less than the install charge and you'll likely have enough left over for the alignment
alexander is offline   Reply With Quote
Old 07-16-2008, 06:58 PM   #4
Brad RTL
ROC Rank: Freshman
2008 RTL
Nimbus Gray Metallic
I am also looking into doing this install in my garage. What am I looking at as far as the install goes? Tools, tips, etc.?
Brad RTL is offline   Reply With Quote
Old 07-16-2008, 08:30 PM   #5
alexander
alexander's Avatar
2 ton jack 4 jack stands and a basic metric tool kit with a breaker bar
Old 07-16-2008, 09:17 PM   #6
ChrisM
Moderator
2006 RTL
Redrock Pearl / Beige
ChrisM's Avatar
You will need metric sockets up to 22 mm if you don't pull the axles. I didn't pull mine when I did it but the instructions say you are supposed to. IIRC the axle socket is either 28 or 32 mm. You can rent that socket from your local auto parts store if they do that sort of thing.
+1 on the breaker bar. It's mandatory. I'd also suggest a set of metric allen wrenches for the sway bar links. They fit in the bolt ends so that the sway bar link ends don't spin when you remove the nuts. A set runs about $5. You might also consider a 17 and 18 mm open ended wrench which is mandatory for getting the bottom bolt off of the front sway bar links. 17 takes off the OEMs and 18 puts the nuts back on the replacement aftermarket sway bar links.
2006 RTL w/o Navi & 2007 RTX
http://s101.photobucket.com/albums/m69/HondaRidgeline/
ChrisM is offline   Reply With Quote
Old 07-18-2008, 02:36 PM   #7
bbnmcas
ROC Rank: Junior
2006 RTL
Formal Black
bbnmcas's Avatar
I had wheel warehouse in Anaheim install mine. They charged me $400.
2006 Honda Ridgeline RTL
AEM Brute Force Intake, Sprint Booster, Truxxx Lift Kit, 265-70/17 Nitto Terra Grapplers, Hidden Hitch, 17" Black OEM Wheels, Altezza Taillights
bbnmcas is offline   Reply With Quote
Old 07-24-2008, 04:28 PM   #8
LunchTicket
ROC Rank: Freshman
2006 RTL
White / Beige
LunchTicket's Avatar
I did this myself and it was not easy if u dont have impact tools or not to sure of yourself. i would leave it up to the grease monkeys.
i was monkeying around with the rear set up for 1 hr till i realized you have to swap assy from rt to Lt.
LunchTicket is offline   Reply With Quote
Old 07-25-2008, 06:30 PM   #9
ChrisM
Moderator
2006 RTL
ChrisM's Avatar
All you have to do is rotate them 180 degrees around with the Truxx kit. There is no need to swap em' left to right.
Sponsored Links
Advertisement
BB code is On
Forum Jump
Definitive Lift Kit Thread toolz_not_toyz Accessories 347 12-27-2012 07:15 PM
2" Truxxx Lift Kit, 20" KMC Wheels, 305/50R20 Toyo A/T Open Country dgrace23 Tires, Wheels and Suspensions 36 06-01-2011 12:06 PM
Truxxx Lift Kit hsustaita Off-Roading 8 05-13-2008 01:14 PM
Hek of a deal IMO on the truxx lift kit , hurry if u r thinking of doing this upgrade madi05 Accessories 28 09-17-2007 06:30 AM
Warning - Truxx lift kit missing welds Whaleya Mods, Installs and How-To's 10 05-18-2007 04:02 PM
