Rear seat pivot support - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 07-23-2008, 08:06 AM   #1
toylman
ROC Rank: Freshman
2006 RTL
Steel Blue Metallic
I usually keep my rear seat locked up, but needed to use my truck like a car, so I put the seats down. The next day I went to lock them up again and the pivot arm on the right side (black horseshoe shaped bar) was sticking straight out. I read in some prior posts it was a plastic part that broke. I did take the seat apart and fixed it and the most difficult part was repairing the plastic pulley. Everything I touched was strong and high quality except this one part. I didn't attempt to buy a new one since it was stated that it was part of the seat frame (list price 210.) and not available separately. If it were, it would be a 2.-5. part. I can't see how this repair should cost as much as others said Honda charged them. At the worst it would be 2 hours for a Honda tech plus the frame. If you wanted to try yourself you need a 14mm socket/wrench, 10mm, phillips and a small putty knife to assist in trim removal. Start with the seat bottoms locked up. Remove the plastic trim parts at the bottom of the seat and floor, unbolt the 6 seat bolts, unbolt the seat belts to floor along with 2 phillip screws at the center, prop the seat assemble away from the bottom edge enough to access/unbolt the seat bottom hinges from the seat back. Remove the center hinge 10mm bolts which hold the 2 center hinges together, remove the trim parts covering the hinges, remove the 14mm bolts holding the side hinges to the seat back, remove the seat bottom to a work bench. You will see the plastic pulley, cracked down the center located in the inner hinge with the pivot cable attached to it. I made a large washer out of aluminum and using 4 very small nut/bolts sandwiched it to pulley. Of course you can come up with a different repair method that works, but forget about glue or using a soldering iron to mend it; not strong enough. This pulley should be metal due to the stress on it. After seeing how it works, I don't know why these parts are Not broken on every Ridgeline. I am now expecting the left side to break next.
toylman is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-23-2008, 08:08 AM   #2
shovelhd
ROC Rank: Comma Club HOF 10,000+
2006 RTL
Steel Blue / Gray
shovelhd's Avatar
Re: Rear seat pivot support
Pictures, please, of your fix.
Shovelhd media installation thread
Kenwood DDX8019*Garmin KNA-G510 Nav 2009 Maps*KCA-BT200 Bluetooth*KTC-HR100 HD Radio Tuner*KTC-V500N TV Tuner (RIP)*KCA-iP200 iPod Adapter*SIR-KEN1 Sirius Satellite Radio Tuner with Lifetime Subscription*Webb OEM XM Antenna Conversion*PPI DCX-730 DSP*Eclipse XA4000 Mains Amp*Rockford-Fosgate T1500bd Sub Amp*Rainbow SLC 265 Front Components*Rainbow 165 SL Rear Coaxials*(2) Diamond Audio D610D4 Subs in Custom Subthump Box*KP Technologies Rollup Modules
shovelhd is offline   Reply With Quote
Old 07-23-2008, 08:58 AM   #3
meanmachine19
ROC Rank: 3k Comma Club
2006 *Former Ridgeline Owner
Steel Blue / Gray
You may be able to buy individual parts. Check out HondaAutomotiveParts.com
meanmachine19@yahoo.com
2006 Ridge -Steel Blue RTL w/moonroof + various accessories
meanmachine19 is offline   Reply With Quote
Old 07-23-2008, 01:14 PM   #4
toylman
ROC Rank: Freshman
2006 RTL
Steel Blue Metallic
Doesn't show or list them on the exploded view. They are located in the inner metal hinge of the seat frames sandwitched between trim parts 2 & 4 for the right seat and 19 & 21 for the left seat.
Old 07-23-2008, 04:58 PM   #5
RustyH
ROC Rank: 4k Comma Club
2006 RTL
Nighthawk Black / Beige
RustyH's Avatar
Soon I hope to reinstall my rear seats, which were removed when I purchased my Ridgeline. The bottom seats are currently seperated, so I when the time comes, with your permission, I'll PM you about how you did this, the steps you took, ect. Thanks in advance.
Rusty
06 RTL, Polished Billet Grill, Custom paint, 275/45R/20 Yokohama Prada Spec-X on Rozzi Octane wheels. EBC Brakes and drilled rotors, custom airbag suspension. Kenwood DDX7017 DVD Player, Rockford Power T15004 Amplifier, Six Rockford Power 6.5" Front Speakers (3 Per Door), 2 10" downfiring subs under rear seat, Custom 3 color Wet Okle seat covers. Airraid CAI and throttle body spacer, Magnaflow Muffler, Truxedo Pro Tonneau Cover, Hidden Hitch, smoked headlights and taillights.
RustyH is offline   Reply With Quote
Old 07-25-2008, 09:17 AM   #6
toylman
ROC Rank: Freshman
2006 RTL
Steel Blue Metallic
Hello, I guess you see that the seat back just hangs on the 2 U shaped hooks near the head rests. I did drop the entire seat off the hooks and removed the small bottom only, but to remove one side it was unnecessary. To re-assemble the entire seat I would suggest you remove the seat back and lay it on a bench, back down. Next attach the seat bottoms. Lay the bottoms on the back and you will see where the hinges line up. The seat bottoms each have 2 separate side hinge brackets, but the center brackets which house the pivot pulleys touch each other and are bolted together with the 3 gold color 10mm bolts. The 2 screw holes are used later for the 2 phillip screws to the center double seat belt After the entire unit is bolted in. The seat back hinges are bolted with 2 x 14mm bolts at each one. Mount the trim covers over all the bottom hinges. If you get this far, you are almost home. Now you need 2 people to put the seat in and hang it in the holes; white plastic bushings go in the holes that the U hangers go in. Next use 6 x 14mm bolts to secure the seat to the truck interior. Next are the seat belt brackets all mounted with 14mm bolts; center is the double with bolts and 2 phillip screws to the bottom hinge, center belt. Last is 4 pieces of bottom trim. Try to use the exploded parts view on the previous reply to the post. Sorry I did not take any pics. Good luck, Lenny
Old 07-26-2008, 04:01 PM   #7
Hooha12
ROC Rank: Freshman
2006 RTL
Billet Silver / Gray
Hooha12's Avatar
Mine broke today. My truck is still under warranty so I will let Honda fix mine.
That's just my opinion . . . . . I could be wrong.
Hooha12 is offline   Reply With Quote
Old 10-23-2008, 08:30 AM   #8
chapds
ROC Rank: Sophomore
2007 RTX
chapds's Avatar
Mine broke today too. Honda time... Love the warranty.
Thanx
David
" Now I Guess I'll Have To Tell 'Em, That I Got No Cerebellum ... " - The Ramones
chapds is offline   Reply With Quote
Old 03-24-2009, 10:07 PM   #9
Desert Ridge
ROC Rank: Freshman
2006 RTL
Well, the driver's side pulley broke about a year ago. Truck no longer under warranty. Honda wanted 400 bucks (!!!!!!) to replace this cheezy, one dollar part. After a long set of back and forth "discussions" with the dealership and Honda Central, they did the work for a hundred bucks.
Two weeks later.... the pulley on the passenger side broke.
Honda would not own up to the obvious engineering problem, nor would they grease the repair with the dealer. All they would say was "take the car to the dealer to start the process." Well, taking the car to the dealer and "starting the process" involves a hundred dollar diagnostic fee. I'm not going through that again.
When this truck wears out, it's back to the Ford dealer for this guy. I will not tolerate the scam that Honda calls "customer service." It's a great car, but Honda service has soured me on them and their product. Yup, I see another Ford F-150 in my future.
What a shame that a one dollar part can cause this kind of result in a customer.
Desert Ridge is offline   Reply With Quote
Old 11-09-2009, 02:44 PM   #10
shalbleib
ROC Rank: Freshman
could this part be machined??? if it's that common, maybe i could have them manufactured out of aluminum, and offer to sell them here...
shalbleib is offline   Reply With Quote
Sponsored Links
Advertisement
BB code is On
Forum Jump
rear seat grab handle zeroagenow Interior 11 04-07-2013 08:35 PM
Rear Seat Removal? jambie Interior 2 03-18-2008 08:54 AM
Plastic seat covers or not? DesertRidgeline Miscellaneous/General Honda Ridgeline Discussions 9 11-15-2007 09:54 PM
Rear seat coming apart xxlr8 Interior 6 09-20-2006 08:21 PM
Rear Seat DVD Entertainment ultimate_ed Mobile Electronics 21 05-20-2005 11:49 PM
