Fluid Leak - Advice - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 07-25-2008, 12:09 PM   #1
pjkanata
ROC Rank: Freshman
2006 RTS
Billet Silver Metallic
Red face Fluid Leak - Advice
Just brought home a new (to us - used in real life) Ridgeline with about 28K on it. First morning noticed a small puddle underneath front end. It is realativley clear but with a yellow tinge to it. First thought is brake fluid but does not have the characteristic brake fluid "scent". I don't think A/C water has a slippery feel to it so I a bit puzzled. Any ideas?
pjkanata is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-25-2008, 12:20 PM   #2
MikeT
Mall Ninja Moderator
2006 RTL
Billet Silver / Gray
MikeT's Avatar
Re: Fluid Leak - Advice
Where was the puddle in relation to the botom of the Ridgeline (In the middle under the engine, under the left side by the wheel, ect)?
2006 Ridgeline RTL, Silver with roofrack.
2000 Accord V6 EX, White no roofrack.
MikeT is offline   Reply With Quote
Old 07-25-2008, 12:24 PM   #3
pjkanata
ROC Rank: Freshman
2006 RTS
Forward and more to the right of the engine compartment. Maybe coolant overflow?
Old 07-25-2008, 12:33 PM   #4
MikeT
2006 RTL
MikeT's Avatar
What color is the windshield washer fluid? Is it up by the radiator? My AC drips directly under the engine on the left, I think that's ruled out.
Old 07-25-2008, 12:38 PM   #5
pjkanata
ROC Rank: Freshman
2006 RTS
WWF is blue colored. I'll have to go and check exact area for a better description.
Old 07-25-2008, 01:51 PM   #6
BillB
ROC Rank: 2k Comma Club
2008 RTS
Steel Blue / Gray
BillB's Avatar
Definitely would be my guess. What level is the fluid in the overflow tank? There is a full line about halfway up and maybe the seller thought he was doing you a favor and filling the tank to the top.
Ridgeline #2
BillB is offline   Reply With Quote
Old 07-25-2008, 03:34 PM   #7
pjkanata
ROC Rank: Freshman
2006 RTS
Took some time to investigate. Origional info was relayed to me by phone.
I got under the vehicle - definitly by the right front. I found oil dripping off the suspension arm; above it - behold the oil filter. The mystery fluid is just plain old motor oil albiet very clean (oil change done prior to delivery). I suspect it was just spillage during the change process but I will keep an eye on the level just to be sure. Thanks for you feed-back
Old 07-25-2008, 04:06 PM   #8
ROTORRAY
ROC Rank: Junior
Spray a de-greaser under there, or at least clean everything up as best you can, and then monitor it. Sometimes they don't take off the old oil filter gasket and put the new oil filter on over it. There's not room for 2 gaskets and you have a leak. Should not be leaking any oil. If in doubt take it back to the dealer and have them put it on the rack, clean it up and THOROUGHLY inspect it. Don't take "NO" for an answer. JMHO
ROTORRAY is offline   Reply With Quote
Old 07-25-2008, 05:37 PM   #9
roakey
ROC Rank: Junior
2007 RTS
roakey's Avatar
Not always, this is what I use exclusively. More expensive, but works much better than the "blue fluid".
Roak
roakeyatunderctekdotcom
<= Mighty Murphy, the wonder Bouv!
roakey is offline   Reply With Quote
Old 07-26-2008, 11:37 AM   #10
Andy-Montreal
ROC Rank: 3k Comma Club
2006 *Former Ridgeline Owner
Nighthawk Black / Beige
Andy-Montreal's Avatar
Precisely. Several years back, there were a few reported engine fires that occurred as engine oil would leak onto hot exhaust components. This was an issue on the older model CRV & Element where Honda sent out letters to owners on this very subject.
Another problem may be a bad batch of cross-threaded oil filters with an "-A01" part number suffix. Check your oil filter for the batch number. This thread may help: http://www.ridgelineownersclub.com/f...r-defects.html
"Never be afraid to try something new. Remember that a lone amateur built the Ark. A large group of professionals built the Titanic." - Dave Barry
Andy-Montreal is offline   Reply With Quote
Sponsored Links
Advertisement
BB code is On
Forum Jump
Discolored transmission fluid N68330 Problems & Issues 8 06-08-2012 02:07 PM
Observations on changing VTM4 fluid eurban Under The Hood / Performance 32 09-02-2011 02:04 PM
DIY power steering flush... repeater Under The Hood / Performance 20 01-29-2011 06:52 PM
30,000 mile service price bigdaddyflo Problems & Issues 46 03-20-2008 09:31 PM
windshield fluid leak grantnpeg Problems & Issues 0 10-25-2007 09:31 AM
