| Register | FAQ/How To's | ROC Chat Room | ROC Calendar | Honda Dealers | Honda Club Store | Search | Today's Posts | Mark Forums Read |
| Notices |
#1 |
ROC Rank: Turkey
2006
RTS
Billet Silver / Gray Join Date: Jan 2005
engine block heater
Since I don't plan on getting an RTL, that means I can't have heated seats (not from the factory anyway) so would an engine block heater help the truck warm up faster? I've never had a vehicle that had one...that's what the little plug hanging out of the grill is--right? The coldest it gets here is typically 25F but that's unusual and it only happens around now when there isn't any cloud cover at night. Unfortunately, the Ridgeline won't be fitting in the garage either and more unfortunate is that it's been COLD here this year
. Rain I can take, but not cold or heat or humidity. Will I be able to start the truck and turn on the heat (and actually get warm air) or will there still be a wait?
I drive a Honda and push one too. |
| Sponsored Links | |
Advertisement |
#2 |
ROC Rank: Turkey
Re: engine block heater
It will help it warm up faster, but if the 6 is anything like the 4 in my wifes Civic, you don't have to worry. It heats up very fast, and our nights are much colder than what yours are.
Robert |
#3 |
ROC Rank: Stuffing
You certainly won't need an engine block heater if it barely gets below freezing in your local. All a block heater does is circulate the engine oil allowing easier engine starting in very cold conditions. It won't make the coolant any warmer. I can only assume Honda Canada is smart enough to include them with all the Canadian models though...
#5 |
ROC Rank: Stuffing
2006
RTL
Redrock Pearl / Beige Join Date: Dec 2005
Does anyone hereaboits know just how mich an engone block heater warms up the coolant?
#6 |
ROC Rank: Ham
2006
RTS
Billet Silver / Gray Join Date: Dec 2005
I had one on my F150 and 02 Mustang (canada rides). Car blows heat way faster with it plug in a few hours before you leave. ( helps deice faster)
I plan on getting one also, helps keep the block warm and less start knock. H&A sells the kit for cheap, downside is you have to drain the coolant. Mods, mods & more mods to buy
06 RTS Silver/Gray, born 11/05 Mods: de emblem tailgate, Honda Hitch,mud flaps, removed stickers from windows, 2008 Black Granite Chevy Trailblazer SS 1997 GT, H&R lwr springs, Magnaflow, 03 cobra rims 1978 F250 Ranger XLT No car is safe from the Mod Master ! |
#7 | |
ROC Rank: Cranberry
2006
RTL
Nighthawk Black / Beige Join Date: Aug 2005
Have Navi? Change the Splash Screen! Last edited by Lingered_I; 01-12-2006 at 08:59 PM. |
#8 |
ROC Rank: Mashed Potatoes
2006
RTL
Billet Silver / Gray Join Date: Nov 2005
When I lived in Alaska I had an aftermarket (JC Whitmey) model that had a heating element and a pump. It was installed by cutting the heater hose line. This heated and circulated the coolant, therefore, your vehicle was toasty warm as soon as you started it up. You needed it on those -50F mornings
Give a person a fish and you feed them for a day; teach a person to use the Internet and they won't bother you for weeks.
#9 |
ROC Rank: Turkey
2006
RTL
White / Beige Join Date: Dec 2005
There are a few different types of heaters, the one you are referring to, the block heater is put in place of a freeze plug on the engine block and as stated before when you take that freeze plug out, out comes the coolant! I ran a V6 Aerostar and 4 cyl. Escort through four winters in Anchorage, Alaska. The Aerostar was garaged, Escort wasn't and neither one had a block heater. I don't think that much would be gained in 25F weather by having a block heater installed. On the few mornings I've ran my heater in the Ridge this winter (~20F) by the time I've traveled the 1.7 miles to exit the subdivision and then turn the heater on, it's blowing warm air, though won't blow hot for a couple more minutes.
TL
2006 Honda Ridgeline - White 2005 Honda Accord - Satin Silver Metallic (Hers) 1993 Isuzu Trooper - White 1968 Ford Torino GT Fastback - Gold 390 V8 |
#10 | |
ROC Rank: Rolls/Bread
2006
RTS
Billet Silver / Gray Join Date: Sep 2005
Honda Towing Package, Rear Splash Guards, Prodigy brake controller, Garmin 2610 GPS, Front Window Tint, Torza Soft Top. Echomaster reverse sensor step bumper What I tow: 2005 Fleetwood Highlander Sequoia - 3,500 lb 2008 Ranger 1860 Angler w/150 Yamaha - 3,950 lb "Things will get better as they improve." |
| Thread Tools | |
| Display Modes | |
| Engine? | BigTzElement | Under The Hood / Performance | 34 | 03-31-2006 06:22 PM |
| Ocassional longer engine start time w/stumble | vertrkr | Under The Hood / Performance | 51 | 12-05-2005 02:57 PM |
| Missing tube on my engine? | vertrkr | Under The Hood / Performance | 11 | 04-28-2005 11:58 PM |
| HF 118 Honda Jet Engine | Ridge | Miscellaneous/General Honda Ridgeline Discussions | 19 | 04-25-2005 09:01 PM |
| Engine space/car maintenance | nwdiver | Miscellaneous/General Honda Ridgeline Discussions | 5 | 02-16-2005 12:37 PM |
