Ridgeline bogs when warm after running 5 hours off and on stop and go... - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Under The Hood / Performance
Notices
Closed Thread
Thread Tools Display Modes
Old 10-20-2008, 11:00 AM   #1
tonkatruck
ROC Rank: Freshman
2008 RT
Billet Silver Metallic
tonkatruck's Avatar
Send a message via Yahoo to tonkatruck
Exclamation Ridgeline bogs when warm after running 5 hours off and on stop and go...
I have an o8 Ridge. When I deliver pizza in this truck, AFTER turning it off every delivery, about 4 or 5 hour sinto my shift the gas pedal feels stiff and the truck barely moves unless it is floored from a dead stop... Could this be bad gas? No check engine light is on. I have been running Phillips 89 octane since this happened, only got better gas mileage by 1.5 m.p.g., Tonka still bogs down...Tonka has backfired during passing at about 5500 6000 r.p.m. also. The only mod I have is a K and n cold air kit, and this has been the same since day one. Also when Tonka is warmed up, the exhaust smells like chlorine bleach... real noxious... Any help?
Jace
tonkatruck is offline
Sponsored Links
Advertisement
Old 10-20-2008, 11:04 AM   #2
chisoxjim
ROC Rank: 5k Comma Club
2006 RT
Other
chisoxjim's Avatar
Re: Ridgeline bogs when warm after running 5 hours off and on stop and go...
take it to the dealer, sounds like "tonka" as issues.
chisoxjim is offline
Old 10-20-2008, 11:12 AM   #3
codda
ROC Rank: 1k Comma Club
2013 RTL
Crystal Black Pearl
codda's Avatar
I wouldn't tach-out Tonka this early in the break-in process. ( I saw your post in another thread...1500mi.
codda is offline
Old 10-20-2008, 11:14 AM   #4
arteegee
2006 RTL
Steel Blue / Gray
arteegee's Avatar
There's the problem. How many pizza deliveries did that cost you? Why put that crap on there?
#567 HPD-Shut Up and Drive...
arteegee is offline
Old 10-20-2008, 11:26 AM   #5
RidgeLI
ROC Rank: Senior
2011 RTL
Polished Metal Metallic
RidgeLI's Avatar
You said the exhaust smells.....possibly your catalytic converter is going, and sometimes the "brick" inside the converter causes blockage and may explain hesitation.
RidgeLI
RidgeLI is offline
Old 10-20-2008, 12:18 PM   #6
shovelhd
ROC Rank: Comma Club HOF 10,000+
2006 RTL
Steel Blue / Gray
shovelhd's Avatar
Maybe it's fouled out from the K&N oil.
Shovelhd media installation thread
Kenwood DDX8019*Garmin KNA-G510 Nav 2009 Maps*KCA-BT200 Bluetooth*KTC-HR100 HD Radio Tuner*KTC-V500N TV Tuner (RIP)*KCA-iP200 iPod Adapter*SIR-KEN1 Sirius Satellite Radio Tuner with Lifetime Subscription*Webb OEM XM Antenna Conversion*PPI DCX-730 DSP*Eclipse XA4000 Mains Amp*Rockford-Fosgate T1500bd Sub Amp*Rainbow SLC 265 Front Components*Rainbow 165 SL Rear Coaxials*(2) Diamond Audio D610D4 Subs in Custom Subthump Box*KP Technologies Rollup Modules
shovelhd is offline
Old 10-20-2008, 01:32 PM   #7
tonkatruck
ROC Rank: Freshman
2008 RT
tonkatruck's Avatar
The k and n was only put on recently. I am getting 16.5 m.p.g. city instead of 15, so it didnt cost me a thing lol... Break in process is a bunch of hog wash... They tested two identical 1988 labaron turbos, one broken in to factory specs, one not, they both burned the SAME amount of oil at 100,000 miles lol
Old 10-20-2008, 01:44 PM   #8
Erock40
ROC Rank: Junior
2006 RTS
Steel Blue / Gray
Erock40's Avatar
Send a message via MSN to Erock40
So where did you get your mechanical engineering degree?
Oh... and who is "they"
Erock40
Erock40 is offline
Old 10-20-2008, 02:15 PM   #9
tonkatruck
ROC Rank: Freshman
2008 RT
tonkatruck's Avatar
Mechanical engineering degree, school of Hard Knocks, I know after about 350-to 500 miles the piston rings have completly seated and the engine has been broken in, if it was 2500 to 5000 miles, then why arent all the vehicles that are hot rodded blown up already? "They" were the cars they tested for this break in process. I have taken my truck to the dealer, they drove it cold said it drives fine. I cannot take the truck in to the dealer when this issue happens because I am working and it is usually about 1 or 2 am... I believe the dealer needs to give me a loaner and keep my truck till they figure out whats wrong with it... Doesn't anyone else name things they love???
BREAK IN PROCESS
Strait from a honda tech
http://www.honda-tech.com/zerothread?id=748015
Old 10-20-2008, 02:27 PM   #10
tonkatruck
ROC Rank: Freshman
2008 RT
tonkatruck's Avatar
My local dealer agreed to take Tonka and keep him overnight run some gas out till he gets warm to cause the issue. Prolly the cat. converter...
Sponsored Links
Advertisement
Closed Thread
BB code is On
Forum Jump
