Do I need to replace all four tires??? - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Tires, Wheels and Suspensions
Notices
Thread Tools Display Modes
Old 12-21-2008, 07:42 AM   #1
Vector1
ROC Rank: Freshman
Well... Unfortunately I walked out to my Ridgeline this morning and found that both drivers side tires had been slashed and were flat . I have just over 35,000 miles on these tires which are the OEM Michelin LTX M/S P245/65 R17's. Would anyone know if I would need to replace all four tires at this point or if it is OK to have two new tires on one side of the vehicle?
2007 Ridgeline RTS -
Aberdeen Green w/Hood Air Deflector, Running Boards, Front/Rear Splash Guards and a Roof Rack.
Vector1 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-21-2008, 07:53 AM   #2
shovelhd
ROC Rank: Comma Club HOF 10,000+
2006 RTL
Steel Blue / Gray
shovelhd's Avatar
Re: Do I need to replace all four tires???
I would put the new ones up front, move the other ones to the back, and don't rotate them. These GM owners must have been celebrating their bailout.
Shovelhd media installation thread
Kenwood DDX8019*Garmin KNA-G510 Nav 2009 Maps*KCA-BT200 Bluetooth*KTC-HR100 HD Radio Tuner*KTC-V500N TV Tuner (RIP)*KCA-iP200 iPod Adapter*SIR-KEN1 Sirius Satellite Radio Tuner with Lifetime Subscription*Webb OEM XM Antenna Conversion*PPI DCX-730 DSP*Eclipse XA4000 Mains Amp*Rockford-Fosgate T1500bd Sub Amp*Rainbow SLC 265 Front Components*Rainbow 165 SL Rear Coaxials*(2) Diamond Audio D610D4 Subs in Custom Subthump Box*KP Technologies Rollup Modules
shovelhd is offline   Reply With Quote Quick reply to this message
Old 12-21-2008, 08:38 AM   #3
northernlights
ROC Rank: 2k Comma Club
2006 RTS
Steel Blue / Gray
northernlights's Avatar
If the NOT slashed tires are showing cracks or dry rot I'd see if I could get them rated at a tire store. Get a police report on the slashed ones and call your insurance. You might be able to get four news ones pretty cheap depending on your deductable.
northernlights is offline   Reply With Quote Quick reply to this message
Old 12-21-2008, 09:06 AM   #4
hwycycle
ROC Rank: Senior
2006 RTL
Billet Silver / Gray
It depends... At least, you'll have to put the remaining tires on the same axle. Try replacing the slashed tires and see if the computer likes the new tires. From what I understand if the overall circumference of the tires and rims are drastically different from the new ones... you might have a problem...
In my Department, we use Ford Explorer which require the replacement of all 4tires if just one tire is damaged... amazing but true. I recently sent our 2008 Explorer (5 months in service) to the shop with one cut tire... and it came back with 4 new tires... The Explorer is driven by supervisors and had only 22k miles on it...
Tom
Build Date 5-06
Silver RTL, moonroof, OEM Brushguard, OEM Tube steps, OEM Fog Lights, OEM Rear Mud Guards, OEM Chrome Rims, 2011 RTL rims & tires, OEM Grill Upgrade, OEM Bed Extender, OEM Roofrack, Hidden Hitch, Pioneer AVIC-F90BT, ScanGuage II, Softopper, Viper 5904 alarm/auto start, Interior LED's, LED lightbar.
hwycycle is offline   Reply With Quote Quick reply to this message
Old 12-21-2008, 09:10 AM   #5
larryr
ROC Rank: 3k Comma Club
2009 *Former Ridgeline Owner
White / Beige
larryr's Avatar
1. Radial tires from one side should never be used on the other side of the car. Radial tires rotate front to rear and vice veras.
2. Radial tires should be replaced by Axle - Both front or both rear at the same time.
That being said:
Since both tires slashed are on the same side. you need to replace all 4 at the same time.
How good is your local Honda Dealer. I picked up 4 ridgeline OEM tires from a dealer in NC for $250 for all 4 with 10 miles on them. The dealer put 20" custom wheels on a new Ridgeline and sold the wheel rims on ebay and had the tires left. Your local Honda Dealer may do the same thing.
Also try ebay if you can wait a few days for tires .
2013 Honda CR-V Polished Metalic EX-L with Navi.
The 199 fill ups on my 2009 Ridgeline with 20.6 MPG and over 60,000 miles driven- I just had 8 wonderful years in the Ridgeline but the Electronics are too many generations behind.
larryr is offline   Reply With Quote Quick reply to this message
Old 12-21-2008, 09:21 AM   #6
TraumaTruck1
ROC Rank: Sophomore
2007 RTX
Dark Cherry Pearl
I would replace all 4. The way the 4x4 system works, the truck is in 4x4 everytime you drive. Not just when it's slippery when you would usually put a truck into 4x4. Any difference in tire circumference can cause major problems because the front and back will turn at different speeds. If you had 10,000 miles I would get 2, but since you are almost half worn I would go with all 4.
TraumaTruck1 is offline   Reply With Quote Quick reply to this message
Old 12-21-2008, 10:31 AM   #7
franc944
ROC Rank: Senior
2006 RTL
Billet Silver Metallic
franc944's Avatar
Send a message via AIM to franc944
Call me captain obvious but would't the lowest cost solution be to buy 2 used Micheline LTX tires from a local tire place or the internet.
I got one locally for $35 otd recently when I had sidewall damage on one with 30,000 miles on it.
I made about 15 calls out of the yellow pages to dismatlers and used tire shops.
2006 Silver RTL Navi, rear camera, oem step tubes, oem bug deflector, oem bed extender, and eBay 4 piece grill insert.
franc944 is offline   Reply With Quote Quick reply to this message
Old 12-21-2008, 02:33 PM   #8
northernlights
2006 RTS
Steel Blue / Gray
Only if a directional tire?
Old 12-21-2008, 02:41 PM   #9
TraumaTruck1
ROC Rank: Sophomore
2007 RTX
Dark Cherry Pearl
Captain Obvious has the best idea if you can find them. I had a similar situation and found one. I forgot about that earlier. I think I paid $45.
Old 12-21-2008, 03:41 PM   #10
Webwader
2006 RTS
Webwader's Avatar
It's too bad Honda has it all wrong as they recommend rotating the fronts straight back to the rears and CROSS rotating the rears to the front as long as they are non-directional tires.
Honda Towing Package, Rear Splash Guards, Prodigy brake controller, Garmin 2610 GPS, Front Window Tint, Torza Soft Top. Echomaster reverse sensor step bumper
What I tow:
2005 Fleetwood Highlander Sequoia - 3,500 lb
2008 Ranger 1860 Angler w/150 Yamaha - 3,950 lb
"Things will get better as they improve."
Webwader is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Honda Maintenance checklists for service intervals kahnartist Miscellaneous/General Honda Ridgeline Discussions 6 03-24-2010 06:48 PM
What Did You Replace Your OEM Tires With, Where Did You Get Them, What Did You Pay? cdepuydt Tires, Wheels and Suspensions 141 12-01-2009 02:25 PM
Care and feeding of your RL's tires. steveberger Tires, Wheels and Suspensions 7 05-23-2009 08:11 PM
Michelin LTX tires replaced at 24,000 miles Cajun Country Ridgeline Problems & Issues 26 09-10-2007 08:03 AM
It's getting cold out side (Tire Pressure) alsridge Problems & Issues 43 12-03-2006 02:58 PM
