how hard is the washer pump replacement? - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Under The Hood / Performance
Notices
Thread Tools Display Modes
Old 12-23-2008, 10:29 AM   #1
ZowieK
ROC Rank: Freshman
2006 RTL
Steel Blue Metallic
I just bought a used 06 Ridgeline from a dealership about 300 miles away.
On the way back I realized washer pump isn't working. I called the dealer, they told me that any local dealer would fix it free of charge because it is a certified used. I haven't talked with the local Honda Dealer about it yet, but if it is something that I can fix relatively easily, then I would just go ahead and do it by myself. I checked the fuse and it was fine. Washer tubes seem to be intact. Just the washer tank so long and goes under frame scares me to go ahead and check it.
If anyone has done the same task of changing washer pump, I would like to have any advise.
I was thinking that I get Trico universal pump.
Thank you.
ZowieK is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-23-2008, 11:12 AM   #2
MikeT
Mall Ninja Moderator
2006 RTL
Billet Silver / Gray
MikeT's Avatar
Re: how hard is the washer pump replacement?
I trust you are refering to the Windshield Washer pump. Should be easy enough to do by removing the passenger side front inner wheel well splash gaurd and the mud gaurd.
2006 Ridgeline RTL, Silver with roofrack.
2000 Accord V6 EX, White no roofrack.
MikeT is offline   Reply With Quote
Old 12-23-2008, 01:55 PM   #3
boobai
ROC Rank: Sophomore
On a similar note, my washer water stopped pumping all of a sudden (fluid wasn't low) so I thought maybe water was frozen on the jets. So I defrosted the truck in the garage and poked around the jets with a pen. Now it pumps, but only hits the very bottom of the windshield. How do I change the angle? I tried just prodding around but not much luck.
boobai is offline   Reply With Quote
Old 12-23-2008, 03:57 PM   #4
OldNorske
ROC Rank: Junior
2006 RTL
White / Beige
OldNorske's Avatar
Put a straight pin (not pen) into the hole of the jet. The jet is adjustable. Move the jet where you think it should be to hit your windshield properly and try it. Keep adjusting the jet until you have it aimed properly.
OldNorske is offline   Reply With Quote
Old 12-27-2008, 10:44 PM   #5
RkyMntHigh
ROC Rank: Senior
2007 RTL
Aberdeen Green Metallic
RkyMntHigh's Avatar
I don't think they will give you the part for free even if it is under warranty. I think they still want to work on it.
Side note: This same thing happened to my TL the other day. You knew it wasn'ty worked because it would even make a sound as if it was trying to pump the fluid out. Then I remembered there was a recall in the Washer Motor that came out in Feb. I took it in to the Acura dealer to get two Recalls done (the motor and a power streeing pump hose). Whe My wife picked it up to day sure enough they fluid came out. I take it as that the MOTOR which was mentioned is for the wipers to work and that the pump is something else. Thats how I have always seen them I think maybe they thought they broke it and fixed it but nothing was said except thanks for bring it in.
07 RTL SB/Navi
04 Acura TL 6 speed/Navi
1981 Kawasaki GPz550
RkyMntHigh is offline   Reply With Quote
Old 12-29-2008, 06:52 AM   #6
shovelhd
ROC Rank: Comma Club HOF 10,000+
2006 RTL
Steel Blue / Gray
shovelhd's Avatar
The washer motor is less than $25. I wouldn't use a universal.
Shovelhd media installation thread
Kenwood DDX8019*Garmin KNA-G510 Nav 2009 Maps*KCA-BT200 Bluetooth*KTC-HR100 HD Radio Tuner*KTC-V500N TV Tuner (RIP)*KCA-iP200 iPod Adapter*SIR-KEN1 Sirius Satellite Radio Tuner with Lifetime Subscription*Webb OEM XM Antenna Conversion*PPI DCX-730 DSP*Eclipse XA4000 Mains Amp*Rockford-Fosgate T1500bd Sub Amp*Rainbow SLC 265 Front Components*Rainbow 165 SL Rear Coaxials*(2) Diamond Audio D610D4 Subs in Custom Subthump Box*KP Technologies Rollup Modules
shovelhd is offline   Reply With Quote
Sponsored Links
Advertisement
BB code is On
Forum Jump
Windshield washer fluid drainplug? Pug Under The Hood / Performance 11 10-30-2011 07:14 PM
Micron Air brand Pollen (Cabin) Filter for Ridgeline Joeyo H-and-A Accessories 4 08-07-2008 11:54 AM
Fuel Pump RFI k0bg Mobile Electronics 6 10-20-2006 03:44 PM
locking hard tonneau cover rfs830 Miscellaneous/General Honda Ridgeline Discussions 4 10-16-2006 05:33 PM
Oil plan drainplug washer xd9x19 Under The Hood / Performance 41 06-21-2006 10:27 AM
