check engine and VTM-4 light on - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 02-22-2009, 12:55 PM   #1
miroslavp
ROC Rank: Freshman
2007 RTS
Steel Blue Metallic
I have a Honda Ridgeline 2007 with 45K miles on it.Occasionally I get check engine and VTM-4 lamp,on. I ran a diagnosis and the computer showed two error codes. P0172 and P0175 (system too rich on both banks).
Possible causes:
-intake blocked
-evaporation canister purge valve
-fuel pressure
-EGR system
-injector(s)
-HO2S
Before anyone suggests I take my car to the dealership,my car is in Europe.
Does anyone know which one of these might be the problem?
The engine runs a bit rough when idle and sometimes turns off.
Otherwise the car runs well.
miroslavp is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-22-2009, 12:56 PM   #2
chisoxjim
ROC Rank: 5k Comma Club
2006 RT
Other
chisoxjim's Avatar
Re: check engine and VTM-4 light on
I had this issue a while back. There are a few threads on the topic I believe. My problem was from a tank of bad fuel. Fried the fuel injectors.
good luck
twitter: @GrubSeeker
chisoxjim is offline   Reply With Quote Quick reply to this message
Old 02-28-2009, 05:53 AM   #3
Some Mook
ROC Rank: Freshman
*Not a Ridgeline owner
Some Mook's Avatar
Originally Posted by miroslavp View Post
P0172 and P0175 (system too rich on both banks)....
-EGR system
...The engine runs a bit rough when idle and sometimes turns off.
What does the freeze data show for TPS and MAP when the DTC's set?
If the TPS was at 0.47 - 0.50 volts (meaning closed throttle) and MAP was greater than 1 volt (meaning higher than normal intake pressure), the odds are very good that the EGR valve was sticking open.
The EGR VLS parameter should be less than 1.2 volts at idle (ideally you'd see it at 1.13 - 1.15 volts.
An EGR valve that is sticking open can cause stalling at idle, and fuel system rich DTCs for both banks.
Take a look at the EGR VLS at idle with the engine warmed up, and also look at your MAP value - if both values are high, tap (lightly) on the side of the EGR valve with a screw-driver handle or small (2 oz) ball peen hammer. If both values drop when you do this (the idle will smooth out too), the valve pintle was sticking open, and you would be advised to replace the EGR valve.
BTW, you can ignore the VTM DTC (which was probably a 77-1 Powertrain System Failure) if the MIL was illuminated - the VTM code would have set simply because the PCM had set an MIL-request fault.
Some Mook is offline   Reply With Quote Quick reply to this message
Old 02-28-2009, 07:32 AM   #4
Silver 3.5
ROC Rank: Freshman
2008 RTX
Billet Silver Metallic
Silver 3.5's Avatar
Bad gas could be the cause. I would check the air filter to make sure it's ok and that nothing found a home in the airbox or intake. I would be looking at the air mass sensor. Had a problem with a bad MAF on a different car that threw the same codes. Car ran ok but the light would come and go, then finally stayed on.
Silver 3.5 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your Ridgeline?
Model
What model Ridgeline do you drive?
Color
What color is your Ridgeline?
Can you spell?
What letter in the alphabet is the fifth character of the word "Honda Ridgeline"
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
a tid bit in The Wall Street Journal on MDX SH-AWD applicable to the VTM maintenance RidgeLI Miscellaneous/General Honda Ridgeline Discussions 1 09-24-2008 07:33 AM
At the dealer service department now. Flashing engine light, and VTM-4 light lit up. chisoxjim Problems & Issues 110 06-18-2008 02:07 PM
Vtm 4 Steel Blue RTX Problems & Issues 2 08-17-2007 07:44 PM
HELP, no VSA, no VTM, Check Engine light on. Luder62678R1 Miscellaneous/General Honda Ridgeline Discussions 10 04-16-2006 07:30 PM
VTM and Check Engine lights jpred Under The Hood / Performance 23 03-15-2006 08:09 AM
