want to get a FS spare: question about sizes - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Tires, Wheels and Suspensions
Notices
Thread Tools Display Modes
Old 05-31-2009, 10:07 PM   #1
trapperkeeper
ROC Rank: Freshman
I want to get a FS spare for my RTL. I can't believe that this wasn't standard. Anyway... Looks like wheels on the RTL are 18x7.5 with P245/60R-18 Michelin LTX M/S tires. I want to buy a RIM from tirerack that is 18x8 and put the Michelin on that. If I got a flat, then I'd just put this FS spare on until I could get the original fixed. I know that the TPMS will be all whacked, but my bigger concern is towing a 4800lb boat + trailer and not having a FS space. Although the stock rims are 18x7.5, I can't see how 1 rim that's 18x8 would be an issue since the diamater is the same and the tire is the same so what's revolving and contacting the ground would be the same as the other 3 stock tires. Anyone have any experience, thoughts or comments? Thanks!
trapperkeeper is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-01-2009, 05:51 PM   #2
chiph
ROC Rank: 2k Comma Club
2006 *Former Ridgeline Owner
Steel Blue Metallic
Re: want to get a FS spare: question about sizes
Since you're not shopping for an exact match on the rim (aka buying it from the local Honda dealer), the thing I would pay attention to is the circumference of your wheel/tire combination. After the bolt pattern & offset, that is.
The reason I would look at that before choosing between a 17" or 18" wheel is the circumference is what will make the difference in how many RPM's the wheel has, which means that your ABS & vehicle stability system won't freak out.
Something else to keep in mind is that steel wheels and the aluminum factory wheels use different lug nuts.
Chip H.
chiph is offline   Reply With Quote
Old 06-01-2009, 08:31 PM   #3
trapperkeeper
ROC Rank: Freshman
So I bought an allow 18x8 wheel with the same 45mm offset as the stock 18x7.5's that are on the RTL now. I am putting the exact same size Michelin LTX tire on the 18x8 rim as the 4 stock Michelins. Total cost shipped = $236 which is cheaper than what Honda wants just for a rim! The circumference will be the exact same, only thing is the FS spare on the 18x8 Rim will stick out a tiny bit further than the other 3 tires. This is GOT to be better if I get a flat and am towing 5000lbs than using that little tiny thin tire that's in there now.
Old 06-01-2009, 08:44 PM   #4
larryr
ROC Rank: 3k Comma Club
2009 RTL
White / Beige
larryr's Avatar
Ebay has lots of factory wheels for less than $100. That is where I got my full sized spare.
http://cgi.ebay.com/ebaymotors/2006-...Q5fAccessories
2009 White RTL with Gray interior
My second Ridgeline. My first was a 2006 RTL Steel Blue with Gray interior.
Mud Flaps, AVS bug guard, AVS ventvisors, Sportwing Door Protectors, Donnelly Autodim Compass Mirror, Isimple Ipod attachment.
And a full sized 18" spare tire.
larryr is offline   Reply With Quote
Old 06-01-2009, 11:26 PM   #5
arteegee
ROC Rank: 5k Comma Club
2006 RTL
Steel Blue / Gray
arteegee's Avatar
http://cgi.ebay.com/ebaymotors/SET-O...171|240%3A1318
#567 HPD-Shut Up and Drive...
arteegee is offline   Reply With Quote
Old 06-02-2009, 03:40 PM   #6
TigerRidge
ROC Rank: Sophomore
2007 RTX
Steel Blue Metallic
TigerRidge's Avatar
Where are you planning on keeping the spare?
"Sprint Booster: For those that say 'F*** you' to middle ground"
TigerRidge is offline   Reply With Quote
Old 06-03-2009, 07:28 AM   #7
Ahab
ROC Rank: Senior
2006 RT
Steel Blue / Gray
I found a new steel rim on e-bay for $40. Discount tire gave me a free take off used tire and mounted it for free. When I tow I throw it in the bed.
Ahab is offline   Reply With Quote
Old 06-03-2009, 09:03 AM   #8
trapperkeeper
ROC Rank: Freshman
I was hoping in the area where the current spare is?? Don't tell me a FS spare won't fit there....
Old 06-03-2009, 09:05 AM   #9
r-squared
ROC Rank: 1k Comma Club
2008 *Former Ridgeline Owner
Steel Blue Metallic
r-squared's Avatar
Stock size full size spare fits.
http://www.ridgelineownersclub.com/f...ull+size+spare
r-squared is offline   Reply With Quote
Sponsored Links
Advertisement
BB code is On
Forum Jump
Check your spare tire pressure reminder! wrenrj1 Miscellaneous/General Honda Ridgeline Discussions 10 10-18-2008 07:26 AM
What size spare tire cover do I need? absinthe Other Cars, Trucks and Bikes 6 07-13-2008 07:33 AM
Full Size Spare Question shamrockshooter Tires, Wheels and Suspensions 3 04-19-2008 10:03 PM
Full Size Spare and Roof Rack Tool Question nevadagarth Accessories 11 01-12-2006 06:54 PM
TPMS Sensor for Spare Tire Question Todd Tires, Wheels and Suspensions 7 09-28-2005 01:44 PM
