rubber cup holder tabs - Page 2 - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Interior
Notices
Thread Tools Display Modes
Old 05-02-2013, 01:07 PM   #11
rollinhonda
ROC Rank: Comma Club HOF 10,000+
2010 RTL
Dark Cherry Pearl
rollinhonda's Avatar
Re: rubber cup holder tabs
Originally Posted by StotheG View Post
They were already removed in my 06 when I got it in '10. I guess I don't know what I'm missing, but I have no desire to replace them.
I don't blame you. You can always get foam sleeves for bottles, cans, etc. if you need it.. why bother.
Honda North, ClovisCA Sales 4 Service 3.5
Private Mechs:
Kurata Automotive, Fresno
Charlies Automotive, Clovis
Home of the Free, because of the Brave!
rollinhonda is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-03-2013, 10:20 AM   #12
goosler
ROC Rank: Sophomore
2006 RTL
White / Beige
Originally Posted by rr2030 View Post
I would like to talk to a Honda Tech. I bet there is a shortcut to this.
no short cut.........the entire center console has to come out..... I've done it on 3 ridgelines.......pretty easy & straight forward job, but time consuming.
Proud to be the 20,000th Member!!!!
goosler is offline   Reply With Quote Quick reply to this message
Old 05-03-2013, 10:26 AM   #13
rollinhonda
2010 RTL
Dark Cherry Pearl
The part is only about 3 or 4 bucks.
Private Mechs:
Old 05-15-2013, 03:54 PM   #14
RTL
ROC Rank: Freshman
2006 RTL
Amazon Green / Olive
RTL's Avatar
For those of you who are going to replace the black rubber I can share my experience.
I used the PDFs in this thread. Very easy, but it's an awful lot of work for very little gratification. There are four screws holding the center console in place, but to get to the front two, you have to remove the lower dash and the center plastic piece in between the lower dash and the center console. I don't think I'll bother next time they wear out. I think I'll just rip the rubber tabs out and leave it like that. I also needed to replace one of the bulbs in the seat heater switch, so I was killing two birds with one stone on this.
My tool list:
10mm socket
phillips screwdriver
dash removal tools
t15 torx bit
2 flat head screwdrivers
The PDFs in this thread tell you exactly what you need to do, but I had a few notes...
As the PDF says, you have to remove the "not an ashtray" bin in the lower dash to get to one of the three screws that hold the lower dash in. This comes out real easy, although at first I didn't get how. If you open the bin then pull out, it comes right out (see pic).
Also, the two trim pieces (driver's side is big, passenger side is small) that are hiding the other two screws on the lower dash have retention clips on one side, and just a tab on the other side (see pics). You just have to pull these plastic trim pieces apart from the lower dash, then they come right out.
Once the lower dash is off you have to remove the plastic piece that's in front of the console to expose the two screws. This piece "underlaps" the console a bit, but only 1/4". You can push the plastic piece a little towards the front of the truck until it clears the console then pull it straight up (see pic). It's just held in by two retention clips on the console side. The front part has hooks.
"Pimped" Infiniti 1031t tweeters
USA spec BT35-HON bluetooth interface
Polk db651s front & rear
Switchblade Key
RTX Grille
Coming soon:
FatMat
RTL is offline   Reply With Quote Quick reply to this message
Old 05-15-2013, 04:29 PM   #15
rollinhonda
2010 RTL
Dark Cherry Pearl
Nicely done! BTW, I noticed the 'broken' tab on my holder has a mylar film on the underside also. I ordered a spare retainer and noticed they are made the same way.
I don't know if the mylar is an improvement over earlier years, regardless, they still break!
Thanks again for the photos.
Private Mechs:
Old 05-15-2013, 04:29 PM   #16
Slider
ROC Rank: 1k Comma Club
2006 RTL
White / Olive
Slider's Avatar
105k and mine are pretty decent. I think I have a Wednesday build after the Tuesday raise.
OEM- Hitch, Brush Guard, Fog Lights, Wood Dash, Side Mouldings, Fender Flares/Splash Guards, Roof Rack, Hard Tonneau and 2013 RTL wheels. Non OEM- Fat Bob's Lift, 265/60/18 LTX MS 2's, front tint, LED's, Figs props, Pioneer Avic x930 bt, 400w amp, Bazooka sub, Backup camera, Fog Light mod.
Slider is offline   Reply With Quote Quick reply to this message
Old 05-15-2013, 04:33 PM   #17
RTL
ROC Rank: Freshman
2006 RTL
RTL's Avatar
To get to the two rear screws that are holding the center console, you have to pry off the back piece of the console where the rear vents, power outlet, and floor light are. I would suggest getting it started down low near the carpet and work your way around releasing the retention clips. The retention clips are AT AN ANGLE. They have to be pulled UP & OUT at an angle heading toward the rear window. There are a bunch of tabs all around the back piece that hold it in place when it's attached. They break easily. There's one connector that needs to be unplugged. The other can be left connected and the piece can just lay down flat on the floor.
Once the console is out, its pretty easy to seperate the sliding part from the rest of the console. I used a zip tie to hold the button down and two flat heads to push the tabs down while pulling it apart with my third hand.
Also, the PDF says theres 6 Torx screws, but I had 7 in mine....two at the back, and five near the cup holders. You need a t15 torx bit to remove.
This is probably overkill for such an easy job, but the few tips in here might prevent someone from breaking a plastic trim piece or hopefully at the very least shave some time off the whole thing.
Switchblade Key
RTX Grille
Coming soon:
FatMat
Old 06-11-2013, 08:45 AM   #18
rollinhonda
2010 RTL
Dark Cherry Pearl
If you only have 1 or 2 broken tabs I wonder if you can double up and put 2 stacked holders in there? Should last even longer, maybe...?
Private Mechs:
Old 07-24-2013, 01:21 AM   #19
noneill88
ROC Rank: Freshman
2008 RTS
Nimbus Gray Metallic
Nice Post! I need to do mine soon, i've had them for months now.
noneill88 is offline   Reply With Quote Quick reply to this message
Old 07-24-2013, 09:18 AM   #20
chisoxjim
ROC Rank: 5k Comma Club
2006 RT
Other
chisoxjim's Avatar
thinking this is an American "problem".
sounds like too many supersized drinks from fast food value meals might be the culprit here.
:-D
twitter: @GrubSeeker
chisoxjim is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
06-033 2006 Ridgeline Beverage Holder Tabs Broken csimo Recalls, TSB's and Notices 23 06-11-2013 10:11 AM
Cup Holder Foam Replacement Cameron Problems & Issues 18 01-25-2008 11:01 AM
Cup Holder Mount for Nuvi 350 nole1972 Mobile Electronics 25 10-28-2007 08:56 PM
New Cup Holder Cap 5S Dude Mods, Installs and How-To's 16 07-14-2006 05:46 PM
Cup Holder Mods? RidgeInTheVille Mods, Installs and How-To's 1 03-01-2006 01:53 PM
