Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Accessories
Notices
Thread Tools Display Modes
Old 03-04-2005, 01:04 PM   #1
vertrkr
ROC Rank: Cranberry
2006 RTL
Steel Blue / Gray
vertrkr's Avatar
Send a message via AIM to vertrkr
Where to get Rivet Nut insert tool for running board install?
I plan to install the running boards myself but it needs a special tool to install a threaded rivet nut. They have a picture of it in the install docs:
http://www.handa-accessories.com/rid...nningboard.pdf
Unfortunately I've yet to find it at local hardware store or on the net. If anyone knows exactly what you call this tool or where to get it I'd sure appreciate it.
vertrkr is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-04-2005, 06:06 PM   #2
delphi7x10
ROC Rank: Turkey
Re: Where to get Rivet Nut insert tool for running board install?
Vertrkr,
Try someplace like MSC, or Graingers, lloking at it, looks like you mayy even be able to improvize, with a home made tool. These are easier than the others I have seen.
delphi7x10 is offline   Reply With Quote
Old 03-04-2005, 07:21 PM   #3
Fastrack
ROC Rank: Stuffing
2006 RTL
Steel Blue / Gray
Send a message via AIM to Fastrack
I found one on Ebay. Needed it for a bugflector on my sister's Pilot.
06 Ridgeline RTL Steel Blue w/Navi-rear camera-chrome bumper trim-fogs-roof rack-trunk carpet-factory side molding
00 S2000 Monte Carlo Blue-SuperCharged-Air Walker ground effects-Work Meister S2R 17"rims-Kenwood sound-Amuse Ti exhaust
Fastrack is offline   Reply With Quote
Old 03-05-2005, 12:58 AM   #4
cowen
ROC Rank: Stuffing
Metric thread setter for nutserts is what my is called from a Snap-On kit, but it came with a Snap-On price. Check at local independent tool retailers in your area. Once you have it and are ready to use it. Pay caution to the set up directions, to not snap off the mandrel inside the nutsert you are installing, or you will not be very happy. "The Voice of Experience", just take your time installing them and everything will be easy.
cowen is offline   Reply With Quote
Old 03-05-2005, 02:31 AM   #5
vertrkr
ROC Rank: Cranberry
2006 RTL
Steel Blue / Gray
vertrkr's Avatar
Wow, thanks all. I really did not expect anyone to know what I was talking about. Most helpful.
Old 03-05-2005, 11:43 AM   #6
Ridge Man
ROC Rank: Mashed Potatoes
Ridge Man's Avatar
After viewing install instructions and looking at item #4. A similar tool at Ace Hardware (Arrow rivet tool,Type that in Google)Also in the install instructions they don't mention if the Knurled Threaded Insert is Metric or SAE?? You can also check out this site.
http://www.rivetsinstock.com/rivet45.htm#2
Ridge Man is offline   Reply With Quote
Old 03-06-2005, 08:41 PM   #7
delphi7x10
ROC Rank: Turkey
Vertrkr,
Harbor Freight has tool for this, and it is only $12.00, if the bolt size fits.
you can see it at this link.
http://www.harborfreight.com/cpi/cta...temnumber=1210
Hope this helps, if not since only 2 of the nuts need this tool, I would find a garage that has it, and give a $10.00 to install the 2 of them for me.
Old 03-07-2005, 02:22 AM   #8
vertrkr
ROC Rank: Cranberry
2006 RTL
Steel Blue / Gray
vertrkr's Avatar
Excellent, thanks a bunch all. Guess I was thrown off track as nothing I saw looked like the tool in the install docs. Just need a rivet tool that installs threaded nuts, seems there's a variety of these of all shapes and types. Found a specialized tool shop in my area so I'm going to wait until I have the rivet nut and then bring it in to be sure I get the right tool that will fit it. If nothing else I'll fall back to plan B, piece of wood and my sledge hammer
BB code is On
Forum Jump
Running Boards - self install summary vertrkr Mods, Installs and How-To's 21 08-16-2007 07:44 AM
$99 wireless backup sensor - install summary vertrkr Mobile Electronics 9 07-27-2006 10:39 PM
Solved the running board insert problem! mugen1 Mods, Installs and How-To's 21 09-10-2005 07:17 PM
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
