How to change wheel bearings. - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline > Problems & Issues is the premier Honda Ridgeline Forum on the internet. Registered Users do not see the above ads.
Thread Tools Display Modes
Old 10-07-2009, 08:56 AM   #1
ROC Rank: Junior
2007 RTL
Nimbus Gray Metallic
Qxtreem's Avatar
Hi gang.
I have tried a few different searches. And Not sure if this belongs here or in How To's so please forgive.
I am starting to hear a clicking noise on the highway. It is not every time and comes and go's. I am thinking it is a bad wheel bearing.
Is this something I can do myself? I searched DIY sites and it seems kind of easy. Has anyone done this themselves?
My Life is Powered by Honda.
Honda Navigation/XM. OEM: Rear View Camera(refitted to the handle), Sunroof, Roof Rack, Auto D/N Mirror, Tow Package, Honeycomb Grill, and Fog Lights. Skyjacker Lift Kit. 245/70/17 GoodYear AT Adventure w/ Kevlar tires. Scangauge II in the NAA. 50% Tint(over factory) on the front, rear and back windows, and 8% Limo on the sunroof. Protecta bed Mat. KP Technologies Windows Up Module. Figs Props. Royal Purple 5w-20 Oil. ROC Decal. Built 10/06, bought 11/06.
Qxtreem is offline   Reply With Quote Quick reply to this message
Sponsored Links
Old 10-08-2009, 01:57 PM   #2
ROC Rank: Freshman
Re: How to change wheel bearings.
If it's a clicking noise, it's more likely a bad CV joint. A bad wheel bearing produces more of a constant hum that changes with speed. This page explains everything on more detail:
Uconn411 is offline   Reply With Quote Quick reply to this message
Old 10-09-2009, 04:15 PM   #3
ROC Rank: Freshman
2006 RTS
Steel Blue Metallic
im with uconn on this one. i clicking is usually not a wheel bearing. a wheel bearing will be a hum that changes pitch with speed. also, if you jerk the truck back and forth (on a road that is empty ) the noise will change from side to side, at least if only one is bad.
i cannot see there being any way for you to do a wheel bearing at home. they are pressed into your front knuckle. most people take the whole front knuckle off and put it in a hydraulic press. there are however some of us that have made tools to replace them on the truck without taking the hub apart other than the axle and lower ball joint, however this still requires 2 different special tools, and a SERIOUS impact gun.
i would still shy away from this being a wheel bearing problem, however without driving the truck myself, i cannot be a ton of help
Certified Honda Master Technician
Any Honda help that you need in the Boston, MA area, please feel free to ask!!
2006 RTS Steel Blue Matallic - Borla exhaust, custom test pipe, intake...blower in the works ...
Skeeter7424 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Quick Reply
Register Now
User Name:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your Ridgeline?
What model Ridgeline do you drive?
What color is your Ridgeline?
Can you spell?
What letter in the alphabet is the fifth character of the word "Honda Ridgeline"
Please select your insurance company (Optional)
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Running without Oil During Dealer Oil Change bertwhitaker Problems & Issues 34 10-11-2007 07:51 PM
When to change oil? RidgeBoyRTL Under The Hood / Performance 32 05-05-2006 12:02 PM
How Many Miles Before First Oil Change? Under The Hood / Performance 218 04-09-2006 06:06 PM
Wheel Bearings BIRDHUNTER Exterior 1 01-22-2006 09:06 PM
Arrrggggggg! Wheel problem. swampler Tires, Wheels and Suspensions 21 10-23-2005 05:31 PM
