Bug deflector issue - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Accessories
Notices
Thread Tools Display Modes
Old 10-11-2009, 07:21 AM   #1
speedlever
Moderator
2008 RTS
Billet Silver Metallic
speedlever's Avatar
Bug deflector issue
I bought an AVS II deflector last year and mounted it on the RL. Recently I just happened to notice that the left front of the deflector is lightly rubbing the front fender at the edge. But it must only happen at speed since there's plenty of clearance at a standstill.
Anyone else see this?
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-11-2009, 07:31 AM   #2
k757
The Unamused Moderator
2006 *Former Ridgeline Owner
Redrock Pearl / Beige
k757's Avatar
Re: Bug deflector issue
put some 3M tape on that end. That should hold it steady (and will come off if you ever want it to)
-Keith
Was: 2006 Ridgeline RTS, 2008 Ridgeline RTS
Now: 2011 Subaru WRX & 1999 Acura 2.3CL
k757 is offline   Reply With Quote
Old 10-11-2009, 07:54 AM   #3
midnightmadman
ROC Rank: Freshman
2006 RTL
Usually they come with those little clear dots that you stick on the body to protect it in the spots where it moves and can rub. You can buy them at a hardware store
midnightmadman is offline   Reply With Quote
Old 10-11-2009, 11:20 AM   #4
speedlever
Moderator
2008 RTS
speedlever's Avatar
Good ideas.
Just seems strange that it would do this at all... especially on the left side which appears to be a bit farther from the fender than the right side, which shows no sign of contact at all.
Old 10-11-2009, 07:04 PM   #5
k757
k757's Avatar
If you could watch it when at highway speeds, I suspect it has a slight wiggle.
-Keith
Old 10-11-2009, 09:17 PM   #6
BRANDONJAMES
ROC Rank: Freshman
2008 RT
Dark Cherry Pearl
I was having the same issue and I just went up to the local hardware and got 4 clear little stick on balls like the ones mentioned above and put the in the spots where it was possible for the deflector to rub. Havent had a problem since.
BRANDONJAMES is offline   Reply With Quote
Old 10-11-2009, 09:28 PM   #7
RockyRoad
ROC Rank: Senior
2009 RTL
Mocha Metallic
RockyRoad's Avatar
I bought a Honda deflector and it works well. I will check to see if it scratches my fender.
! Not to be a pessimist, freedom has a price. So does living. Pay it forward.
RockyRoad is offline   Reply With Quote
Old 10-12-2009, 08:28 AM   #8
RockyRoad
ROC Rank: Senior
2009 RTL
Mocha Metallic
RockyRoad's Avatar
No scratches from my Honda bug deflector. FYI: The sides are very firm and I see no marks or scratches.
Sponsored Links
Advertisement
BB code is On
Forum Jump
Help with installing weathertech bug deflector!!!! ryukinrobo2 Accessories 6 11-20-2009 11:33 PM
Looking for a new clear bug deflector brich Mods, Installs and How-To's 5 03-28-2009 06:12 PM
Bug shield...what bug shield... nohr14 Accessories 18 12-10-2007 02:40 PM
Bug guts GaryT41 Washing / Waxing / Detailing 3 06-14-2006 12:31 AM
Bug Screen MikeFL Exterior 0 04-09-2006 12:27 PM
