Check Engine/VTM-4 light on... - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 12-08-2009, 06:54 PM   #1
CrowMagnumMan
ROC Rank: Senior
2006 RTL
Steel Blue Metallic
CrowMagnumMan's Avatar
Just had the little engine icon light up and the VTM-4 light come on at startup. They stayed on. Interesting to note that last Wed. I had my oil/oil filter, air filter, and VTM-4 oil changed. The RL also sputters when slowing down to stop and when stopped but does not stall. Thoughts?
06 Steel Blue RTL/Nav - OEM fog lights, OEM hood deflector, OEM rear mudflaps, OEM all-weather Ridgeline front mats, OEM trunk mat, OEM 4.73 Nav. disc, 5S Dude's license plate frame/door sills, E&G grill, chrome pinstripes, Raptor 4" oval SS side steps, SportWing side protectors w/ Ridgeline badges, chrome hubcap skins, Weather Tech rear floor mats, AVS window visors, FastLane heavy duty bed mat, chrome door handles, tailgate handle, taillight covers, mirror covers, and side vent strips.
CrowMagnumMan is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-08-2009, 09:10 PM   #2
speedlever
Moderator
2008 RTS
Billet Silver Metallic
speedlever's Avatar
Re: Check Engine/VTM-4 light on...
Engine light and sputtering.... bad gas?
VTM-4 light comes on... problem with the VTM-4 system.
Recent maintenance? It all sounds too coincidental to me.
Sorry... not much help here.
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is offline   Reply With Quote
Old 12-09-2009, 06:29 AM   #3
CrowMagnumMan
ROC Rank: Senior
2006 RTL
Steel Blue Metallic
Gas is a possibility. I was running out of gas, needle was on E, starting sputtering a bit, filled it alittle. Went home. Had to run right back out, started it up, and the engine icon came on.
VTM-4 - who knows.
However, you are right. Way too coincidental. Just got it serviced last Wed. and 6 days later, problems.
Goes in today at 2:30PM. We shall see.
Thanks!
Old 12-09-2009, 07:00 AM   #4
thefinks13
ROC Rank: Sophomore
2007 RT
Billet Silver / Gray
thefinks13's Avatar
Thumbs up Re: Check Engine/VTM-4 light on...
engine light def from air getting in system no big deal may need dealer to clear light at least i had to...twice...no history with other light i have changed that fluid a few times i used small motorized pump to remove old fluid and make sure you use honda vtm4 fluid. no other.
good luck.
keep me informed.
thefinks13 is offline   Reply With Quote
Old 12-09-2009, 07:15 AM   #5
CrowMagnumMan
ROC Rank: Senior
2006 RTL
Steel Blue Metallic
Would air cause the sputtering? Easy to turn the light off, but, it is sputtering.
VTM-4 service was done by the Honda shop.
We'll see how it goes.
Thanks.
Old 12-09-2009, 07:16 AM   #6
shovelhd
ROC Rank: Comma Club HOF 10,000+
2006 RTL
Steel Blue / Gray
shovelhd's Avatar
I hope they filled the differential back up.
The engine sputtering could be from running the fuel down to empty. Mash the gas a few times.
Shovelhd media installation thread
Kenwood DDX8019*Garmin KNA-G510 Nav 2009 Maps*KCA-BT200 Bluetooth*KTC-HR100 HD Radio Tuner*KTC-V500N TV Tuner (RIP)*KCA-iP200 iPod Adapter*SIR-KEN1 Sirius Satellite Radio Tuner with Lifetime Subscription*Webb OEM XM Antenna Conversion*PPI DCX-730 DSP*Eclipse XA4000 Mains Amp*Rockford-Fosgate T1500bd Sub Amp*Rainbow SLC 265 Front Components*Rainbow 165 SL Rear Coaxials*(2) Diamond Audio D610D4 Subs in Custom Subthump Box*KP Technologies Rollup Modules
shovelhd is offline   Reply With Quote
Old 12-09-2009, 08:02 PM   #7
CrowMagnumMan
ROC Rank: Senior
2006 RTL
Steel Blue Metallic
Well, this is going to cost me $220. Went today. They told me it was the EGR valve. It was clogged and I need a new one. Cost $146. They charged me for an hour's labor today - $74. Told me it is NOT under warranty. Hmmmm. 2006 with 32,900 miles on it. Thought it was an emission part which would be covered to my knowledge.
Anyway, it is what was causing the engine to sputter. It inturn caused the engine light to go on which in turn make the VTM-4 light go on because according to them, when there is something wrong with the engine, it shuts down the VTM-4 because the engine is unable to supply power to it, etc.
I am just curious why I was charged for them to run the codes and "clean" the EGR valve, yet, I need a new one. When I started it up, both lights were out. Took it about a mile and the truck still sputtered so I turned right back around and told them about it. They pulled some type of plug and it runs better than it did before????? Engine light and VTM-4 light came back on though. Part is ordered.
Thoughts?
Old 12-19-2009, 12:01 PM   #8
Nga_and_Phu
ROC Rank: Freshman
2006 RTL
I just had my 30K maintenance over a month ago on my 06 Rigdeline. check engine and VTM light came on as I was pulling out of the driveway. Got to the corner, turned off the engine and started back up again. The VTM light disappeared but the check engine light still on.
Taking into the dealer to diagnosis -- It's going to be at least $100 for the diagnostics. Interesting how this happens just as the the 3yr/30k warranty runs out.
06 RTL, Moonroof and Roof Rack
05 Civic LX (Wife's)
03 Galant -- Back to Honda
97 Accord LX (wife's)
95 Accord LX
90 Accord LX
87 Prelude Si
85 Prelude
Nga_and_Phu is offline   Reply With Quote
Old 12-19-2009, 01:17 PM   #9
speedlever
Moderator
2008 RTS
speedlever's Avatar
Originally Posted by Nga_and_Phu View Post
snip
That would be 3 year/ 36k warranty.
Or 5 years/60k for the drivetrain.
Old 12-19-2009, 07:38 PM   #10
Nga_and_Phu
ROC Rank: Freshman
2006 RTL
Yip it was 3yr/36K warranty. The service was a for B36 code, performed at 41K. The check engine light came on at 42.6K
Dealer checked it out and reported Code P0116 Coolant Temp Sensor Range Performance. A software update cleared the check engine light.
Software updates should be covered by the manufacturer as a service bulletin. If you release software that buggy and needs to be updated, the update shouldn't cost the consumer. In the in the information technology industry, software updates to fix bugs or patch an issue are released as free updates. The auto industry should do the same. At least provide a longer warranty period for software updates. Maybe 5yr/60K warranty on software updates.
It feels like stuff starts to break soon after manufacturer's warranty expires for me all the time. Guess I'll be investing in extended warranties more often.
95 Accord LX
90 Accord LX
87 Prelude Si
85 Prelude
Sponsored Links
Advertisement
BB code is On
Forum Jump
Got a joke to share? Long Gone The Ridge - Off-Topic Discussions 2927 04-24-2013 03:10 PM
HIDs baseballfreak2 Mods, Installs and How-To's 56 07-07-2010 03:02 PM
VTM-4 Light Bikemedic Problems & Issues 12 10-20-2008 01:30 PM
At the dealer service department now. Flashing engine light, and VTM-4 light lit up. chisoxjim Problems & Issues 110 06-18-2008 02:07 PM
Trailer Hitch Harness Recall shanew Recalls, TSB's and Notices 72 11-01-2006 07:23 AM
