| Notices |
#1 |
ROC Rank: Junior
2007
RTL
Billet Silver Metallic Join Date: Feb 2008
Replacing Spark plugs Question
I know I have between 66500 and 67000 miles on my 07 and some of you will be questioning me doing this now but on a severe service life schedule the plugs, timing belt, and check of the water pump should be done at 60000 miles. I think I read that right.
On my last couple of GM vehicles I was told to use a tool that helped me remove the plug boots without damage as I kept breaking the plug wires right near the boots. Is there such a tool for the Honda vehicles? Or is there any trick to getting the boots off without damage? Or should I just replace the wires now while I am in there? Do you use the anti sieze compounds on your plugs? |
| Sponsored Links | |||
Advertisement | |||
#2 |
ROC Rank: 3k Comma Club
2007
RTX
Dark Cherry Pearl Join Date: May 2009
Re: Replacing Spark plugs Question
There are no plug wires, its coil packs. You take out a allen bolt and pull the coil pack with the spark plug attachment out in one pull up. If you look under the hood you can see 3 black boxes and the allen bolts i am talking about. There are 3 identical ones on the back side of the engine. Pull the engine cover off and replace the plugs. Its very simple, buy you will need a long extension on the socket since honda puts spark plugs deep in the heads. Because they are coil packs you have no need to replace them for a long long time. I dont use anti seeze, but some do. Good luck!
Click here for pics and mod info of my truck! Last edited by 07_rtx; 12-09-2009 at 08:45 AM. |
#3 |
2007
RTX
Here is a pic. Look just beside my oil cap and under the 3 turn tabs on the engine cover. You will see the front 3 coil pack boxes that i am talking about
Click here for pics and mod info of my truck! |
#4 |
Moderator
2006
RTL
Billet Silver / Gray Join Date: May 2005
FYI, even on the severe maintenance schedule the service schedule for the spark plugs and timing belt both remain at 105,000 miles. No change from the normal service schedule.
-Joe email: joe at ridgelineownersclub . com (anti-spam measure, but you can figure it out) |
#5 |
ROC Rank: Senior
2006
RTL
Steel Blue Metallic Join Date: Aug 2009
Joe,
It would not hurt anything to change them earlier, correct? I am nowhere near that but was thinking of changing around 75K. Thoughts?
06 Steel Blue RTL/Nav - OEM fog lights, OEM hood deflector, OEM rear mudflaps, OEM all-weather Ridgeline front mats, OEM trunk mat, OEM 4.73 Nav. disc, 5S Dude's license plate frame/door sills, E&G grill, chrome pinstripes, Raptor 4" oval SS side steps, SportWing side protectors w/ Ridgeline badges, chrome hubcap skins, Weather Tech rear floor mats, AVS window visors, FastLane heavy duty bed mat, chrome door handles, tailgate handle, taillight covers, mirror covers, and side vent strips. |
#6 | |
Moderator
2006
RTL
In other words I don't think you'll hurt anything by changing them sooner than recommended, but I don't think you'll gain anything either. I would change them at the same time the timing belt is changed out at 105k miles. Change the water pump, idler and tension pulleys, serpentine belt, thermostat and hoses. You'll be good to go for another 105k miles.
#7 |
ROC Rank: Senior
2006
RTL
Thanks bub!
#8 | |
ROC Rank: Junior
2007
RTL
#9 |
ROC Rank: Freshman
there are some posting on which brand to use bosch fusion, ngk laser irridium, pulstar be1...least to most expensive, respectively.
i found a set (6 plugs sold in 3 packages) of pulstar for 75 at autozone. not sure why they are so inexpensive (comparatively)...perhaps they mistakenly label 24.99 for one plug, but each package comes with 2. every where else its 49.99 for 2 plugs. i leaned toward using ngk laser irridium (13.99 each) until i found the pulstar deal. they will be installed in my 06 rt with 100k on a new second set of tires. thanks for the clues on where the other 3 plugs are located. |
#10 |
ROC Rank: Sophomore
2006
RTS
Billet Silver Metallic Join Date: May 2008
Location: 6 miles from sanibel and fort myers beach, florida
My pul stars failed with only 13 k miles on them. not happy.
47 modifacations.Cat back magnaflow.AFE air intake.side bumper strips.bull bar.running boards.lite bar strip.hid headlight system.gps Sony 4.8.back up vidio.cb radio and P.A.chrome wheel skins.led backup lights.tonneau cover.bug deflector.chrome mirror, door and trunk handles skins. drilled sloted rotors. larger tires. Fox hood ornament. 42 feet of stick on chrome, and roof rack, to name some of the expensive ones. most modifications inspired by ROC.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| Spark plugs | par3773 | Under The Hood / Performance | 11 | 05-14-2012 10:33 AM |
| Spark Plug Question | Head | Under The Hood / Performance | 39 | 05-14-2012 08:13 AM |
| changing spark plugs | flying butcher | Problems & Issues | 16 | 04-12-2011 02:52 PM |
| general Warranty question and ethics- non honda | spitfisher | The Ridge - Off-Topic Discussions | 7 | 12-24-2008 02:41 PM |
| Ease of replacing stock speakers on RTX question... | QuintanaRooster | Mobile Electronics | 3 | 09-24-2008 05:26 PM |
