Jammed door lock! - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 04-28-2010, 01:07 PM   #1
BlueRidge06
ROC Rank: Sophomore
2006 RT
Steel Blue / Gray
BlueRidge06's Avatar
Jammed door lock!
I think someone tried to break into my Ridgeline! My keyhole is jammed, I can only stick my key in about 1/4" into the keyhole. I haven't taken it to the dealer yet, but I am anticipating it not being under warranty (2006, just passed 50k miles).
I'm good with step-by-step picture instructions and I'm sure I could get the parts I needed from H&A. Anyone have any idea how complicated this might be? Suggestions?
2006 Steel Blue RT Ridgeline
BlueRidge06 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-28-2010, 01:41 PM   #2
hiPSI
ROC Rank: 2k Comma Club
2010 *Former Ridgeline Owner
Mocha Metallic
hiPSI's Avatar
Re: Jammed door lock!
Do you know what jammed your lock? Do you use the key in the lock often? I would try some WD-40 or something first.
It is easy to remove the lock itself. After removing the insiide door panel the lock removal is simple. If WD-40 does not free it up or if there is something broken off inside depending on what it is a locksmith might be cheaper than buying a new lock cylinder.
ROC #935
hiPSI is offline   Reply With Quote
Old 04-28-2010, 06:48 PM   #3
Jack
ROC Rank: Senior
2008 RTL
Billet Silver / Gray
Jack's Avatar
Don't know if this will work, but I had a key break off in another car I owned. Short of calling a locksmith or going to a dealer because the car was old, I used my black and decker shop vac. Taped the end of the hose over the key hole using good old duct tape, turned it on, and when it reached full suck I heard the key piece fly down the hose.
Give it a try ya never know.
Jack is offline   Reply With Quote
Old 04-28-2010, 08:48 PM   #4
BlueRidge06
ROC Rank: Sophomore
2006 RT
Steel Blue / Gray
I don't know what jammed the lock...it's possible something got stuck in it, but it felt like pieces are loose in the lock itself. I don't know if that's even possible but I just know my key hit something hard and twisting the key in different directions didn't get it pass the obstacle! =(
Do I spray WD-40 into the lock itself? I know the last time I used it would've been last summer when I used it to close all my windows...that's really the only time I stick the key in the lock...I'm just nervous that my key's battery will die and I will have no way of getting into my car unless I use my other remote key!!! yikes!
Old 04-28-2010, 09:26 PM   #5
RustyH
ROC Rank: 4k Comma Club
2006 RTL
Nighthawk Black / Beige
RustyH's Avatar
Never use WD-40 on locks. Go to your local hardware store and get some lock graphite and try that. I don't know that it will solve your particular problem, but only use DRY graphite on any lock...otherwise you're just asking for trouble down the road.
06 RTL, 2011 ROTY billet cubby cover, door sills and license plate frame. Polished Billet Grills, Custom paint, 275/45R/20 Yokohama tires on Rozzi Octane wheels. caliper covers, custom airbag suspension. Kenwood DVD Player, Rockford Power T15004 Amplifier, Six Rockford Power 6.5" speakers and 2 10" downfiring subs. Custom 3 color Wet Okle seat covers. Airraid CAI, throttle body spacer, Magnaflow muffler, Truxedo Pro Tonneau Cover, Hidden Hitch, smoked head and taillights.
RustyH is offline   Reply With Quote
Old 04-29-2010, 05:55 AM   #6
hiPSI
Mocha Metallic
hiPSI's Avatar
Ok Rusty, what trouble down the road? I agree dry graphite should be used to lubricate locks, but what about for cleaning locks? My recommendation for WD-40 is if anything (mud, dirt, spider, wood, etc) is clogging the tumblers dry graphite would only exacerbate the problem. WD-40 is a solvent, not a lubricant. Before you can lubricate, you must get whatever is stuck or jammed moving. Penetrating oil is another option but WD-40 works well in hinge, lock and bolt situations where the mechanism is initially stuck.
ROC #935
Sponsored Links
Advertisement
BB code is On
Forum Jump
Door Lock reelnice2 Interior 9 11-28-2012 04:37 PM
KP Auto Door Lock and factory speed lock? mikeh Mods, Installs and How-To's 4 05-03-2007 10:22 AM
Door Lock Fix? MauiRidge Problems & Issues 0 07-28-2006 07:28 PM
Door Lock Noise flridgey Interior 7 02-11-2006 12:14 PM
Door lock light goes out dan-D-man Interior 2 01-12-2006 04:05 PM
