Catalytic Converter Heat Shield Replacement $560???? - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 06-25-2010, 01:21 PM   #1
shanew
ROC Rank: Freshman
So I have had a weird screeching sound at around 2000 RPMs on my 2006 Ridgeline. After searching the forum it looked like the problem was related to TSB 07-028 (intermediate shaft heat shield is loose) so I took it to the dealer to get the heat shield replaced. After diagnosing my Ridgeline they are telling me the Catalytic Converter Heat shield rusted and causing the problem. I had both of my catalytic converters replace about a year and half ago, but I guess they didn't replace the catalytic converter heat shield. Now this dealer wants to charge me $560 total to replace a $40 part. Does this sound right or are they gouging me? Is it going to take that labor to remove the exhaust and catalytic converters and replace the heat shield?
shanew is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-25-2010, 07:34 PM   #2
Skeeter7424
ROC Rank: Freshman
2006 RTS
Steel Blue Metallic
Re: Catalytic Converter Heat Shield Replacement $560????
Shane
This all depends on which CC you are talking about. There are front and rear cats (I'm guessing the ones u had replaced) and a lower CC. Also, the shields arent $40 from Honda. I don't have prices in front of me, but I can confirm on what we get for them tomorrow if you would really like. Anyways, the lower CC we get an hour to replace the shields, which is way less that $560...the front or rear ones however, are such a PITA to get out, that actually doesnt sound too unreasonable. However, if it were my vehicle, I would go to an auto parts store and grab a metal hose clamp (the screw types), and put it around the shield and CC. Taking those out is not my idea of a good time , or a good job for that matter in our shop.
Hope this helps you!
...Skeeter...
Certified Honda Master Technician
Any Honda help that you need in the Boston, MA area, please feel free to ask!!
2006 RTS Steel Blue Matallic - Borla exhaust, custom test pipe, intake...blower in the works ...
Skeeter7424 is offline   Reply With Quote Quick reply to this message
Old 06-26-2010, 11:34 AM   #3
chiph
ROC Rank: 3k Comma Club
2006 *Former Ridgeline Owner
Steel Blue Metallic
The hose clamp trick is also used in the CR-V community when the heatshield mounting points rust out. Use a stainless-steel clamp.
Chip H.
chiph is offline   Reply With Quote Quick reply to this message
Old 06-26-2010, 11:44 AM   #4
ridgelinematt
ROC Rank: Senior
2009 RTL
Mocha Metallic
ridgelinematt's Avatar
Chip H.
Ditto with my 04' Pilot
09' RTL Mocha w/Black Interior - OEM Air Deflector, Mud Guards, Black Roof Rack, Running Boards,
Torza Hard Hat Premier Tri-Fold Tonneau, Protecta Bed Mat, WeatherTech Black Digimats, Pop & Lock
04' Honda Pilot EX Sagebrush Pearl
02' Mazda Protege5
99' Honda Shadow Ace 1100C2
ridgelinematt is offline   Reply With Quote Quick reply to this message
Old 06-26-2010, 07:41 PM   #5
shanew
ROC Rank: Freshman
Originally Posted by Skeeter7424 View Post
Shane
...Skeeter...
Thanks for the information Skeeter. So, the CC heat shields that are a PITA to get to are on the CCs that are mounted up to the Cylinder Heads (I was looking up Honda parts and think I found them)? I put my Ridgeline up on ramps today and looked underneath it and the heat shields on the lower CC looked okay and didn't seem to be loose. So I guess my dealer is talking about either the front or rear CC heat shields. I may look for them tomorrow to see if that is what they are talking about. I am also still concerned that this problem is related to TSB 07-028. If they miss diagnosed it and I still have the problem $560 later I am going to be very annoyed. Also, how would I use the hose clamp on the front or rear CC? I can't imagine that I will even be able to get to it.
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
O2 sensor alert to catalytic converter failure amy19355 Problems & Issues 32 01-28-2013 07:15 AM
Need an Air Intake Heat shield only for Mod ace5000 Under The Hood / Performance 1 08-22-2009 12:53 PM
WTB: OE catalytic converter TeamRidgeline Trading Post 3 07-24-2009 06:44 PM
exhaust heat shield ripped off bolts cer0z Miscellaneous/General Honda Ridgeline Discussions 0 09-04-2006 12:06 PM
Accord question catalytic converter replacement rfs830 Other Cars, Trucks and Bikes 2 05-21-2006 11:25 PM
