Which is the most waterproof hard tonneau cover? - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Accessories
Notices
View Poll Results: Which is the most waterproof tonneau
Extang 0 0%
Backflip 6 42.86%
Retrax 4 28.57%
Rollbak 0 0%
OEM 1 7.14%
None of the above .. retrofit a Sport Trac tonneau! 3 21.43%
Multiple Choice Poll. Voters: 14. You may not vote on this poll
Thread Tools Display Modes
Old 08-09-2010, 10:49 PM   #1
Rambunctious
ROC Rank: Sophomore
2011 RTL
Bali Blue Pearl
I can't believe I just spent ~3 hours going through the forums seeking this answer. I've been able to "narrow" it down to the Extang, Backflip, Retrax, Rollbak, and even the OEM but none seems close to a perfect solution.
I understand mounting may be difficult, but as a former Ford Explorer Sport Trac owner, for the ~$1k I dropped on the original factory tonneau, I got a decade of near waterproof, "perceived" security (guess a screwdriver could pop open the locks), and great looks. Am I to understand that after 5 years, Honda still can't get it right? Really? My only complaint about the ST tonneau was how solidly it was built, bit of a challenge to remove the heavy top and store it away from the vehicle.
Requirements:
- Hard top
- Multiple points of access (ie folding/rolling)
- Nearly waterproof
- Works with bed extender
- Removable by 1 person
I'm awaiting delivery of a '11 RTL w/ navi and as much I've dumped into this truck, spending up to $1,500 for some peace of mind is well worth it.
(Be gentle)
Rambunctious is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-09-2010, 10:56 PM   #2
rollinhonda
ROC Rank: Comma Club HOF 10,000+
2010 RTL
Dark Cherry Pearl
rollinhonda's Avatar
Re: Which is the most waterproof hard tonneau cover?
Here's a test I did on my Extang..I have nothing to compare it with, but quite pleased with it all around.
http://www.ridgelineownersclub.com/f...7&postcount=18
http://www.ridgelineownersclub.com/f...8&postcount=19
http://www.ridgelineownersclub.com/f...9&postcount=20
Honda North, ClovisCA Sales 4 Service 3.5 (out of 5)
Private Mechs:
Kurata Automotive, Fresno
Charlies Automotive, Clovis
Home of the Free, because of the Brave!
rollinhonda is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 11:12 PM   #3
Rambunctious
ROC Rank: Sophomore
2011 RTL
Bali Blue Pearl
Not a bad test and I like your comments about a bed mat (I had one in my ST as well) ... mental note: get bed mat! However, that's a lot of water for just 1 minute, how much would you expect in a downpour that last several hours?
... is the trunk waterproof (taking into consideration a bed mat is added)?
Old 08-09-2010, 11:34 PM   #4
rollinhonda
2010 RTL
Dark Cherry Pearl
No doubt it will get more water with a constant rain, however it always running off. I did not try to move it around and make sure it was sealing better, especially where it meets the back of the cab. Some have added various rubber strips and sealing compounds on various tonneau covers to improve it.
I live in an area with not a lot of rainfall, so it was not a major issue for me..especially with a mat where a lot of draining will be underneath it. I guess when the rains come I will really find out. I have not tried a car wash yet either, but would expect results to be similar to the hose test.
Yes, the mat is essential. No problems with the trunk, it is sealed when closed.
By the way, be aware most covers limit the trunk opening somewhat.
Here's the measurement for the Trifecta
http://www.ridgelineownersclub.com/f...1&postcount=13
The Torza has some notches in the rails which allow a little more access. Unless you get the factory top, or another tilt-back cover, there will always be some restriction, but it never seems to be enough to be a real problem.
The retractable covers are likely the most waterproof. Unfortunately, the Ridgeline design does not lend itself to a sealing hard cap such as you see on other pickups.
Private Mechs:
Old 08-10-2010, 07:54 AM   #5
Altamont
ROC Rank: Junior
2006 RTL
Nighthawk Black / Beige
I bought the new Backflip HD expecting it to leak some water, but it is dry. even when I wash the truck it is dry. without the drain tubes. the only time it leaked some water is when I parked it on a steep hill nose down for several days and it rained, but that is what the drain tubes are for. the only disadvantage I can see is that being hard aluminum it will dent, though my has not done so yet. paid $800.
Altamont is offline   Reply With Quote Quick reply to this message
Old 08-10-2010, 09:47 AM   #6
Rambunctious
ROC Rank: Sophomore
2011 RTL
Bali Blue Pearl
Wow, that's a bit of a shock - does this limitation affect the OEM model as well? (which would be really surprising if they let that slip)
Old 08-10-2010, 09:48 AM   #7
Rambunctious
ROC Rank: Sophomore
2011 RTL
Bali Blue Pearl
Good stuff, glad to see some people are having really good experiences with their choice of cover.
Old 08-10-2010, 10:03 AM   #8
rollinhonda
2010 RTL
Dark Cherry Pearl
Again, only the tiltbacks like the OEM (where the back half tilts) do not have a restriction. For other covers, where there is a side rail there is a restriction.
No one has found the restriction to be a problem.
Private Mechs:
Old 08-10-2010, 10:21 AM   #9
Rambunctious
ROC Rank: Sophomore
2011 RTL
Bali Blue Pearl
Thanks for that clarification.
Old 08-10-2010, 11:17 AM   #10
rollinhonda
2010 RTL
Dark Cherry Pearl
Altamount brought up a good point about parking on grades. That could certainly have major effect on how much water gets in and stays in.
Parking nose up when it is raining would certainly help!
I see I will have more opportunities for experiments in the future! Retirement does have some advantages! LOL
BTW, I only noticed today you were asking about 'hard covers'...hopefully the topic will still interest all owners with covers to take some pics!!
Private Mechs:
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
2006 Hard-Cover Tonneau lamontinem Dear Honda: (Feedback Forum) 4 12-19-2007 04:55 PM
locking hard tonneau cover rfs830 Miscellaneous/General Honda Ridgeline Discussions 4 10-16-2006 05:33 PM
Possible New Hard Tonneau Cover to be released soon zuhl Exterior 0 07-31-2006 09:44 AM
Locking Hard Tonneau Cover BIGTAZZDADDY Exterior 6 01-23-2006 03:37 PM
Hard Tonneau Cover rtbaron Exterior 4 06-07-2005 05:10 AM
