Radiator failure @ cooler lines ...
2 reading
81K views 99 replies 41 participants last post by  boobboob
#1 · (Edited)
Radiator failure @ cooler lines ... pics posted
My 07 ridge w /56K miles leaked coolant from the radiator and slightly overheated. Took it local Honda dealer who said radiator failure due to rust ??? I called Honda of America and started a case file. They contacted the dealer and said the radiator failure was due to environment and would not cover my expense ($620). Upon further conversation with mechanic he indicated that failure occurred when oil cooler line pulled out of the radiator , that happened because of dissimilar metal corrosion , a steel washer was used that caused the failure. After subsequent conversation with mechanic and Honda of America, Honda Denied my claim... stating environmental failure and not defect.
Good thing I caught the problem just in time ...damage to the engine and transmission was imminent.
I have read few other posts here that have had the same problem, oil cooler line rusted and pulled out from the radiator..and Honda covered their costs
Any one else has had a problem like this ?
What was the outcome ?
Thanks
#3 ·
sibex, sorry to hear about your radiator problem and hopefully with persistence Honda will cover it, at least part of it. Did you try contacting the Honda rep? Also I see you're from Buffalo, who are you using for dealer service?? I need a different dealer. If you don't want to post here you can PM me, thanks
Update :
Picked up the radiator from a dealer and will be posting some images later (I insisted that they would save it )...looks like something that could have been fixed ...hard to believe that this item (washer) could have caused a catastrophic failure to my engine and transmission .
My rant and complaint to Honda of America got me no ...where.
They are steadfast on not accepting any blame or resposibility for this design /build flaw...using inferior product that will fail !! they offered no Help at all...simply said sorry ...not our problem.
Wow I'm sort of shocked to hear that from them.... I guess 25 years of loyalty and 20 Hondas later means ... O nada.
I lodged a complaint with NHTSB ...
Should I continue to fight or is this a lost cause ?
Took pics today... posting pics of oil cooler line that enters the radiator, had it's threads pulled out lost its compression due to dissimilar metal corrosion .
Honda refused to pay for any portion of it ... claimed it was environmental .
Images show both fittings, one as it appears now one as "new"...it gas "swelled "due to corrosion to 1 millimeter.
Hope this does not happen to the rest of you ...
You should examine this area periodically.
#9 ·
Something still doesnt seem right about this. I just checked my 06 and no signs of corrosion at all. Did both the inlet and outlet have the same corrosion? I dont have the factory service manual, but the parts seem similar from what I can tell.
It almost seems like a second washer was installed, the one that corroded, and pulled the threads out. From the pics, it also looks like one of the washers (on the failed part) still doesnt show any signs of corrosion.
Whats the chance that an incorrect part was installed at the factory or that this is the result of some sort of service?
The online parts diagrams i have access to dont have enough detail, but it look to me like an additional washer was installed and thats the source of the problem.
If thats the case and the factory or dealer service did it, then I'd ratchet up the pressure to have them pay for it.
#10 ·
I can not imagine how any fluid fitting open to the environment (and there are many on any vehicle) can fail on a car due to corrosion unless unspecified parts are used, it was not assembled correctly, or the joint was somehow compromised in an accident, etc.
Honda is more worried about the financial 'environment' when they should be reminded to look at their own 'Honda Care' signs and put the customer first.
Reactions: LowcarbNY
#11 ·
sibex,
Those pics look very descriptive. Did you happen to contact Honda Corporate and send them an email along with those images?
#12 · (Edited)
I know colors and and pictures can be deceptive and hard to interpret, but it also looks like perhaps some sort of thread lock or sealant may have been used. Since the nut and curved pipe that needs to point particular direction are one welded piece, what if a washer was used to change the indexing of the outlet?
#13 · (Edited)
I gave the failed fitting to my friend to examine it and instead, he tried to re-use it and cleaned both washers...there are two washers on that fitting, one stainless and one steel . You can see on some of the photos the washer closer to the fitting (smaller one , rusted one..expanded in thickness ).
So, I pulled the second fitting , the one that did not fail to show the corrosion. The one that failed is the clean one.
I have a case number assigned to this claim , and when i complained about how it was handled, it was re-routed back to the same guy who made the original determination , he closed the case by saying the part and labor would not be covered and that is final...cause of failure is environmental ... Go figure, I have had 10 Hondas that have over 150K miles and never had a problem like that. I guess they don't make them like the use to ..
#14 ·
This what I get there are 2 washers, one ss and one regular steel the one closer to the fiitting gets rusted it expands, then the line comes off? Gets loose and tranny fluid leaks.
I have seen many pictures, I have not seen a broken line on all the pictures, just rust bulilt up.
The options to fix it before it gets worse are:
1 New radiator
2. Disconnect the lines, put a cap fiitting on the radiator connect an external after market tranny dedicated radiator to those lines.
3. Brush off the rust with a wire brush and naval grease, clean it, either put some silicon caulk or a coat of paint, gutter sealer from home depot.
Any other comments corrections or actions that I or anyone else should keep in mind about this post so nobody has to read the 6 threads on the subject or all on this thread?
#16 ·
My Ridgeline also blew a radiator at 117,000 miles BUT lucky for me I noticed that the a/c had just started to blow warm air, looked down at teh gauges and saw that it was just starting to climb up FAST , pulled into a garage 10' away and had them do teh repairs. Now the only issue is that the radiator seems to be fitting loosely even though the garage claims it is correct. Am now at the Honda repair shop for them to look it over JUST tro make sure it " is Ok."
regpatchell@comcast.net;act028:;act028:
#17 ·
Yet another case of blown transmission cooler line fittings. Many on here have been proactively replacing their radiators with aftermarket units with fittings constructed of non-corrosive metals (including me). I'm glad to hear you haven't experienced any long-lasting issues, or so it seems.
#18 ·
I had been following this post on the Radiator issue and felt that I should do the same and replace the radiator. I purchased the one everbody was recommending from Rockauto and am about to install the new radiator but in rereading this , isn't the issue actually the trans. cooler lines ? Is everybody that's doing this also replacing the cooler lines since that's what's rusting out? Or is the washer on the radiator fitting ? I'm confused now... :act002::confused::confused::confused:
#19 ·
#20 ·
Here's how you get satisfaction. I had a friend who did this with a Vega back in the day, and I have done it on a Ford in the past.
Have a magnetic sign made that says somehting like "Honda, they do not stand behind their product, don't buy one" and affix it to both side doors. Drive around in circles by the Honda dealership that services your car. See what happens!
If need be, park in the median or close to the dealer, set up an unbrella and a lawn chair, and have a sign. Tell people the truth when they ask. You might also get a visit from a local TV or radio station.
In my friends case, the Chevy dealer came out and said enough is enough, what do you want! He got his trade in back and all his cash. His campaign cost the Chey dealer revenue.
In my case, the Ford dealer called the house and asked politly that I return the car for a full refund. They had already sold my trade, so they had to pay me back for that as well.
#21 ·
Reminds me whhen I was a lot younger I went with my girl-friend at the time to a Ford dealer to complain about the lousy job they did on rubbing out the paint on the hood to remove some scratches. They had it in writing as part of the used car contract when she picked her early 80's Ford Fairmont she just purchased. (A car I advised her not to buy to start with..)
The sales manager got very indignant, and starting boasting about what great service they had, pointing to the awards around his walls.
I said, "Oh, those plastic trophies, who really cares, it's the final job that counts!"
His face went up about 3 shades of red, I thought we better go, there might be an ambulance driving up soon, and it might be for me.
The next day she composed a very fine letter to Ford consumer service and they ended up repainting the hood.
I've been avoiding Fords since, except for one 2 year experience with a Taurus that convinced me to keep avoiding them. Unless it's a classic Mustang.
#22 ·
I finally put in the new Spectra radiator I got from Rock Auto on Wed. and it leaked. So I had to call Rock auto and explain my situation. I had noticed that the styrafoam corner supports in the box were destroyed, (so it must have really got tossed around by Fedex) but I didn't see anything wrong ( visually) with the radiator. Of course as soon as I dumped the Honda $22 a gal. antifreeze in the radiator it started dripping out from the crimped seam. Ughhh ! I finally got the replacement radiator from Rock auto via Fedex again ( I was chewing my finger nails down to the elbows about when it would arrive and what kind of shape it would be in when I got it). Anyways, so far so good . If anyone is considering replacing theres, it's really not that bad ( especially after having to do it twice).
I took some pictures of the original Honda fittings on the radiator for you all to check out. As you can see, I did it none to soon !!!! Thanks for the heads up on this problem guys. Hopefully I'll get many more years and miles on the Ridgeline without having to take care of this expensive problem?
#23 ·
I think you should send those pics to Honda corporate too.
#24 ·
I've been following all the threads on the radiator failures. Mine still look good from the outside, but that can be misleading. It makes me wonder... What is the latest model year RL that has seen this failure reported on the ROC? Anybody know? Don't remember seeing any 2009's or later. Correct me if I'm wrong.
Wonder if the problem was corrected, or the later RL's don't have enough miles/time on the road yet.
#26 ·
Maybe they'll change their tune when they get enough pics/complaints. Perhaps the NHSTA would be interested too.
