Recommended oil - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline > Dear Honda: (Feedback Forum)
Notices
Thread Tools Display Modes
Old 08-26-2010, 02:49 PM   #1
famaro
ROC Rank: Freshman
2008 RT
Steel Blue Metallic
Recommended oil
While my 2008 Ridgeline was under warranty I took it to the Honda Service Department in San Juan, Puerto Rico to perform the maintenance, but it was not until now that I noticed that they were using 10W-30 instead of the recommended in the manual 5W-20. I want to know if it is right and/or safe of the a Service Department to do that. NOT FOLLOWING THE MANUAL. I called my Service Dept. and they told me that they are using the recommended by Honda but when I call Honda of America they told me to follow the owner's manual. Which one is lying? Or are there other authorized recommended oil in Puerto Rico? Right now I'm at 40K miles on my unit (just passed warranty coverage) and I want to know who is going to held responsible if there is a problem associated to that? What am I going to do, follow the recommendations of Honda and the manual or the local Service Dept? It is safe to switch back to 5W-20? I understand it is supposed to be safe due to the mileage of the unit. What do you guys think?
famaro is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-26-2010, 03:26 PM   #2
larryr
ROC Rank: 3k Comma Club
2009 *Former Ridgeline Owner
White / Beige
larryr's Avatar
Re: Recommended oil
Most of us use Mobil One 5w20 - any 5w20 is the right oil. 10w20 or 10w30 will work but give you poor gas mileage - the engine was designed for 5w20. I would switch to it as soon as possible.
If you look at the oil filler cap it clearly states 5w20.
2013 Honda CR-V Polished Metalic EX-L with Navi.
The 199 fill ups on my 2009 Ridgeline with 20.6 MPG and over 60,000 miles driven- I just had 8 wonderful years in the Ridgeline but the Electronics are too many generations behind.
larryr is offline   Reply With Quote Quick reply to this message
Old 08-26-2010, 07:05 PM   #3
famaro
ROC Rank: Freshman
2008 RT
Steel Blue Metallic
Re: Recommended oil
That is what I think I'm going to do. TNX
Old 08-27-2010, 12:00 AM   #4
laserguy
ROC Rank: 5k Comma Club
2006 RTL
Other
laserguy's Avatar
Re: Recommended oil
5w20 is what you should use. I used 10w30 in a ford suv with 100k miles, I could hear and feel the difference in the engine, when I put the correct weight (5w30) it ran way smoother and the engine was quieter.
laserguy is offline   Reply With Quote Quick reply to this message
Old 08-27-2010, 10:08 AM   #5
rollinhonda
ROC Rank: Comma Club HOF 10,000+
2010 RTL
Dark Cherry Pearl
rollinhonda's Avatar
Re: Recommended oil
Bring your own, you can even buy filters in bulk, and bring those too. They should be willing to give you a discount on the service each time you do.
Honda North, ClovisCA Sales 4 Service 3.5 (out of 5)
Private Mechs:
Kurata Automotive, Fresno
Charlies Automotive, Clovis
Home of the Free, because of the Brave!
rollinhonda is offline   Reply With Quote Quick reply to this message
Old 09-01-2010, 06:38 PM   #6
Dekonick
ROC Rank: Junior
2010 RTL
Crystal Black Pearl
Re: Recommended oil
That is what I have done with our Honda Ody. I like knowing my car has always had mobil 1.
Now - what about the 0w20 oil? My dealer has it for sale...
AND what about the $7 a quart synthetic oil for extended use?
does using any of the above void warranty?
Dekonick is offline   Reply With Quote Quick reply to this message
Old 12-31-2013, 01:33 PM   #7
HONDAFAN123456
ROC Rank: Freshman
Re: Recommended oil
This information is correct. The engine was built to use 5w20 engine oil, but using a 5w30, 10w30 etc. will not harm your engine, but give you less performance, fuel economy etc. I have been using Royal Mfg brand for the past 3 years and have excellent results with the product. I have been using their full synthetic 5w20 (Monarch Synlube 5w20) in my 2010 Honda Ridge line. Check them out on their website at www.royalmfg.com
HONDAFAN123456 is offline   Reply With Quote Quick reply to this message
Old 12-31-2013, 02:13 PM   #8
Ourfarm09
ROC Rank: 4k Comma Club
2011 RTS
Bali Blue Pearl
Ourfarm09's Avatar
Re: Recommended oil
The site says, " Meets requirements of API Services SH/CD, which replaces SG/CD, SF/CC and MIL-L-2104B"
But is it API certified?
aka Ron
U.S. Army (retired) , ASE Certified
AVS ventvisors, ROC decal,
Ourfarm09 is offline   Reply With Quote Quick reply to this message
Old 12-31-2013, 07:41 PM   #9
JimKden
ROC Rank: Freshman
2007 RTL
Dark Cherry Pearl
Re: Recommended oil
I think you mean API Liscensed. API Liscensed simply means the brand has the same additive package and base stock as any other garden variety API Liscensed oils. It's an industry gimic to get you to think the oil has some magical properties, but is only so as to get mfrs to list that as a requirement and oil companies do not have to test their oils to be able to label as API Liscensed oils (it cheapens up the cost of producing an oil)
The better oils use their own additive package because they don't want to stoop that low. But they have to spend cash on expensive API tests to apply the API classification for the oil.
JimKden is offline   Reply With Quote Quick reply to this message
Old 12-31-2013, 08:36 PM   #10
csimo
2014 SE
White/Black
csimo's Avatar
Re: Recommended oil
The correct term is "API Certified" and Honda requires owners to use API Certified oil as a condition of the warranty.
I don't know of anyone that has said API Certified oil has any "magical properties", but I sure know that some snake oil non-API Certified oil manufactures absolutely make wild claims and imply magical properties.
Using an API Certified oil means that the product is certified to meet the minimum requirements for your engine health. The certification doesn't prevent an engine oil from exceeding the specifications... in other words a super premium synthetic oil would not be disqualified from being API Certified.
There are some oil companies that would have you believe they know more about what an engine requires than the people that actually designed and engineered the engine. As long as there are enough people out there to foolishly believe such outlandish claims they'll keep making the stuff.
-Joe
csimo is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your Ridgeline?
Model
What model Ridgeline do you drive?
Color
What color is your Ridgeline?
Can you spell?
What letter in the alphabet is the fifth character of the word "Honda Ridgeline"
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Crutchfield Recommended Speakers SuperChris7 Mobile Electronics 38 12-02-2009 02:55 PM
Give up free oil changes or stick with dealer recommended service? yukiginger Under The Hood / Performance 19 10-24-2007 11:07 AM
recommended cleaner for the dash weatherman Washing / Waxing / Detailing 7 12-22-2006 09:12 AM
Recommended video for newbies vertrkr Greetings & Introductions 11 11-11-2005 07:18 PM
Dealers in Jersey that are recommended Near Freehold jerseyshoreguy Shoppin' and Test Drivin' 15 10-29-2005 08:13 AM
