| Notices |
#1 |
ROC Rank: Freshman
2006
RTS
White / Beige Join Date: Oct 2010
Leaks - water/trunk
Was searching to see of anyone experienced leaks with the trunk. Some months ago I noticed a couple of inches of water in the bottom of the trunk. Opened the plug to drain it and have not figured out how the water got in there. Has there been a problem with the gaskets or something else? For now I have just left the plug out. I suppose I could have not properly shut the trunk????
Also I noticed that when it rains and my truck is parked front-end low, water will accummulate in the forward part of the bed. It will eventually go away but I would have thought it would drain faster than it does. I don't like it since sitting water creates rust. So far I have not experience the seemingly common leaks inside on the driver's side. |
| Sponsored Links | |||
Advertisement | |||
#2 |
ROC Rank: 1k Comma Club
2009
VP
Sterling Gray Metallic Join Date: Nov 2008
Re: Leaks - water/trunk
Check around the seal (and the underside of the trunk door) to see if there is any debris, such as tree leaves/twigs, obstructing it. I park near a tree and there is frequently something fallen onto the truck bed, ready to float down into the trunk area when I open it.
#3 |
2007
RTL
Formal Black Join Date: Feb 2007
2nd for check around gasket as I had a small twig in mine and it created bad seal and leak. Cleaned out gasket and all is fine.....
#4 |
ROC Rank: Freshman
2006
RTS
Thanks for the responses -- I shall check that and keep that in mind for the future. Gene
#5 | |
ROC Rank: 2k Comma Club
2006
RTL
Nighthawk Black / Beige Join Date: Nov 2005
The water should drain in the front of the bed between the panel below the rear window and the truck bed floor. Take a hose and blast the crack between the panels to clear out the debris.
#6 |
ROC Rank: Freshman
2006
RTS
Thanks - will do.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| 2007 Water Leaks. Anyone Else ?? | Fish Daddy | Problems & Issues | 33 | 07-25-2007 06:23 PM |
| 07 water leaks poll | TheRidgester | Problems & Issues | 2 | 06-10-2007 10:21 AM |
| Water Leaks | Dave S | Problems & Issues | 113 | 03-19-2007 03:15 PM |
| No Water Leaks Yet But..... | Ridgetalker | Recalls, TSB's and Notices | 7 | 12-22-2006 06:10 AM |
| Water Leaks | swampler | The Ridge - Off-Topic Discussions | 2 | 02-18-2006 06:43 PM |
