| Notices |
#1 |
ROC Rank: Freshman
2008
RTX
Billet Silver / Gray Join Date: Jan 2008
Transmission fluid low
My Ridgeline has 24k on it and while in the garage I checked al the fluids since was on level ground. To my surprise the transmission fluid barely showed on the end of the dip stick. I looked under the trunk and cannot find any leaks or other signs of loss. Anyone have any thoughts as to the loss issue? "Supposedly" my dealer checked it during it's last oil change 2k ago.....
| Sponsored Links | |||
Advertisement | |||
#2 |
ROC Rank: Sophomore
2007
RTL
Formal Black |
Re: Transmission fluid low
You did check this while the truck was running correct?
#3 |
ROC Rank: Sophomore
2009
Bali Blue Pearl Join Date: Mar 2009
You mean of course after it was run until hot, then engine shut off for 60 seconds...
yes, if it was stone cold that might be why it is a little low. If it gets really low you will notice it when driving/shifting. No problem, just take her back and get it topped up. |
#4 |
ROC Rank: Freshman
2008
RTX
I did check it while it was warm.
#5 |
Moderator
2008
RTS
Billet Silver Metallic Join Date: Oct 2005
I've seen large variances in the level with temperature changes.
Here's the OM procedure:
#6 |
ROC Rank: Freshman
2008
RTX
the best way to add fluid still through the dip stick?
#7 |
Moderator
2008
RTS
Either that or via the fill hole. If you use the dip stick, be careful that you don't drip ATF fluid on the starter just below.
#8 |
ROC Rank: Sophomore
2009
for small quantities dipstick should be okay; get a good funnel. If you change your own ATF you need alot of patience with this method. Better to use proper fill hole, but do you have some good wrenches for this plug?
#9 |
ROC Rank: Freshman
2006
RT
Formal Black Join Date: May 2010
That is the way every other car I've ever worked on is, but not these evidently. I went to check mine today while it was running, and almost lost a finger in the radiator fan. As others may have found out, there isn't much clearance there. That is why I searched here on how to do it.
#10 | |
ROC Rank: 1k Comma Club
2010
RTL
Dark Cherry Pearl Join Date: Aug 2010
-- Matt, Connecticut 2010 Ridgeline RTL, BakFlip G2 cover, USA Spec iPod interface, Lund AVS Vent Visors from Burtman Industries, Lund AVS Hood Deflector from Tonneau Covers World and how to install, plated arch folding ramps from AllRamps, and a ROC Decal (white) (here) Are you paying the dealer beaucoup $$'s to change your cabin air filter? Check out this all-time great thread!
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| Transmission Fluid and Rear Differental fluid changed... | ukwes21 | Under The Hood / Performance | 2 | 06-23-2010 06:32 PM |
| Tranny fluid low, slight slipping | bbriscoe | Under The Hood / Performance | 15 | 04-07-2010 07:48 AM |
| Transmission Fluid Low | swedge | Under The Hood / Performance | 3 | 03-29-2010 02:19 PM |
| Low transmission fluid | Evo | Problems & Issues | 2 | 03-24-2008 09:11 AM |
| Help please: question about low power steering fluid level | Ridge | Problems & Issues | 8 | 11-03-2007 04:55 AM |
