Transmission fluid change - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Under The Hood / Performance
Notices
Thread Tools Display Modes
Old 10-20-2010, 02:20 PM   #1
customcracka
ROC Rank: Freshman
So I called the dealer and they want $90 for a drain and refill and $210 for a flush. Which one should I choose? My 06 RTL has about 56,xxx on it and I have no idea if it's ever been done before (but I doubt it). I was thinking of doing the drain and refill myself so I also asked about how much the ATF costs and how much it takes and they said $8 a quart and it takes about 3 quarts. They said the flush takes about 12 quarts! Is there a drain plug on the pan? What about a filter?
customcracka is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-20-2010, 02:22 PM   #2
zepman881qyk
ROC Rank: Sophomore
2007 RT
Formal Black
zepman881qyk's Avatar
Re: Transmission fluid change
Do the drain and fill. Most machines that do the flush operate at a higher psi than the A/T operates at and that could cause damage.
"Now don't get all nutty, let's do this methodically" W.C.L.
1999 Honda Shadow ACE
2007 Ridgeline RT
2010 Odyssey EXL-RES
Honda Mower (push)
zepman881qyk is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 02:41 PM   #3
rollinhonda
ROC Rank: Comma Club HOF 10,000+
2010 RTL
Dark Cherry Pearl
rollinhonda's Avatar
Some recommend the 3X drain and fill (drain it, run it a few minutes, drain it again, etc.) to get out about 90% of the fluid. I prefer to do the 1X and do it more often, like every 15K or every other or 3rd oil change.
Honda North, ClovisCA Sales 4 Service 3.5 (out of 5)
Private Mechs:
Kurata Automotive, Fresno
Charlies Automotive, Clovis
Home of the Free, because of the Brave!
rollinhonda is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 03:31 PM   #4
speedlever
Moderator
2008 RTS
Billet Silver Metallic
speedlever's Avatar
Ditto here.
There are plenty of threads here that show how to do the tranny fluid change. Nothing to fear if you can change oil. The hardest thing to do is break the filler bolt free. Make sure you have some quality tools else expect to twist off some el cheapos in the process. ALWAYS loosen the fill bolt before you drain a fluid. *ALWAYS*
Here's an excellent tutorial for the A136 service... which is more than you're asking... but may be what you need to do if you have questions about where your RL is service-wise.
Ask away if you have questions. Plan about 1/2 a day for this if you DIY. Probably won't take that long... but the first time everything takes longer.. plus the setup and cleanup takes some time too. And the savings are significant. I saved about $400 recently doing this to our Pilot (compared to the dealer quote for a 60k mile service).
Edit: you'll need 4 quarts of ATF-Z1 (Honda fluid only), 1 qt of 80w-90 hypoid gear oil (any brand), and a gallon of VTM-4 fluid (absolutelty no substitutes) for the A136 service. Whatever tools you use for the VTM-4 fluid change (tubing, pump, etc.)... keep it dedicated strictly for VTM-4 fluid. It does *not* like to be contaminated.
If you buy enough at a time, your dealer may be willing to give you a nice discount. My local dealer has done so in the past. Never hurts to ask.
Edit2: Honda frowns on tranny flushes for whatever reason. I've seen it reported that flushing the tranny can mess up the internal filter (not part of the transmission service.) I don't know what the truth is. So I will sometimes do a tranny fluid change at every oil change... or maybe every other oil change... whatever I decide at the moment... until I have a few done in a reasonable time frame.
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 05:00 PM   #5
Lightship
ROC Rank: Freshman
2008 RTL
Formal Black
This was a great reference, I got my 2008 Ridgeline with 14,000 miles recently, there was no indication on the history that fluids were replaced other than the oil. Since I have no indication on what driving conditions it was operated in over the last few years and the dealer has agreed to replace the fluids VTM 4 do you think I should have the ATF-z1 and haploid gear oil replaced at the same time if the dealer will cover the cost? No sense waisting resources, only drive 5000 miles per year.
Thanks for your input, Maintence Minder says 70% on oil, and I've bought enough Mobil One for 3 Oil Changes, should I convert after 3000 miles from the last Oil Change?
Lightship is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 05:39 PM   #6
zepman881qyk
ROC Rank: Sophomore
2007 RT
Formal Black
Yeah, I would go with the 1X more frequently also. That is sound advice.
2007 Ridgeline RT
Honda Mower (push)
Old 10-20-2010, 08:28 PM   #7
speedlever
Moderator
2008 RTS
speedlever's Avatar
Well rats. I just had a computer crash after typing a lengthy response.
Long story short, if you can't get the service records for your RL, I would assume that you're on your 3rd oil change with 70% remaining at 14k miles. The mx schedule calls for VTM-4 service at 15k miles. However, it's been my experience that you will get the -6 callout for VTM-4 service when you're due the 2nd oil change.
IE, you should see an A1 callout at 5-8k. And a B6 callout at 10-15k. Much depends on the driving environment the RL sees (road or city, hot, rapid starts, etc.) And as usual, YMMV.
Without service records, I'd go ahead with the VTM-4 fluid change by 15k and leave the MM alone and watch for the next callout for the -6 service. You might eyeball the rear diff drain and see if the white paint marks line up. If not, it's a good bet the rear diff (VTM-4) has been serviced. But still.....
Per the schedule (normal service), the first tranny service (with accompanying transfer assembly fluid change) happens at 45k miles. I serviced my tranny at 17k miles and am glad I did due to a significant amount of debris on my mag plug. I'll likely do another tranny drain and refill at the 30k mark.
Use your own judgment on the tranny service at 14k. It's way early (as was mine). Also I wouldn't worry with the transfer assembly (hypoid gear oil) for a good while yet... maybe at the 30k point or at least by the 45k point.
On the oil change to Mobil 1, personally I'd wait until the MM calls for your next oil change.
Edit: or as hondaloyal correctly points out below, at 12 months from your last oil change if the MM hasn't called for it.
See the note at *1:
Old 10-20-2010, 09:50 PM   #8
hondaloyal
ROC Rank: Sophomore
2009
Bali Blue Pearl
hondaloyal's Avatar
Normally; but oil should be changed annually whether you hit the MM or not...if you are only doing 5K a year; change it every year.
hondaloyal is offline   Reply With Quote Quick reply to this message
Old 10-21-2010, 05:26 AM   #9
speedlever
Moderator
2008 RTS
speedlever's Avatar
Good catch. I missed the low annual mileage.
Old 10-21-2010, 06:24 AM   #10
hondaloyal
ROC Rank: Sophomore
2009
Bali Blue Pearl
hondaloyal's Avatar
Maintenance Minder was not designed for low mileage people. Perhaps in the next revision it will have two MM's; one for oil and one for all the other codes... ?
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Transmission fluid change speedlever Under The Hood / Performance 14 03-11-2013 02:24 PM
How to change transmission fluid and transfer gear box? ZowieK Under The Hood / Performance 7 07-11-2011 09:30 AM
Transmission Fluid: To change or not to change? LouisB Miscellaneous/General Honda Ridgeline Discussions 23 11-09-2009 05:29 PM
Transmission fluid change?? k co 3/7 Mods, Installs and How-To's 2 05-13-2009 03:03 PM
Transmission Fluid Change mugen1 Miscellaneous/General Honda Ridgeline Discussions 7 11-06-2007 11:29 AM
