All 3 power outlets kaput after oil change - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 12-28-2010, 07:38 PM   #1
GAbeast
ROC Rank: Freshman
2008 RT
Billet Silver / Gray
I took our 08 ridgeline into the dealership for our first oil change since we've owned it, when I got it back I have no power in any of my power outlets. I know they are two different fuses so I don't think that is the problem. I know they ran a battery test that came out low. The rating is at 550 cca which is a little lower than 12.60v, at least that is what the reading they gave me says. So I guess my question is can a low charged battery make the power outlets not work, or is there something the technicians can do on a battery test that would blow out both fuses on my power outlets?
Any help would be appreciated.
Thanks!
GAbeast is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-28-2010, 09:54 PM   #2
mevers
ROC Rank: 1k Comma Club
2008 RTL
White / Beige
mevers's Avatar
Re: All 3 power outlets kaput after oil change
I don't have the answers to any of your questions, but if your dealer ran a test on the battery and now none of your outlets work I'd take it back to them ASAP, to prevent them from blaming it on something else.
mevers
"A good plan violently executed now is better than a perfect plan executed next week." George S. Patton
mevers is offline   Reply With Quote
Old 12-29-2010, 07:49 AM   #3
TAILDRAGGER-J3
ROC Rank: Freshman
2006 RTS
Redrock Pearl / Beige
I second the motion. Like you said there are two different circuits to the power outlets. I'd take it back and ask them what they did to blow both of them.
2006 Redrock Pearl RL, Easymount Ipod adpater, RoadyII XM receiver, (both in space below radio),
Trifecta Bed Cover, 12 volt outlet in bed side, and dual-band Ham radio in the center console.
Honda Lawnmower & Honda GL500
TAILDRAGGER-J3 is offline   Reply With Quote
Old 12-29-2010, 09:30 AM   #4
Pizza Man
ROC Rank: 7k Comma Club
2006 RTL
Steel Blue / Gray
Pizza Man's Avatar
As this is a somewhat new to you vehicle, is it safe to assume all the outlets were working and that you realize all the outlets are dead unless the ignition switch is on?
BACON IS THE REASON I'M NOT A VEGETARIAN!
Pizza Man is offline   Reply With Quote
Old 12-29-2010, 04:07 PM   #5
GAbeast
ROC Rank: Freshman
2008 RT
Thanks guys, I probably should have turned around soon as I noticed, but it's the wife's truck and I wasn't sure exactly if they worked when I took it in. She said both of the front power outlet worked the day before. I tried two different chargers while the truck was running with nothing worked, then used them on my civic and both worked fine. I will double check again to make sure I didn't do anything stupid, I've been known to overlook things. I'll let you know the verdict when we take it back in tomorrow.
Thanks for the help,
Kevin
Sponsored Links
Advertisement
BB code is On
Forum Jump
power outlets venag1 First Generation (2006-present) 12 03-20-2012 01:46 PM
power outlets moyockredrock Problems & Issues 8 02-01-2008 02:56 PM
Power Outlets alanderego Interior 10 09-24-2006 11:50 PM
Power outlets VillagePub Problems & Issues 7 07-14-2006 05:38 PM
Power outlets gbldrt Shoppin' and Test Drivin' 4 04-16-2006 11:35 AM
