Vtm 4 - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 12-30-2010, 03:36 AM   #1
Melvin8078
ROC Rank: Freshman
2009 RTS
Sterling Gray Metallic
Vtm 4
Hey guys I need your opinions. I live in Edmonton, Canada and lately my VTM4 on the dash is lighting up. This only happens when its cold outside. I took it to the dealership and they said that it could be a bad control module of some sort. Anyone else have experience this on theirs? I almost got in a heated argument with the service advisor about it. He asked me if I had any after market parts on the truck. He mentioned all 3 that i had which was HIDs, HU, and cell charger. All 3 were visible and told me that it could be those that is causing the problem. Apparently those 3 are emitting a RF signal that's causing the VTM to light up on the dash. I looked at him...WTF do you think I'm stupid?! Make the long story short, he went back to the shop foreman to find out exactly what went on the diagnostic. He came back and said that it threw a code that it light up but could not determine the cause. Of course I have to bring it in when the light is on and hopefully then can fix the problem.
So please anyone with an answer as to what the problem is let me know. I want to tell them exactly what needs to be done and I'm not paying anything that's under warranty. They better not use the BS about me having aftermarket parts on my truck!
Melvin8078 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-30-2010, 12:29 PM   #2
Goodview
ROC Rank: Senior
2006 *Not a Ridgeline Owner
Other
Re: Vtm 4
He could very well be correct. The Odyssey had a problem with the alternator about 6 years ago that was failing to filter electrical noise (from the cooling fan) and screwing up the computer's ability to monitor several functions. There's a TSB about it here.
I've heard of CR-V owners with 'interference' problems caused by cheap (usually Asian) add-ons, especially things they plugged into the accy socket. See post number 9, below for links.
.... BTW, you didn't mention your mileage and it is slippery under foot these days... If your VTM-4 fluid is overdue / contaminated with moisture, could that be your problem? My rear diff has 'grunted' a few times just since the recent snow storm.... Changed the fluid and all is quiet.
Goodview is offline   Reply With Quote
Old 12-30-2010, 12:50 PM   #3
Ian Brantford
ROC Rank: 1k Comma Club
2009 VP
Re: Vtm 4
Did the service advisor literally say that it was RF interference, or electrical interference? There is a big difference. Electrical interference could happen if the different power circuits are not isolated from each other -- for which I am not qualified to judge. Maybe others here are. For RF interference, that would have to be some pretty powerful broadcast (or a very vulnerable VTM system) to be an issue.
However, in either case, you can disconnect or undo all three modifications to see whether there is any merit to this claim. Hopefully you have the original headlights. For the HU and charger, completely disconnecting them would be required, not just turning them off.
Yes, disconnecting all your mods might be a bother, but it would provide objective evidence.
Ian Brantford is offline   Reply With Quote
Old 01-01-2011, 06:51 PM   #4
RickC5
ROC Rank: Junior
2010 *Former Ridgeline Owner
Other
Re: Vtm 4
Please check out this thread, as it is most enlightening:
http://www.ridgelineownersclub.com/f...ad.php?t=38084
BTW--I know you don't want to hear this, but I can't count the number of times I have had to remove a mod to one of my cars because the mod interfered with something else in the car. This happens because the mod designers/manufacturers/suppliers simply do not test their mod(s) on every make & model of vehicle out there. They test a few and hope nothing happens to the rest. Yeah, right.
A good example is that my Escort Passport radar/laser detector will SCREAM out a Laser warning every time I honk the horn in ANY Honda vehicle I have owned. It doesn't do this in Toyotas, ever. Escort knows about this and can install a fix/upgrade for $50. Nah, I'll just deal with it.
I'm waiting for someone to install a mod that shuts down the brakes so we can witness the battle over who pays. Would be interesting.
RickC5 is offline   Reply With Quote
Old 01-01-2011, 08:19 PM   #5
drdave00
ROC Rank: Freshman
2010 RTL
Billet Silver / Gray
Re: Vtm 4
I have a set of Beamer HID's with the low and high beam in the same bulb.(motorized) I also have a Kenwood DNX9960 installed.I have no issues with the RL electronics,I do have an issue with the bluetooth for the phone as the people i call say they cannot understand me and lots of background noise. If I shut the truck off and use the phone it sounds perfect to my callers. from idle up is noisey and unusable. I hope this gives you some info on your vtm issue as mine works fine.I have also installed a Passport Qi45 installed and I have not had any issues.
drdave00 is offline   Reply With Quote
Old 01-03-2011, 08:07 PM   #6
Melvin8078
ROC Rank: Freshman
2009 RTS
Re: Vtm 4
hey guys... I only have the problem when its cold. I do remember even before I put on the "mods" it lit up. It was around -40 here in Edmonton and the vtm4 lit up. I also noticed that after 15 minutes of driving and then shutting of the truck, it does not come back on. The other thing that SA said was low battery charge, could that be a possibility?
Old 01-04-2011, 06:05 AM   #7
MikeT
Mall Ninja Moderator
2006 RTL
MikeT's Avatar
Re: Vtm 4
Bad batteries create all kinds of weird reactions from the Ridgeline...
2006 Ridgeline RTL, Silver with roofrack.
2000 Accord V6 EX, White no roofrack.
MikeT is offline   Reply With Quote
Old 01-05-2011, 12:06 PM   #8
PLF
ROC Rank: Sophomore
2006 RTS
White / Beige
PLF's Avatar
Re: Vtm 4
I agree with this. I also noticed that when offroading the vtm-4 lights comes on much later when the fluid as been changed recently.
2006 Honda Ridgeline RTS (Daily Driver)
- SkyJacker Lift
- 265/65-17 Fuzion XTI
- 265/70-17 WinterForce Winter Tires
- Front SkidPlate
- 4500k HID's
1999 Eclipse GS-T Spyder (400whp Weekend Fun)
PLF is offline   Reply With Quote
Old 01-05-2011, 12:58 PM   #9
Goodview
ROC Rank: Senior
Other
Re: Vtm 4
Here's a few examples of HID electrical interference whacking various other systems on various modern vehicles.....
Electromagnetic Interference with new HiD kit!
Newly installed HID's causing TPMS light to come on?
HID KIT & FM Radio Interference
HID Headlight interference issues?
Old 01-09-2011, 12:15 PM   #10
silveridge
ROC Rank: Junior
2007 RTX
Billet Silver Metallic
silveridge's Avatar
Re: Vtm 4
From the ’06-'07 RL Service Manual, p. 15-4 (general troubleshooting information for the VTM-4 Indicator):
The VTM-4 Indicator comes on under certain conditions even if the 4WD system is working normally. Here are some examples:
  • When you use high-powered wireless equipment such as a CB or Ham radio in the vehicle.
  • When you keep spinning the front wheels while the vehicle is stuck in sand, mud, snow, etc.
  • When the battery voltage suddenly drops below 8 volts or rises above 16 volts.
After the VTM-4 indicator comes on, it stays on until you turn the ignition switch off.
Don't know if any of these are causing your problem, Melvin, but this may of assistance to others with unexplained VTM-4 Indicator illumination.
silveridge is offline   Reply With Quote
Sponsored Links
Advertisement
BB code is On
Forum Jump
Vtm noise!!! DIGIO40 Problems & Issues 25 12-29-2009 05:18 PM
VTM Question outtaline Problems & Issues 3 03-16-2008 04:21 PM
Vtm 4 Steel Blue RTX Problems & Issues 2 08-17-2007 07:44 PM
Vtm-4 kwoodman Miscellaneous/General Honda Ridgeline Discussions 1 03-20-2007 06:18 AM
Honda VTM-4 Fluid same as Acura VTM-4 Fluid? zuhl Under The Hood / Performance 12 10-01-2006 10:13 PM
