VTM 4, VSA, ABS, Brake lights wont go out - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 01-10-2011, 09:30 AM   #1
911rcr
ROC Rank: Freshman
Hi Guys,
Had my 2006 RTL parked at the airport for a few days and when I started it up last night, these four lights stayed on. Tried a restart to no avail. Tried both VTM 4 and VSA buttons and nothing happens. Same thing again this AM.
Any thoughts on what would trigger all 4 lights?
Thanks!
911rcr is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-10-2011, 10:17 AM   #2
cdepuydt
ROC Rank: 6k Comma Club
2006 RTL
Billet Silver / Gray
Re: VTM 4, VSA, ABS, Brake lights wont go out
Is your battery in good shape? I see you have an '06 and just wondering if your battery is the original or not. Seems as if a weak battery will cause all sorts of issues and various lights coming on for no reason is one of them.
Golf and Sex - Two things you don't have to be good at to enjoy.
RTL w/Nav and Sunroof, Running boards, Bug deflector, Leer Cap, OEM Hitch, Auto-Dimming Rear View Mirror, Weathertech Floor Mats, OEM Fogs w/Painted Bezels, OEM Side Door Protectors, '10 Pilot Touring Wheels, Kumho Road Venture KL61 Tires (New 05/14), new Monroe OE Spectrum Struts (New 05/13), RTX/Accessory Grill, Raybestos Professional Grade Rotors/Akebono pads (New 06/15), and Figs Hood Prop Kit.
cdepuydt is offline   Reply With Quote Quick reply to this message
Old 01-10-2011, 10:38 AM   #3
IanRTL
ROC Rank: 7k Comma Club
2007 RTL
Nimbus Gray Metallic
x2 on the battery. Those are the lights that come on when your battery is drained to just before the point of not being able to keep up with the electrical load needed by the truck. If you have the original battery, I'm very surprised it even lasted this long. You may not have problems with it starting or running just yet, but it IS on its way out. Go to your local auto parts store and have them test your electrical system and pick up a new battery. You can get one for around $90 with your core. I've had very good luck with Autocraft Gold batteries in the past and I'll be replacing mine shortly with one of them.
Westin black running boards, AVS vent visors, AVS bug shield, blue LED interior switches, LED interior/exterior lights, GE Nighthawk Sport headlight bulbs, Weathertech floor mats, Extang Trifecta soft tonneau cover, Pioneer AVH-P4400BH bypassed head unit, Metra Axxess ASWC, Jensen Carbon 65C components, Jensen Power 400 2ch bridged amp, 10" Boss Onyx shallow sub in custom behind-seat enclosure, FatMat sound deadening, Pyle backup camera
IanRTL is offline   Reply With Quote Quick reply to this message
Old 01-10-2011, 11:23 AM   #4
911rcr
ROC Rank: Freshman
Great input guys. To my knowledge it is the original battery. I guess that combined with the colder temps and the truck sitting for a few days may have been enough.
One new battery, coming up!!
Thanks!!
Old 01-10-2011, 05:13 PM   #5
911rcr
ROC Rank: Freshman
Unhappy Re: VTM 4, VSA, ABS, Brake lights wont go out
Well, a brand new Dekka battery later and same thing. Needed to be replaced though.
Any additional thoughts?
Thanks!
Old 01-11-2011, 10:03 AM   #6
IanRTL
2007 RTL
Thanks!
It may take a little while for the systems to learn that the new battery has been installed. Drive it a bit longer (a few days or so) and see if the lights go out. If they don't, I would suggest getting your electrical system tested.
Old 01-11-2011, 04:25 PM   #7
ladaca
ROC Rank: Sophomore
2007 RTL
Steel Blue Metallic
ladaca's Avatar
Check the Alternator. I had a similar problem and had to replace both a defective battery and a defective alternator. Does'nt cost anything to have the alternator checked at an auto parts store.
Dan
2007 Steele Blue Metallic RTL with Nav, Moonroof, Running Boards, Mud Flaps and Roof Rack.
Member # 21071
ladaca is offline   Reply With Quote Quick reply to this message
Old 01-12-2011, 10:09 AM   #8
Lancelot
ROC Rank: Freshman
2008 RTX
Billet Silver Metallic
Interesting, I ran into this problem last winter it turned out to be a bad front wheel speed sensor, Honda replaced under warranty and everthing was normal again.
Lancelot is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your Ridgeline?
Model
What model Ridgeline do you drive?
Color
What color is your Ridgeline?
Can you spell?
What letter in the alphabet is the fifth character of the word "Honda Ridgeline"
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
VSA, Exclaimation and ABS dash lights on triggerhappy Problems & Issues 15 08-04-2014 03:31 PM
VSA, VTM, TMPS, ABS, Brake warning lights Caspwy Problems & Issues 11 11-27-2010 08:18 PM
VTM4, Exclamation, VSA, and ABS lights all on??? zmil Problems & Issues 1 09-20-2010 09:28 AM
ABS and VSA lights are on and gear shift won't move denise00867 Problems & Issues 5 09-12-2009 12:40 PM
ABS, VSA lights just turned on at 65mph arcon72 Miscellaneous/General Honda Ridgeline Discussions 11 11-04-2005 05:26 PM
