Help with idle on Craftsman snowblower - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > ROC Member Central > The Ridge - Off-Topic Discussions
Notices
Thread Tools Display Modes
Old 01-15-2011, 02:49 PM   #1
MooseMan
ROC Rank: Freshman
2006 RTS
Alabaster Silver Metallic
Hey backyard motorheads...
I have this Craftsman snowblower I got from a neighbor moving out. Model 247.888160. Works fine, except the idle is terrible. Revs up and down at any throttle preset. Engine speed normalizes and runs fine when under load (auger engaged and throwing snow). Here's a video so you can hear it.
http://www.youtube.com/watch?v=pWZQMjoMGI4
Any suggestions?
I live at ~7500 feet. Wouldn't expect altitude to be causing this sort of flux.
Thanks!
MooseMan is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-15-2011, 03:39 PM   #2
Goodview
ROC Rank: Senior
2006 *Not a Ridgeline Owner
Other
Re: Help with idle on Craftsman snowblower
Most motors that size are governed by a 'wind vane' that connects by a spring to the throttle. If somebody has gotten some lube on the shaft of the vane, or if the spring is just dragging against something, the idle will go wild. It's probably a Tecumseh, but the throttle part is much the same on Briggs & Scrapiron. My Craftsman about 24 years old and was owned by a guy who claimed he only blew snow on Sunday.
Yeah, I know.....
If a visual proves the spring is OK (don't stretch it) six or so screws and the blower cover is off, then remove the little shaft and clean it as well by running a Q-tip through the plastic vane's hole. Use WD-40 as a solvent or maybe just alcohol cuz it should be un-lubricated when you're done. Use a heavy toothbrush, air hose and various poking tools (bicycle spoke) to clean out any oily debris that's down in between the engine's cooling vanes.
Goodview is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 03:58 PM   #3
MooseMan
ROC Rank: Freshman
2006 RTS
Yeah, I know.....
Thanks! I will look into that.
Old 01-15-2011, 05:02 PM   #4
MooseMan
ROC Rank: Freshman
2006 RTS
OK. I've located the spring, which looks to be in decent condition. So assuming you are correct and that the vane is in need of cleaning. When you say take the blower cover off, do you mean the flywheel cover where the pull-start is attached? Or are you referring to something else?
Here's what I'm looking at
Old 01-15-2011, 06:24 PM   #5
qlake
ROC Rank: Junior
2007 RTL
Steel Blue / Gray
qlake's Avatar
That is a very common issue with the Tecumseh engines. Under a load they usually work well. Live with it or try replacing the carburetor.
qlake is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 07:09 PM   #6
Ourfarm09
ROC Rank: 4k Comma Club
2011 RTS
Bali Blue Pearl
Ourfarm09's Avatar
If the above suggestions don't work, try some stabil in your fuel. Ethanol really messes with small engines.
aka Ron
U.S. Army (retired) , ASE Certified
AVS ventvisors, ROC decal,
Ourfarm09 is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 08:00 PM   #7
bikerbudmatt
ROC Rank: 1k Comma Club
2010 RTL
Dark Cherry Pearl
bikerbudmatt's Avatar
I notice that kind of fluctuation on idle with my Craftsman (looks pretty much identical to the one in the video; purchased 2003), but not to that degree and only for a minute or so while warming up. And the issue disappears under load. Once it's warm, the idle is steady as a rock.
I would endorse the Stabil suggestion. Maybe a 1/4-ounce in the tank with a fill-up. It's a good idea to have your fuel Stabil-ed in the gas can anyway.
Matt, Connecticut
2010 Ridgeline RTL, BakFlip G2 cover, USA Spec iPod interface, Lund AVS Vent Visors from Burtman Industries, Lund AVS Hood Deflector from Tonneau Covers World and how to install, plated arch folding ramps from AllRamps, and a ROC Decal (white) (here)
Are you paying the dealer beaucoup $$'s to change your cabin air filter? Check out this all-time great thread!
bikerbudmatt is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 09:01 PM   #8
MooseMan
ROC Rank: Freshman
2006 RTS
Good advice all around. I'll throw some of that in there... I've also put some (sea-foam?) through. But am going to try and locate the vane. Not that it really matters, the darn thing works. But it's the principal of the matter!!!
While I'm in there it's half tempting to tweak the arm that connects the carb and get a few more RPM's out of the thing for those big snowfalls. Got to be careful, but hey that's what the Amsoil is for, right?
Old 01-15-2011, 09:10 PM   #9
07inny
ROC Rank: Junior
2007 RTS
Aberdeen Green Metallic
Send a message via AIM to 07inny
It could also be a clog in one of the jets in the carb. If you can remove the carb and take the bowl off of the bottom and take a paper clip or a pin and try to clean them out. Also try some carb cleaner and blow some air through them. That might work also.... Good Luck
My Car
2007 Ridge RTS Bought new 02/07/09
Wifes Car
2007 Pilot EX Bought New 11/14/06
My Toy
1986 300 ZX 2+2GLL 54000 Original Miles Fair Weather Car
07inny is offline   Reply With Quote Quick reply to this message
Old 01-16-2011, 06:01 PM   #10
Goodview
ROC Rank: Senior
Other
After seeing the photo, I think yours has the governor inside the crankcase, not it the air stream.
I can spot the lever on the right side of your float bowl, which loads the spring. If you're low on oil you may have the same idle problem.
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Rough idle and 15mpg TexFromKansas Problems & Issues 14 03-27-2013 03:44 PM
Engine noise on idle Shutterbug Problems & Issues 15 03-12-2011 04:42 PM
Unexpected acceleration from idle FlaDan Problems & Issues 20 09-03-2007 10:51 PM
A/C cycling on/off at idle TheRidgester Problems & Issues 11 08-09-2007 06:57 PM
Movement at idle speed nwdiver Under The Hood / Performance 2 05-13-2005 03:46 PM
