Making noise when wheels are turned - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline > First Generation (2006-present)
Notices
Thread Tools Display Modes
Old 02-02-2011, 08:43 AM   #1
109TR
ROC Rank: Freshman
2006 RT
Billet Silver Metallic
My 06 has started making a humming type noise that almost sounds like the power steering is going bad when the wheels are turned either left or right and only makes the noise when i give it gas. the more the wheels are turned the louder it gets. I do believe it has something to do with the rear / limited slip but i'm not sure. Has anyone come across this yet?
109TR is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-02-2011, 09:03 AM   #2
speedlever
Moderator
2008 RTS
speedlever's Avatar
Re: Making noise when wheels are turned
How long since your VTM-4 fluid was changed? How many miles on your 2006 RL?
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is offline   Reply With Quote
Old 02-02-2011, 09:04 AM   #3
Goodview
ROC Rank: Senior
2006 *Not a Ridgeline Owner
Other
It's been covered, and yes, you need a fresh load of VTM-4.
Lots of threads explain the problem. Fix is cheap and not too hard to DIY.
Love your truck...Read the Owner's Manual
Goodview is offline   Reply With Quote
Old 02-02-2011, 09:43 AM   #4
109TR
ROC Rank: Freshman
2006 RT
just turned 100K. thanks for the quick response guys. VTM-4 fluid has never been changed. I will get on that pronto.
thanks again
D
Old 02-02-2011, 10:01 AM   #5
speedlever
Moderator
2008 RTS
speedlever's Avatar
In 100k miles, the VTM-4 fluid has never been changed?
Jeepers. What maintenance *has* been done on your RL? Did you buy it new?
Old 02-02-2011, 04:07 PM   #6
109TR
ROC Rank: Freshman
2006 RT
Yes i bought it new. I have changed the brakes and tires and the oil has been changed every 3000 to 5000 miles. It runs great. It is now obvious that the VTM oil should have been changed.
D
Old 02-02-2011, 05:04 PM   #7
speedlever
Moderator
2008 RTS
speedlever's Avatar
Good luck to you. I hope your rear diff is ok.
But you really need to take a look at the mx schedules for what should have been/needs to be done. It sounds like you have ignored the MM system. (which is ok, but you should have been following the mx schedule if so).
I trust you know that you have a major maintenance interval coming up at 105k when the water pump, timing belt, spark plugs, idler pulley, etc. need to be changed.
How about the tranny fluid? Transfer assembly gear oil? Air and cabin filters? Brake fluid flush?
Old 02-02-2011, 07:24 PM   #8
109TR
ROC Rank: Freshman
2006 RT
I am planning my timing belt at this time. i'm trying to find a reasonable yet competent mechanic to do it. I've worked on cars my whole life but it's not very often that one changes the transfer case oil if at all. It didn't dawn on me about being front wheel drive and it's always engaged. Not much i can do except change oils now.
Could you please clarify mx schedules? is that a reference to maintenance?
what is the MM system?
tranny fluid has not been touched. I was going to add some Lucas to it. I've seen too many trannies with high miles get ruined by changing the fluid.
Transfer assembly gear oil has not been changed
Air and cabin filters have not been changed
Brake fluid flush has not been done. Is this one even necessary?
I know how to work on cars but these terms are new to me.
I know, i should have been on this sooner.
thanks for all the help guys
D
Old 02-02-2011, 08:13 PM   #9
speedlever
Moderator
2008 RTS
speedlever's Avatar
No offense intended, but assuming you're serious and not jerking my chain, it's time for you to do some reading:
Normal and severe maintenance schedules
Crush washers and torques
What not to have done to your Honda
Maintenance minder basics
A136 maintenance thread
Cabin filter replacement
One way to change VTM-4 fluid. Personally, I use a hand pump that fits the gallon jug.
MM reset procedure
Suggestions:
use a good quality oil filter... not the Honda A02 filter. Use the Honda A01 or Napa Gold/Wix/Purolator equivalent.
Use Honda fluids for all fluid changes except for hypoid gear oil for the transfer assembly and motor oil (but stick with 5w-20 SAE).
VTM-4 fluid does *not* like to be contaminated. Make sure the equipment you use to change it is clean of any residue of any other fluids. I dedicate pumps and tubing for this process and don't use it with anything else.
Brake fluid is hygroscopic. Change it every 3 years to get rid of any contaminants and water it may contain.
Let us know if you have any questions or problems.
Edit: I strongly recommend against adding any additives to the oil or transmission fluids. Do a search here on additives for more info if interested in why.
Old 02-02-2011, 09:02 PM   #10
109TR
ROC Rank: Freshman
2006 RT
Your chain has been jerked! HA HA HA!
Actually This is great help. I will read all the information provided and I will start buying all the fluids and things i need and in the next two weeks i will try to get as much done as possible.
Man, all i wanted was to fix a noise. I do love the truck though.
thanks again.
D
Sponsored Links
Advertisement
BB code is On
Forum Jump
Rear ended and backup sensor making noise Leo Problems & Issues 1 01-05-2010 05:29 PM
RL just turned 4 yrs old c_duncan_pe Miscellaneous/General Honda Ridgeline Discussions 6 08-24-2009 05:38 PM
Brake Pedal Making "hollow" Noise jeffiam Interior 22 02-06-2009 08:36 AM
Navi turned blue. Gotstacks Problems & Issues 1 11-07-2006 05:16 PM
