Check Engine Light? - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 05-20-2011, 02:22 PM   #1
psiclist
ROC Rank: Freshman
2007 RTX
Steel Blue Metallic
psiclist's Avatar
Check Engine Light?
Sorry if this is a duplicate. I searched but found no post on this. Anyway, my yellow engine shaped "malfunction indicator lamp" came on recently. It stays on. I disconnected the battery and after reconnecting it still stays on. The manual says it has to do with emissions. My last car, an Escort had that light come on and I never did anything about it. It was on for years until I sold the car. Do I need to worry about this or race down to the Mechanic? I replaced the battery a couple of weeks before it came on the first time. Any ideas? thanks!
psiclist is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-20-2011, 02:25 PM   #2
Ourfarm09
ROC Rank: 4k Comma Club
2011 RTS
Bali Blue Pearl
Ourfarm09's Avatar
Re: Check Engine Light?
You can go to most any auto parts store and have them read the engine codes for you then decide from there what you want to do.
aka Ron
U.S. Army (retired) , ASE Certified
AVS ventvisors, ROC decal,
Ourfarm09 is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 03:27 PM   #3
laserguy
ROC Rank: 5k Comma Club
2006 RTL
Other
laserguy's Avatar
Yeah, check engine could be over 30 different things, simple issues or major issues. A scanner to read the codes is a good start. Sometimes you need to disconnect the battery for over a minute to clear the code, and if it does, it has some good chances to show up just miles after you reset it.
laserguy is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 09:06 PM   #4
Goodview
ROC Rank: Senior
2006 *Not a Ridgeline Owner
Other
When you get the code, write it down, tell it to us.
What you driving...Where are you ? If you're in Canada you may want to just BUY a code reader since there aren't many places that do it for free.
Now that you've disconnected the battery you should probably redo your idle learn procedure, or your mileage may go down the toilet, but then again, it may get better.
Last edited by Goodview; 05-20-2011 at 09:19 PM. Reason: If you're in Canada ......
Goodview is offline   Reply With Quote Quick reply to this message
Old 05-24-2011, 11:35 AM   #5
psiclist
ROC Rank: Freshman
2007 RTX
Steel Blue Metallic
psiclist's Avatar
Thanks for all the replies. I did go to an auto parts store. Got the reader and it said "knock sensor circuit 1 bank 1" not necessarily in that order. The guy there knew what it was, and I got the new part. Now, where does it go? He said it is on the engine somewhere. And easy to replace. Just screw it in. The number 1 implies to me that there are more than one sensor, and more than one place that they go. Is there a manual or diagram online that will tell me where to find the one that needs to be replaced? Again, THANKS!
Old 05-24-2011, 11:40 AM   #6
laserguy
2006 RTL
Other
laserguy's Avatar
Did it clear or reset the error or check engine light at least temporarily?
Old 05-24-2011, 12:12 PM   #7
psiclist
ROC Rank: Freshman
2007 RTX
Steel Blue Metallic
psiclist's Avatar
Uh, no I don't think it did. I never noticed that the light was off while I was driving after that.
Old 05-24-2011, 12:47 PM   #8
Goodview
ROC Rank: Senior
Other
Did you write the CODE down? The interpretation could be (often) incorrect.
Excellent HONDA parts diagrams and part numbers can be found at various online parts suppliers. www.hondapartsdeals.com is just one of them that has good diagrams. It's a good site to BOOKMARK.
Those parts diagrams are almost as handy as owning the (expensive) service manual, and it's FREE.
Old 05-24-2011, 01:03 PM   #9
zroger73
2014 SE
Crystal Black Pearl
zroger73's Avatar
Ugh. It bugs me when these minimum-wage cashiers read a keyword off a scan tool and sell people a part then refuse to refund it if it doesn't fix the problem. It's extremely rare that a knock sensor would be bad. It has no moving parts to wear out and is not exposed to engine fluids. It's essentially a microphone that listens to frequencies that are associated with detonation (pinging, knocking). If this is the correct code description, notice the definition is knock sensor circuit, not knock sensor. Although it's possible it's the sensor itself, I would suspect a wiring issue before I would suspect the sensor. You can "rent" access to the Honda or aftermarket service manuals or you can purchase the read thing through Helm. It might would have already paid for itself by the time you get done spending hours throwing parts at this issue.
Edit: Here is a thread you might be interested in.
Former vehicles: '10 Ridgeline, '09 Civic, '09 Silverado, '99 B2500, '08 G35, '07 Ridgeline, '06 Accord, '96 Cougar, '73 F-100, '00 Cavalier, '93 Cougar, '84 Fiero, '99 Regal, '98 Neon, '96 Ranger, '95 Probe, '94 Escort, '92 Grand Am, '86 Escort, '69 Skylark
zroger73 is offline   Reply With Quote Quick reply to this message
Old 05-24-2011, 02:16 PM   #10
Goodview
ROC Rank: Senior
Other
___D_O_U_B_L_E_ __ P_O_S_T_ somebody please delete ....
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Check Engine/VTM-4 light on... CrowMagnumMan Problems & Issues 11 11-07-2013 10:40 AM
check engine light big c Miscellaneous/General Honda Ridgeline Discussions 3 09-02-2009 02:58 PM
Check engine light just come on?? ziggers Problems & Issues 11 08-26-2009 04:27 PM
Check engine light is now on Ckimbrough18 Problems & Issues 8 03-05-2009 10:51 AM
check engine and VTM-4 light on miroslavp Problems & Issues 3 02-28-2009 07:32 AM
