Timing belt job - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Under The Hood / Performance
Notices
Thread Tools Display Modes
Old 07-31-2011, 07:00 PM   #1
thooks
ROC Rank: Junior
2006 RTS
Steel Blue Metallic
Timing belt job
DONE!!! I did mine yesterday at 106,500 miles...
Man, what a long job. For a desk jockey, it was a great experience. I learned a lot and do NOT want to do that job again for a very long time. I will probably wait until 225K to do the next one.
The most valuable tool: The 3/8" flex head ratchet I bought Friday. Runner up- my 3/8" air ratchet. And I guess honorable mention goes to the
http://www.amazon.com/Powerbuilt-648796-Crankcase-Pulley-Removal/dp/B0000TMLWQ/ref=sr_1_1?ie=UTF8&qid=1312159933&sr=8-1 http://www.amazon.com/Powerbuilt-648796-Crankcase-Pulley-Removal/dp/B0000TMLWQ/ref=sr_1_1?ie=UTF8&qid=1312159933&sr=8-1
Crankshaft bolt removal tool. Well worth the $36 it took to get it in my hands.
Anyway, this was the most in-depth mechanical work I've done on my own. All by myself, except when my wife held the crankshaft tool while I put the pressure on the 19mm socket to break it free and she helped get the drive belt back on at the end.
There's a LOT of BS in this job as far as the crap you have to do, remove, snake around, etc. I guess that's the deal with working on cars today. I guess there's a lot more room in this truck than some of the cars with the V6 engines, tho.
All in all, I'm pretty darn proud of myself. I hit some gotchyas...the worst was realizing the back camshaft had rolled off of TDC when I was threading the new timing belt on. It did it three more times.
I've still got to replace the spark plugs and open the valve covers up to check the valves (I don't think there's anything wrong with the clearance, but just might go through the exercise for the fun of it.
Was it worth the $500 savings? Yeah. I'd still be wondering if I could do it. Now I know.
thooks is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-31-2011, 07:10 PM   #2
thooks
ROC Rank: Junior
2006 RTS
Steel Blue Metallic
Re: Timing belt job
Oh yeah...
I will say that the Honda V6 video from Eric is the Car Guy was a great help ($10), Looking through my Honda service manual about 800 times over the last year was a fair help, too. The video is on an Accord V6, so it is not exactly the same as the Ridgeline/Pilot/Van, but it is close enough to get by. That and the manual will get'er done.
The tools needed for the job*:
10, 12, 14, 17mm sockets- in both short (reg) and deep 3/8" drive.
19mm deep, 1/2" drive
3/8" extension- 1" or 2", 3", 6", 20"
1/2" extension- 20"+
12mm and 14mm ratcheting, flex head wrenches
Long pattern 14mm wrench
An offset 14mm wrench is helpful also
3/8" ratchet (Flex head is valuable)
1/2" breaker bars (2 needed)
Plastic trim retaining screw/clip removal tool
Deadblow or Ball Peen hammer (helps nudge the water pump along)
Like I said, an air ratchet allows you to take a little break when putting the fasteners back in.
Flexible 10mm, 12mm and 14mm sockets would help. The 3/8" U-joint wasn't that great of a help, but I used it 2-3 times.
All variations of the tools above can be helpful.
*The Job includes:
Removing drive belt
Removing drive belt tensioner, timing covers, engine mount, power steering pump, cable connections, timing belt tensioner, crankshaft bolt/pulley, water pump.
Old 07-31-2011, 10:21 PM   #3
Mtnman
ROC Rank: Junior
2006 RTS
Billet Silver / Gray
Re: Timing belt job
Congratulations
Did you do the CPK clear and learn(camshaft position) procedure? If so how?
I've been wanting to due mine but don't have access to a HDS black box.
Mtnman is offline   Reply With Quote Quick reply to this message
Old 08-01-2011, 05:25 AM   #4
thooks
ROC Rank: Junior
2006 RTS
Steel Blue Metallic
Re: Timing belt job
Yes. It's a simple procedure of getting it up to speed/rpm on a clear, flat road and letting it wind down.
I will get the procedure tonight out of the service manual for you.
Old 08-01-2011, 06:53 AM   #5
hawkeye16
ROC Rank: 1k Comma Club
2006 RTS
Amazon Green / Olive
hawkeye16's Avatar
Re: Timing belt job
Congrats. I wouldn't know where to begin.
hawkeye16 is online now   Reply With Quote Quick reply to this message
Old 08-01-2011, 07:40 AM   #6
twowheeled
ROC Rank: Sophomore
2006 RTL
Crystal Black Pearl
Re: Timing belt job
awesome, how hard was the crankcase pully bolt to remove? I am hoping my 220ft/lb impact will be able to knock it off. A friend had to use a breaker bar with a fence post slipped over it on his integra motor!
twowheeled is offline   Reply With Quote Quick reply to this message
Old 08-01-2011, 08:05 AM   #7
speedlever
Moderator
2008 RTS
Billet Silver Metallic
speedlever's Avatar
Re: Timing belt job
Congrats on the TB replacement thooks. Great job.
Mtnman, here are both the Crank Pattern Learn (CKP) and Idle Learn Procedure (ILP) from the 2006-2008 FSM.
CKP:
ILP:
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is online now   Reply With Quote Quick reply to this message
Old 08-01-2011, 08:23 AM   #8
thooks
ROC Rank: Junior
2006 RTS
Steel Blue Metallic
Re: Timing belt job
twowheeled,
You aren't going to break the bolt loose with an impact...unless it is a 1" gun hooked to one of those large trailer-mounted compressors...in my opinion.
I had a 1/2" breaker bar on a 20" x 1/2" extension. On the breaker bar, I had a 28" long piece of 1-1/4" black iron pipe and it took a LOT of weight on it with about half of the pipe pulled off of the breaker bar. That had the length of the cheater assembly at about 3'.
I had the extension laying on a jack stand and my wife was down holding the big hexagon tool and 1/2" breaker bar with a piece of 1" pipe on it.
There was a loud *POP* when it came loose.
I would say at least 400 lbs of torque was on it.
Old 08-01-2011, 10:37 AM   #9
twowheeled
ROC Rank: Sophomore
2006 RTL
Crystal Black Pearl
Re: Timing belt job
dang!! now I see why my friend used a fence post as a cheater bar. What is the bolt torqued back to, hopefully not over 200ftlbs??
Old 08-01-2011, 11:53 AM   #10
speedlever
Moderator
2008 RTS
speedlever's Avatar
Re: Timing belt job
The FSM says 47 lb-ft... and then another 60* turn... whatever that number is.
I wonder what the actual number would be?
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your Ridgeline?
Model
What model Ridgeline do you drive?
Color
What color is your Ridgeline?
Can you spell?
What letter in the alphabet is the fifth character of the word "Honda Ridgeline"
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Timing Chain Versus Timing Belt amp5516 Under The Hood / Performance 31 12-10-2013 09:54 AM
Timing belt question Chris C Under The Hood / Performance 70 08-14-2011 12:56 PM
Timing belt estimate mike kennedy Under The Hood / Performance 6 11-08-2010 05:15 AM
Timing Belt clarification tjaroszewski Under The Hood / Performance 18 04-20-2010 09:11 PM
Timing Belt in Arizona deserthawaiian Under The Hood / Performance 4 03-09-2010 10:49 PM
