Front brakes make grinding sound when stopping. - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 08-17-2011, 07:21 PM   #1
Tnridgeliner
ROC Rank: Junior
2006 RTL
Billet Silver Metallic
Tnridgeliner's Avatar
Every time I come to a stop, my front brakes make a grinding sound as if the rivets in the pads are rubbing against the disks! The pads are only 8 months old and just 10% worn. Any suggestions?
Tnridgeliner is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-17-2011, 07:40 PM   #2
RustyH
ROC Rank: 4k Comma Club
2006 RTL
Nighthawk Black / Beige
RustyH's Avatar
Re: Front brakes make grinding sound when stopping.
Stop driving immediately, pull both tires off and do a complete inspection of the pads, rotors, mounting brackets and calipers. Report back what you find. I'm guessing either a separated brake pad or loose caliper bracket bolts.
06 RTL, 2011 ROTY billet cubby cover, door sills and license plate frame. Polished Billet Grills, Custom paint, 275/45R/20 Yokohama tires on Rozzi Octane wheels. caliper covers, custom airbag suspension. Kenwood DVD Player, Rockford Power T15004 Amplifier, Six Rockford Power 6.5" speakers and 2 10" downfiring subs. Custom 3 color Wet Okle seat covers. Airraid CAI, throttle body spacer, Magnaflow muffler, Truxedo Pro Tonneau Cover, Hidden Hitch, smoked head and taillights.
RustyH is offline   Reply With Quote Quick reply to this message
Old 08-18-2011, 12:12 AM   #3
kevin_stevens
ROC Rank: 1k Comma Club
2008 RTS
Nimbus Gray Metallic
Is it a rotational, once-per-wheel-turn kind of noise, or a constant grinding based on how hard you're pressing the brake pedal?
KeS
kevin_stevens is offline   Reply With Quote Quick reply to this message
Old 08-18-2011, 05:26 AM   #4
CUinaRidge
ROC Rank: 2k Comma Club
2006 RTL
Where the slides lubricated?
Small rock or pebble wedged in there??
CUinaRidge is offline   Reply With Quote Quick reply to this message
Old 08-18-2011, 05:52 AM   #5
Tnridgeliner
ROC Rank: Junior
2006 RTL
My initial post may come across a bit exaggerated. The brakes work fine. When coming to a slow stop (2-5mph) there is a faint grinding sound when pressing pedal.
Its definitely coming from the front (both sides) and is constant when brakes are applied in forward or reverse. Sounds like metal to metal rub!
The sound is NOT present while driving down the road or braking from higher speeds, just when coming to a complete stop. Disks appear smooth and pads pretty new.
I gotta get a jack that will lift this beast in order to check caliper bolts and if slides are lubed good. I just bought this 06 RTL 4 months ago with 90k miles.
Sorry for not completely explaining.
Old 08-18-2011, 05:54 AM   #6
Tnridgeliner
ROC Rank: Junior
2006 RTL
KeS
The second one Kevin.
Old 08-18-2011, 07:24 AM   #7
speedlever
Moderator
2008 RTS
speedlever's Avatar
I have a long frame floor jack that I use on the central jack points to lift the RL high enough to put jackstands under the side jackpoints. Once I have all 4 corners on jackstands, it's time to get down to business!
Sitting on two jackstands:
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is offline   Reply With Quote Quick reply to this message
Old 08-18-2011, 11:06 AM   #8
IanRTL
ROC Rank: 7k Comma Club
2007 RTL
That looks so much easier than doing one wheel at a time. I have a 2 1/4 ton jack, though. I don't think it's heavy-duty enough to lift the entire front or back of the truck at the same time. One wheel at a time might be the only method I'll be able to follow. The one I have works just fine for our Accord, but I have yet to have to jack up the Ridge. I'm planning on doing it over the next few weeks to replace the pads and do a brake fluid change.
Anyways, Tnridgeliner, does this grinding noise still happen even after you've been driving for a while? Usually, if the truck sits overnight and there is any moisture in the air, you'll get some oxidation on the rotors that will rub off after the first few applications of the brakes. Has this just started happening, or has it been going on since you first put the brakes on? As was asked before, did you make sure the slide pins were lubed? That seems to be a commonly overlooked thing that can affect braking performance/sound. I'm not quite sure if it would cause the grinding sound like you're describing though...
Westin black running boards, AVS vent visors, AVS bug shield, blue LED interior switches, LED interior/exterior lights, GE Nighthawk Sport headlight bulbs, Weathertech floor mats, Extang Trifecta soft tonneau cover, Pioneer AVH-P4400BH bypassed head unit, Metra Axxess ASWC, Jensen Carbon 65C components, Jensen Power 400 2ch bridged amp, 10" Boss Onyx shallow sub in custom behind-seat enclosure, FatMat sound deadening, Pyle backup camera
IanRTL is offline   Reply With Quote Quick reply to this message
Old 08-18-2011, 11:37 AM   #9
kevin_stevens
2008 RTS
Ok, different than mine then, I'm no help.
KeS
Old 08-18-2011, 11:40 AM   #10
kevin_stevens
2008 RTS
Why not? You're only picking up half the truck, that's almost exactly half of your jack's *working* capacity. Usually the only problem with the jack is if the handle angle is too low to pump effectively.
KeS
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your Ridgeline?
Model
What model Ridgeline do you drive?
Color
What color is your Ridgeline?
Can you spell?
What letter in the alphabet is the fifth character of the word "Honda Ridgeline"
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Grinding sound after cold start AlexRTS Problems & Issues 75 03-12-2015 03:21 PM
The infamous grinding (zip!) sound on start - Power steering fluid exchange AlexRTS Problems & Issues 3 09-17-2011 09:16 AM
Slight grinding sound while moving bonescrub Tires, Wheels and Suspensions 5 09-27-2010 11:28 PM
Need info - Grinding sound, pull to right r-squared Under The Hood / Performance 1 05-25-2008 08:43 AM
Front End Noise On Left Turns, Pulling Out and Stopping Mike72677 Problems & Issues 8 09-24-2007 09:30 AM
