| Notices |
#1 |
ROC Rank: Freshman
2007
RTL
White / Beige Join Date: Sep 2011
Custom cheap cold air intake
Hey new to the forum but I figured there's a lot of discussion on intakes and which is best . For the money it seems like your giving your left arm for a simple pipe and filter element . Understandably the k&n intake at somewhere around 200-300$ has the intake box which adds to it's worth. Right? Or does it. Well for under 60$ I made a comparable substitute. Some of you I'm sure will jump on the band wagon of eBay is crap I don't trust it blah blah blah... But for those of you who wanna try it be my guest! But by no account am I garenteeing anything to be safe and if you descide to follow you do so on your own.
35$ ebay intake kit for 92-95 civic (make sure its straight pipe into about 35 degree angle) 10$ sheet of 2x2 plexi glass from home depot 0.97$ walmart flat black spray paint free card board and some high grit sand paper could be about 5$ first ebay intake shortened by about two inches eye it up to be precise mark then cut be sure to clean spare pieces of metal. then sand and paint. second test fit relativly simple if you have half a brain.. take old out put new in... since honda stayed with map sensors no needs for any fancy hookup for and maf sensors so hook up vacuum line and go third.... get the cardboard test and trim test and trim keep goin till you have a shape that blocks most of the air from the engine bay. a hole in the center for the charge pipe worked well for me.. once you have a decent fitting piece of card board... time for step four fourth take the plexi trace your cardboard for a basic shape then cut.. i used an angle grinder but you can use a razor blade but trust me its difficult... any way you can to get the cardboard shape cut from the plexi.... fifth fit it all together if you make it tight enough you wont need any supports but i made a few anyway (not pictured) the mount on the strut tower will work wonders just screw in a small piece from the ebay intake kit and secure it to the hole for the original airbox... honestly if you need more instructions i dont think you should attempt this but im willing to answer questions...ive been working on cars for sometime now and have a good hand in custom fabricating some things so this may not be for the newb section of ridgeline owners... |
| Sponsored Links | |||
Advertisement | |||
#2 |
ROC Rank: 1k Comma Club
2007
RTS
Aberdeen Green Metallic Join Date: Dec 2010
Re: Custom cheap cold air intake
Hmmm....$200-300 vs. $51? I think i'd go your route...good job
I might opt for a black divider over the clear plexiglas Nice first post newbie
![]() Full Size Spare, USA-Spec iPod adaptor, Westin powder coated sidesteps, OEM tow hitch and harness, 2009 camera handle, Back-up camera, Dual input 3.6-inch Boyo Monitor (Second camera on rear of my teardrop trailer), Trunk carpet, Trunk dividers, Billet Grill, Infinity Reference 1031t Tweeters, Full-time power to front and rear 12V outlets, Fumoto oil drain valve, FIGS G2 hood prop kit. Rhino 360B Hitch step, OEM Rear Splashguards, 255/65/17 MS2's. |
#3 |
ROC Rank: Freshman
2007
RTL
Thanks i originally wanted to do that too but home depot didnt have the supplies and i didnt feel like buying a 6x8 sheet of aluminum from the metal shop....
#4 |
2007
RTS
Do you notice any difference over the stock?
#5 |
ROC Rank: Freshman
2007
RTL
Its still no rocket ship but definatly an increase... About as much as an intake should give.. Engine sounds better tho, the thng roars to life at vtec now, before i could barely hear it im excited for the colder weather to it should really have a differnce then....
#6 |
ROC Rank: 2k Comma Club
2007
*Former Ridgeline Owner
Nimbus Gray Metallic Join Date: Sep 2010
I though the stock system was considered a CAI, as it was.
But hey, for around $50, if it sounds better, great!
Leather, Navigation & Moonroof > 245/70 17 Toyo "Open Country" A/T Boots! OEM Steelies 245/70 17 Winter Boots!![]() My other ride is my Bicycle! |
#7 |
ROC Rank: Freshman
2007
RTL
It probably is but i know that k&n refers to there boxed in filter to be a cold air intake... So i did the same , its the same basic idea
#8 |
ROC Rank: 7k Comma Club
2010
RTL
Dark Cherry Pearl Join Date: Mar 2010
I suspect the opening under the hood just in front of the radiator, would be cooler that an area inside the engine compartment, even with the divider.
At least you don't have to work hard to sell us on a $50 mod as hard as K&N does to sell something for 3 to 5x that. |
#9 |
ROC Rank: Freshman
2007
RTL
I doubt this is the most effective way. But i will say its an easy settup no headache....i did see that area and it did look like i could get one in there. But i would need more piping and not in the mood lol...this only took about an hour total with the plexi being the biggest pain.....but like you said its only 50$
#10 | |
2010
RTL
Actually, I think K&N was working on one, but I doubt there are a sufficient number of those RLs around to make it worth their time. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| Cold Air Intake Systems and Low-Restriction Air Filters: A Word to the Wise | Webwader | Under The Hood / Performance | 129 | 03-28-2013 08:18 PM |
| cold air intake | jesse's RTS | Dear Honda: (Feedback Forum) | 4 | 02-05-2008 07:39 AM |
| Best Cold Air Intake??? | brad geisler | Miscellaneous/General Honda Ridgeline Discussions | 6 | 09-26-2006 09:27 PM |
| New Cold Air intake | M.Landon | Under The Hood / Performance | 1 | 05-19-2006 03:59 PM |
