Removing the center console - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Interior
Notices
Thread Tools Display Modes
Old 12-28-2005, 07:50 PM   #1
tcj
ROC Rank: Sophomore
2006 RTS
Amazon Green / Olive
Anyone have any tips on how to remove the center console? I'm installing an Ipod connector and want the cable to come out through the center console so I can hide the wire in there when I don't want it out. I had hoped someone had already done something like this, or there'd be some instructions that involved its removal available at College Hills Honda (what a great resource that site is!) but I can't find anything about how to get the console or the floor-mounted tray loose.
tcj is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-28-2005, 08:01 PM   #2
Lingered_I
ROC Rank: 2k Comma Club
2006 RTL
Nighthawk Black / Beige
Lingered_I's Avatar
Re: Removing the center console
You start by removing the dashboard lower center cover, which requires that you remove both footwell panels either side of the dash center console. Then remove the "not an ashtray" (open and pull up towards you) and remove the screw that's behind it. There is also a screw on both sides towards the lower edge of the dash console. Once removed, pull the whole panel towards you, and disconnect the power socket & heated seat harness connectors.
For the center console itself, remove the rear panel (the one that contains the air vents for rear passengers). It has 8 clips (4 down each side) and two harness connectors. Then remove the center floor tray (that's why you had to remove the dash console) by lifting at the front and detaching the two rear clips. Finally remove the two screws located inside the console at the front, and the two bolts either side of the console at the rear. That's it - the console should now lift out.
Service manual 20-75 & 20-83
Installing the OEM Fog Lamps (05 to 08)
Fixing the "all door" unlock (Pre-Oct 05)
Lingered_I is offline   Reply With Quote Quick reply to this message
Old 12-28-2005, 08:05 PM   #3
Truckin'
ROC Rank: 5k Comma Club
2006 RTL
Steel Blue / Gray
Truckin''s Avatar
You are such a great resource to all of us, Lingered_I. It's great to have you around!
tcj, this sounds like a great mod. Take photos if you have a digital camera and post the process for others to follow.
'06 Steel BLUE RTL with NAV, OEM roof rack, running boards, backup camera, hitch, rear mud guards, air deflector, underseat storage, body side moldings, pin stripes, decals, Doggie Deck, Retrax, vent visors, bull bar, dash plate, tubular hitch step, XM!!
Truckin' is offline   Reply With Quote Quick reply to this message
Old 12-28-2005, 08:14 PM   #4
Lingered_I
2006 RTL
Lingered_I's Avatar
Thanks. I just figured I'd share my $70 investment in the service manual with the rest of you There may be shortcuts to some of these steps that I don't know about until I try this myself, but I'm going to go with the Honda Ipod connector when it's available (next week allegedly), so I'll post pics of that install, which doesn't involve the center console.
Old 12-28-2005, 09:57 PM   #5
tcj
ROC Rank: Sophomore
2006 RTS
Thanks a LOT, Lingered_I! That's just what I needed.
Truckin', I will definitely take photos to document the job. I don't anticipate that it'll be particularly awful - I just did a similar job on my wife's 03 Accord this weekend and was really pleased with how simple it turned out to be, because it seemed daunting at first. Honda seems to have made an effort to make the process smooth, whereas other manufacturers don't seem to take into account that once things are together, they may have to come apart some time later on. Yet another reason I've become a Honda guy, of course!
Old 01-05-2006, 08:23 AM   #6
CTRidgeline
ROC Rank: Freshman
2006 RTS
CTRidgeline's Avatar
TCJ, any update on the pics for the console deinstall/reinstall. If anyone has some or a link, I would like to see it. I may try to get my radios installed this weekend if time permits and want to have good knowledge on getting the console appart.
Thanks!
2006 Ridgeline RTS - Amazon Green
2002 CR-V EX - Silver
CTRidgeline is offline   Reply With Quote Quick reply to this message
Old 11-19-2007, 05:53 AM   #7
guitar88
ROC Rank: Freshman
Does anyone know if the rear slider in the center console is removable? I need to take it out and modify the bottom, then put it back.
guitar88 is offline   Reply With Quote Quick reply to this message
Old 11-19-2007, 08:58 PM   #8
cboosh
ROC Rank: Sophomore
2007 RTX
Billet Silver Metallic
cboosh's Avatar
Originally Posted by Lingered_I View Post
... Then remove the "not an ashtray" (open and pull up towards you) and remove the screw that's behind it. ...
OMFG!!! I struggled with that effin 'not an ashtray' for a friggin hour ... I read your post, went to the Ridge... and it comes right out!!!!!!!!!!!!!
T H A N K Y O U!!!
my other Honda...
cboosh is offline   Reply With Quote Quick reply to this message
Old 11-19-2007, 09:39 PM   #9
Lingered_I
2006 RTL
Lingered_I's Avatar
Glad to help. It's great that these old posts don't go away.
Old 11-19-2007, 09:52 PM   #10
Lingered_I
2006 RTL
Lingered_I's Avatar
Do you mean the armrest or the tray inside the console?
If the latter, you have to remove the upper sliding piece of the console (the bit with the cupholders), but you may also have to remove the entire console. Slide the cupholders forward and then release the two stops which are either side of the release button that you had to squeeze to get the console to slide forwards. Then continue to slide the cupholders forward. If it hits the dashboard before coming free, you will need to remove the entire console. If it does come loose, you can then slide the tray out.
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your Ridgeline?
Model
What model Ridgeline do you drive?
Color
What color is your Ridgeline?
Can you spell?
What letter in the alphabet is the fifth character of the word "Honda Ridgeline"
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Triple power outlets in center console djdj Mods, Installs and How-To's 30 10-06-2010 03:26 PM
Beige Leather Interior for sale $400 includes full seats and console not just covers jlannoo Trading Post 11 05-16-2007 04:47 PM
Center air vents and heat methodtim Interior 39 12-07-2005 08:20 AM
Center console position Ruffles Interior 3 09-13-2005 11:20 AM
Center Console not locking ravill Interior 8 08-12-2005 06:49 PM
